Posted November 26, 200816 yr Auto Window Manager 1.5* Automatically maximize or minimize or normal all new windows you specify. *Automatically minimize all new windows you specify to system tray. *Automatically keep all new windows you specify always on top. *Adds several menu items to standard window system menu. *Minimize the current window to system tray. *Apply transparency effect from 0% (fully transparent) to 100% (solid) rate to any program in Windows 2000/XP/2003/Vista. *Show window property of application, such as window handle, class name, process id etc. *Auto Refresh Internet explorer at custom intervals.DownloadUrl: http://www.eusing.com/WindowManager/WindowManager.htmSize:595 KBMD5 : 7E4741E0B65FEAC55AF46A02590C6051 Edited November 26, 200816 yr by DaRk MaDnEsS
November 26, 200816 yr hey kel! yep try it ... there's a request though for registration (but you can still use it even without going through the registration process)DaRk MaDnEsS was kind enough to work swiftly on my request Edited November 26, 200816 yr by kiki burgh
November 26, 200816 yr thx for your replays i made a little update for uninstall section you can use your version but close the program before uninstall this version closes it automatically
March 1, 200916 yr Edit - no problems today, got the add-on. Thanks.Link is deadInvalid File. This error has been forwarded to MediaFire's development team.The key you provided for file download was invalid.This is usually caused because the file is no longer stored on Mediafire. This occurs when the file is removed by the originating user or Mediafire. Edited March 1, 200916 yr by TribbleBait
March 6, 200916 yr Edit - no problems today, got the add-on. Thanks.Link is deadInvalid File. This error has been forwarded to MediaFire's development team.The key you provided for file download was invalid.This is usually caused because the file is no longer stored on Mediafire. This occurs when the file is removed by the originating user or Mediafire.seems working fine here try again if not i will upload it to a mirror
March 7, 200916 yr seems working fine here try again if not i will upload it to a mirrorThat's what I get for top-posting my edits. I had two failures and after waiting a bit I had a success. Then you read my post and noticed the failure but didn't notice the edit that said I was successful because I didn't put it where it was supposed to be. Perhaps I'll know better next time. No more top-posting. Thanks
