WinRAR AddOn Maker for 3.7 Plus
Info: Creates a custom WinRAR addon, you have options for Registered and Not Registered, Themes and No Themes, you can also choose to set the default theme of your choice... If WinRAR is updated just install it and run this tool again and will build you a updated addon.
download.png Updated Nov 10-2007
MD5: 3CDF2A93BF91ABD59BDB9D6C47B96432
Website: http://www.rarlab.com
yumeyao has a updated addon builder
http://www.ryanvm.net/forum/viewtopic.php?t=6202
Instructions:
- Make sure you have WinRAR already installed and (optionaly) registered
- Run WinRAR3.7x_AAM.exe and enter your choices
- Integrate
- nJoy!
Requirements:
dotNet 2.0 (for FGCBA by n7Epilson)
WinRAR 3.xx (alredy installed)
rarreg.key in "%ProgramFiles%\WinRAR" (optional registration file)
RyanVM Integrator or nLite (for Integration)
  • Replies 81
  • 4 weeks later...
Thanks for the handy tool. Some ideas/requests for a future version...match installed "Integration" settings. Specific requests are:
1) Match installed file associations. (I have 7zip installed also, and prefer for it to be associated with .7z files...aka winrar NOT associated.) This tool automatically associates winrar with all supported file types.
2) Match installed shell integration. (More specifically, I prefer "Cascaded context menus". Default is non-cascaded.)
Thanks again.
LOL who do you think I am Rickdini :lol:
Sorry m8 but im not that good. This addon builder is simpler than it appears, its just a CMD file with a bunch of INF files for different theme settings and stuff.
@Rickdini :) : Well, regardless of your perspective, I still consider your add-on maker impressive. :D It's beyond my skill level.
I'll figure out my solution with some registry comparisons then. (Unless you have a better recommendation?)
Thanks anyway.
Yea but its not for the faint of heart, you might need some addon making skills...
Install the WinRAR Addon "AS-IS" then run InstallWatch
Now open WinRAR and change the settings to the way you like it and run InstallWatch again to see the changes made to the registry.
Export the InstallWatch Reg changes
Use Reg2Inf to convert the InstallWatch RegFile to INF then expand and edit/delete the IN_ file of the addon to add/edit or remove Reg-lines.
  • 6 months later...
Posted (edited)
Does this tool can be apply to winrar 3.71?
I try to apply with winrar 3.71 but got error
!-error(s):
-L2 file not found : zipnew.dat <zipnew.dat>
! error(s).
!!!!-Critical error(s) detected,process aborted
The error also occur when I apply to winrar 3.70. what does it mean?
Edited by yadzil
Maybe you are using a different language, any case will update the addon later today. I have a new INF file
Different language? I used English. Nevermind, I just wait the new version. Thanks Rick.
Give me a list of files you have in your WinRAR folder, this is what mine has.
Formats (Dir)
Default.SFX
Descript.ion
File_Id.diz
License.txt
Order.htm
Rar.exe
Rar.txt
RarExt64.dll
RarExt.dll
RarExtLoader.exe
RarFiles.lst
rarnew.dat
rarreg.key
ReadMe.txt
TechNote.txt
Uninstall.exe
Uninstall.lst
UnRAR.exe
UnrarSrc.txt
WhatsNew.txt
WinCon.SFX
WinRAR.chm
WinRAR.exe
Zip.SFX
zipnew.dat
zipnew.dat and rarnew.dat are both used/copied when you right click and choose New -> WinRAR Archive and WinRAR Zip Arhive so yes these are standard and nessesary.
Rick i have the same problem, no zipnew.dat file :(
Hey what version r u using ??? I'm using 3.71 :)
cool add on tho ;)
