XPtsp Black
FileName: XPtsp.Black.v.1.0.9b1.batch.exe
File Size: 41.3 MB (43,323,358 bytes)
MD5: 1212916d03c25ea7e996427453a8a229
FileName: XPtsp.Black.v.1.0.batch.exe
File Size: 41.1 MB (43,123,697 bytes)
MD5: 8eeb8c0abb158094d398f4b0d0d42573
Change log:
Off-Topic Comment(Click to Show)
  • 220+ folders and icons from "XPtsp green" made black. (still needs polishing) ,
    made 240+ black dialog backgrounds and had to cut out and re-mirror all objects.
    Last updated March 23 2009
    Black v1.0
    -intro.wmv
    -new theme (xptsp)
    -new setup.exe
    -Batch file updates
    -added hex code to patch setupapi.dll, sfc_os.dll, uxtheme.exe
    -latest ehres.dll.res by Ricktendo64
    -zipfldr.dll.res
    -winbrand.dll.res
    -themeui.dll.res
    -shell32.dll.res
    -syssetup.dll.res
    -shimgvw.dll.res
    -logonui.exe.res
    -bootscr.res
    -ftsrch.dll.res
    -winbrand.dll.res
    -winntbbu.dll.res
    -winntbba.dll.res
    -user32.dll.res
    -webcheck.dll.res
    -syssetup.dll.res
    -ntshrui.dll.res
    -netshell.dll.res
    -main.cpl.res
    -inetcpl.mui.res
    -inetcpl.cpl.res
    -ieaksie.dll.res
    -explorer.exe.res
    -dsuiext.dll.res
    -fontext.dll.res
    v0.9.beta2
    -ehres.dll.res by Ricktendo64
    -Sysdm.cpl.res
    -wuaucpl.cpl.res
    -wuaucpl.mui.res
    -srrstr.dll.res
    -netid.dll.res
[Close]
Edited by dougiefresh
Removed unavailable link
  • Replies 59
  • Views 39.1k
here is one with Phenom die :)
amnesia really like the monitor with the Universe :D
nice, huh ? The Andromeda Galaxy.
cool place for vacation, too :D
Edited by amnesia
I agree with you, and have a suggestion: IMO the colors (Black'n'Blue) like in Fixit image look much better, or even Black-green (my taste). Anyway, looks better than blue based backgrounds. :thumbsup:
tnx,
if u lasso only the blue in paint .net and hue eg. -120 it wil turn green,
u could do that whit just a few dialogs u use often if u like...
WOW excellent job guys.
amnesia the right picture with reflection looks good.
i hope you catchup with the normal XPtsp in terms of resources modded.
keep up the good work
Tnx!
the only thing that needs updating atm to "catch up" sorta speak is Rick's ehres.dll.res for mce users.
also black is still beta and needs some work.. however pretty much all 240+ black bitmaps are all ready finished and in the pack.
tnx,
:thumbsup_anim: :prop: :dribble: That's what I'm talking about . Looks very nice. You can make a black-green edition too (I'm very bad with laso use :( )
a Black-green Display Properties! maybe i'll do some more later....
BLACK-gr Display Properties.7z
Thanks mate :thumbsup_anim:
[Edit]: Why don't you use www.mediafire.com for upload? It's fast, free (up to 100MB) and you don't need to wait seconds ;)
Edited by DennyMK
well because i have an acount whit folder structure which is easy for me to manage files, my screenshots come out small on the forum
and i really like the download counter :rolleyes: + i can update files without losing the download link.
and a Black-green System properties ...
Black-gr System properties.7z
Thank you :guitar: :jerry: :D
Edited by DennyMK
lol np.
last one, Black-gr Menu start options.
explorer.exe(Menu start options).7z
u can also try using lasso in combination with magic wand.. set tolerance to about 20-25% and hold Ctrl down while clicking... :)
also hue does not effect blacks or whites so it does not need to be verry precise ;)
i really like this black edition everything working me me so far
just a quick note, i think the folder icons could be better tho and the animations from 165 to 170 so need to be redone just my 2 cents :)
if we could get something like black icons
then this would look really special, anyways keep up the good work guys.
Edited by sT0n3r
thx.. and tnx for reporting!!
i used these for the menu start/mydocs folders
the folders that need work are the other 200 standard folders, witch are generally not in icon pack's so i took those from green and tried to make them black....
i acctually kinda like avi 165 but the others will be made black in the future...
those are not free.... also i made some black hd icons etc, which are white in the green pack...
