xplorer2 lite v1.7.1.4 (Request posted HERE)
Dual-panel, tabbed file manager. And it's FREE.
xplorer2 lite is an easy to use yet very potent and extremely efficient alternative to the standard windows Explorer.
It combines the user-friendliness of the latter with the increased efficiency and advanced features
of good-old dual-pane file managers like Norton Commander.
It is a package that will appeal to the power user, yet its similarity with Explorer will ensure that less experienced users will not be driven away either.
Here are some key features of "xplorer2 lite":
  • Dual pane layout, with intelligent communication between two independent panes.
  • Powerful selection engine, for easily building up selection patterns for items before file operations.
  • File filters, both for selecting and for displaying files.
  • Drivebar navigation, for accessing quickly all the drives installed on a computer.
  • Keyboard shortcuts for nearly all its commands, for efficient everyday use.
  • Complete file date information, utilising Creation and LastAccessed information as well as the normal Modification date.
  • Proper path resolution, including UNC and relative paths (e.g. "C:" as opposed to "C:").
  • Printing of folder contents, find results and other statistics.
  • Proper file sorting, based on extension (alphabetically).
  • Full drag/drop and shell context menu support, for integration with the desktop.
  • Separable tree view; one can have both the tree view and the two contents panes visible at the same time.
  • Multifunctional address bar, for specifying folder names and visual filters, plus for running windows or DOS applications.
  • Dockable Thumbnail bar, for previewing popular graphics formats (jpg, bmp, gif, etc.) plus HTML and M/S Office documents.
  • Efficient navigation, supporting bookmarks, folder history and internet-style back/next folder navigation.
  • Shell namespace browser, allowing the browsing of non-filesystem folders like ControlPanel etc. If you install a shell extension for FTP and/or ZIP content browsing, 2xExplorer will integrate with that too.
  • Autocompletion for paths and other frequently typed information.
  • Copy pathnames of selected items and preview bitmaps, simplifying clipboard transfers.
  • Optional single-click activation schemes for both views and tree, to match your usability patterns.
NB: description from SoftPedia
*** Addon is localized in dutch, english, french, german, italian, portuguese (Brazil), spanish
website :www.zabkat.com
/////////////////////////xplorer² lite 1.8.1.4 INTL True Addon//////////////////
Btn_Download.png Compatibility_rvmi_EN.png(With Help File - in english)
CRC32 : D5B412D0
MD4 : F1B560F0A6055D588FE64FE0F9E2890A
MD5 : F3535065918CF0E2998DADD250E79D96
SHA-1 : 5753C0C96B997CAAA20515EB915EBEB152D6C9C1
PLUS : Added Visterish skin made by FMG.
A BIG THANKS to Kal, ricktendo64 and MrNxDmX who help me to achieve this addon.
Edited by Ken@fri
  • 2 years later...
