Kelsenellenelvian Posted December 4, 2008 Posted December 4, 2008 I mean in no way To harm vLite or Nuhi and am in no way affiliated or have ever took part in the proccess of making or distributing vLite and release them (vLite & Nuhi) from any implications of me hosting this file.Version 1.2Includes:wimgapi.dll, wimfltr.inf, wimfltr.sys for BOTH x86 & x64!Size 413 kbYou can make this silent by using the /s switch with it. bismark231, johnjr95, mona and 2 others 5 Quote
The Stig Posted December 6, 2008 Posted December 6, 2008 (edited) Kelsenellenelvian, you saved my day! I registered here just to say THANK YOU for that job! I was pissed off with vLite not recognizing those WAIK files, and to do an slipstreamed Vista, I had to use the 1.1x versions, which have very few options.I'm reccomending your job to friends which had the same problem, and giving credits for you.I think that the reason why Nuhi hasn't put those files directly on vLite, is the license of WAIK, or something of the like.THANK YOU! Edited December 6, 2008 by The Stig Quote
Kelsenellenelvian Posted December 6, 2008 Author Posted December 6, 2008 Always nice to hear a thank you. Quote
ALIEDHED Posted January 7, 2009 Posted January 7, 2009 Thanks for your job.PD: Don't function link for download, please reup any, help me Please. Quote
spidernz Posted February 5, 2009 Posted February 5, 2009 hey kel, nice i was looking for this but could you plz reup. Quote
Guest snakecracker Posted February 7, 2009 Posted February 7, 2009 thanks kel.forgot to tell you on msn. Quote
bjfrog Posted February 7, 2009 Posted February 7, 2009 (edited) thanks Kel, my Gimagex is working Edited February 7, 2009 by bjfrog Quote
Wendigo Posted February 10, 2009 Posted February 10, 2009 Brutal, very smart. However, vLite 1.1 already has these files integrated Quote
Guest snakecracker Posted February 10, 2009 Posted February 10, 2009 Brutal, very smart. However, vLite 1.1 already has these files integrated does it? i've just installed it...says it needs that file. Quote
Kelsenellenelvian Posted February 10, 2009 Author Posted February 10, 2009 Hes actually correct (IN A WAY)1.1.6 has the files...1.2 DOES NOTFuture version (If there is ever any) WILL NOT! Quote
Guest snakecracker Posted February 10, 2009 Posted February 10, 2009 well thats weirdwhy would they remove it!? Quote
Kelsenellenelvian Posted February 10, 2009 Author Posted February 10, 2009 Becuase WAIK is proprietary software of MS and Nuhi did not want to chance a C&D from them.Remember the Autopatcher fiasco about 18months ago? Quote
babu Posted March 11, 2009 Posted March 11, 2009 Thank go to Mr.Kelsenellenelvia I request you to kindly enlighten me on the following silent by using the /s switch with it. Quote
x-shadow-x Posted March 12, 2009 Posted March 12, 2009 How are you installing it? Through bat/cmd/runonce? The it would be winfltr.exe /S Quote
hitman1961 Posted September 24, 2010 Posted September 24, 2010 How are you installing it? Through bat/cmd/runonce? The it would be winfltr.exe /SHi Kes,This is it should MJ says.Man i've tried now for 2 days to get the fk vLite at work. all the options i came across did not work out. than there is the enoing rar file that isn't there anymore.i was hopeless untill i search in my native language dutch. then i encountered your topic. Just the thing anyone needs who wants the work with vLite for win7.Thanks a lot. is simply said but ment from the heart.Hitman1961 Quote
