Onepiece, a guy from Albania who doesn't speak a word of english (and his italian is not so good, too) has created this IE8 addon...in english!!! ohmy.gif
and went in our italian forum asking us to help him sharing his work with WinCert's forum community (because he can't do it himself)
It works with Nlite 1.4.x and RVM Integrator 1.6 or later on a Windows XP SP 2 or SP 3 sources.
*note: Integrator will doesn't warn anymore about files exceeding 8.3 format: don't worry because integration works fine anyway
Here it is:
OnePiece IE8 WinXPSP3 FINAL True AddOn ENU
tabdownload.png Update (8 April 2014)
Hash MD5 2E1CF7B45ED81F3E992D77D706BDAA67
Filesize: 11.1 MB (11724273 bytes)
This is an universal UpdatePack/Addon Creator:
[Tool] Universal UpdatePack/Addon Creator
If you prefer to create your own addon in every language you like, you can use this tool. You must place only IE installer and the needed hotfixes in your own language in a temp folder. Then run the Addon Creator, enter the path of your folder and wait a few seconds/minutes (depends on your system) for the completion popup. 7-zip the resulting files.
Onepiece's addon allows you to decide if keeping or not IE Desktop Icon:
http://img27.imagesh...sktopicone1.png
http://img27.imagesh...sktopicone2.png
Both solutions work with Nlite 1.4.9.1 or RVM 1.6.1.
IE8 addon is not needed if you integrate Onepiece's XP post-SP3 AIO Update Pack in your XP source because it's already included
IE8 integration esthetic side effects:
* setuperr.log will point out harmless error messages about some IE files like imgutil.dll, inetcpl.cpl, inseng.dll, mshtml.dll, msrating.dll, pngfilt.dll, occache.dll, webcheck.dll (caused by the patched Syssetup.dll used for integration and then restored with the original one). If you don't tolerate it you can integrate in addition Onepiece Repair IE8 cosmetic problems addon (Hash MD5 5C7AF8CA9F637C993F4AEEFFB63F39ED - Filesize: 1.28 Kb - updated 2008-03-27) which cleans the false errors.
changelog:
1.0.0 - 090322: First RTM release - Rebuilded from scratch with IE final and KB968220-IE8
1.0.1 - 090325: fixed some small bugs and code improvements; added TrueAddon Maker
1.0.2 - 090408: fixed ActiveX Control bug
1.1.0 - 090412: added uninstallation
1.2.0 - 090509: added KB969497 (replaces KB968220), now desktop icon
1.2.1 - 090525: added KB971180 (replaces KB969497)
1.3.0 - 090610: added KB969897, 8.3 filenames full support
1.3.1 - 090625: added KB971930 (replaces KB971180)
1.3.2 - 090723: added KB972636 (replaces KB971930)
1.4.0 - 090729: added KB972260 (replaces KB969897)
1.4.1 - 090830: added KB973874 (replaces KB972636)
1.5.0 - 090916: added KB971961
1.6.0 - 091016: added KB974455 (replaces KB972260)
1.7.0 - 091215: added KB976325 (replaces KB974455), KB975364 (replaces KB973874)
1.8.0 - 100123: added KB978207-IE8 (supersedes KB976325-IE8)
1.9.0 - 100210: added KB978506-IE8 (supersedes KB975364-IE8)
1.9.1 - 100310: added KB976662-IE8 (supersedes KB971961-IE8)
2.0.0 - 100416: added KB980182-IE8 (supersedes KB978207), KB980302-IE8 (supersedes KB978506), KB981332-IE8
2.1.0 - 100611: added KB982381-IE8 (supersedes KB980182-IE8), KB982632-IE8 (supersedes KB980302-IE8)
2.2.0 - 100811: added KB982664-IE8 (supersedes KB982632) and KB2183461-IE8 (supersedes KB982381)
2.3.0 - 101109: added KB2360131-IE8 (supersedes KB2183461) and KB2362765-IE8 (supersedes KB982664)
2.5.0 - 110209: added KB2482017-IE8 (supersedes KB2416400)
2.6.0 - 110415: added KB2497640-IE8 (supersedes KB2482017-IE8) and KB2510531-IE8 (supersedes KB976662-IE8 & KB981332-IE8)
2.7.0 - 110616: added KB2530548-IE8 (supersedes KB2497640-IE8) and KB2544521-IE8
2.8.0 - 110812: added KB2559049-IE8 (supersedes KB2530548-IE8)
2.9.0 - 111012: added KB2586448-IE8 (supersedes KB2559049-IE8)
2.9.1 - 111201: added KB2598845-IE8 (
supersedes KB2447568-IE8)
3.0.0 - 111214: added KB2618444-IE8 (
supersedes KB2586448-IE8)
3.2.0 - 120216: added KB2647516-IE8 (supersedes KB2618444-IE8)
3.3.0 - 120411: added KB2675157-IE8 (supersedes KB2647516-IE8)
3.4.0 - 120710: added KB2699988-IE8 (supersedes KB2675157-IE8)
3.5.0 - 120815: added KB2722913-IE8 (supersedes KB2699988-IE8)
3.6.0 - 120921: added KB2744842IE8 (supersedes KB2722913-IE8)
3.7.0 - 121212: added KB2761465-IE8 (supersedes KB2744842-IE8)
3.8.0 - 130114: added KB2799329-IE8
3.9.0 - 130213: added KB2792100-IE8 (supersedes KB2761465-IE8 and KB2799329-IE8) and KB2797052 (supersedes KB2544521-IE8)
4.0.0 - 130313: added KB2809289-IE8 (supersedes KB2792100-IE8)
4.1.0 - 130410: added KB2817183-IE8 (supersedes KB2809289-IE8 & KB2797052-IE8)
4.2.0 - 130515: added KB2829530-IE8 (supersedes 2817183-IE8) and KB2847204-IE8
4.3.0 - 130611: added KB2838727-IE8 (supersedes 2829530-IE8 and KB2847204-IE8)
4.4.0 - 130710: added KB2846071-IE8 (supersedes KB2838727-IE8)
4.5.0 - 130814: added KB2862772-IE8 (supersedes KB2846071-IE8)
4.6.0 - 130911: added KB2870699-IE8 (supersedes KB2862772-IE8)
4.7.0 - 131009: added KB2879017-IE8 (supersedes KB2870699-IE8)
4.8.0 - 131113: added KB2888505-IE8 (supersedes KB2879017-IE8)
4.9.0 - 131211: added KB2898785-IE8 (supersedes KB2888505-IE8)
5.0.0 - 140212: added KB2909210-IE8 (supersedes KB2510531-IE8) & KB2909921-IE8 (supersedes KB2898785-IE8)
5.1.0 - 140312: added KB2925418-IE8 (supersedes KB2909921-IE8)
FiNAL 140408: added KB2936068-IE8 (supersedes KB2925418-IE8)
Edited by kontini
  • Replies 290
  • Views 262.6k
  • marspetite
    marspetite
    you are mentioning IE7, but you mean IE8... Is it necessary to addon IE7 addon first? What i mean is: does IE8 need IE7 to be installed?
  • @marspetite No, it is a mistake when the words are copied from the topic of IE7, enough to be used only ie8 addon. @All OnePiece IE8 WinXPSP3 AddOn PLK OnePiece IE8 WinXPSP3 AddOn PTB OnePiece IE8 Win
  • new monthly update
hey thanks
Is it the final build Internet Explorer 8 RTM or still RC1 ? and why the size is only 11mb where as the official has download size approx 16 mb?
Edited by zabardast_1
Sorry for my English, When you enter kontini tells you all better.
That's great. Can you do that for the dutch version as well, please?
Yes, and the question of days and put online RUN_Automatic_OnePiece_IE8_XP_Own_AddOn_Creator_INTL.exe, which will create this addon in all languages
OnePiece
Thanks buddy, thats exactly I was looking for grrrr8 job :thumbsup_anim:
Thanks ;)
Thanks in advance Onepiece :thumbsup_anim:
I sure hope it will create a True Addon :rolleyes: Is it also applicable with IE8 for MSN?
kontini tell onepiece about this folder
He has to update this because occache.dll is like webcheck.dll now, it cannot be self registering so the icon will no longer show unless you do this:
;   File/Folder Attributes
; R=1; H=2; S=4; HS=6; SHR=7
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\RenameFiles\Win",,,"%10%"
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\RenameFiles\Win",FOLDER1,,"Downloaded Program Files,1"
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\RenameFiles\Win",FILE1,,"Downloaded Program Files\desktop.ini,6"
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\RenameFiles\Win",FOLDER2,,"Offline Web Pages,1"
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\RenameFiles\Win",FILE2,,"Offline Web Pages\desktop.ini,6"
link is down
Hello Boooggy, my fault, I was updating the files to the server, or a slow connection, or had a little late to change the files.
Updated by request of OnePiece
Thanks ricktendo64.
Not working in polish version IE8 :(
tabdownload.png Updated (June 15-2009)
Hash MD5 70634E880B9137E5CA9D764A3CFD6489
Filesize: 11.2 MB (11782298 bytes)
Edited by OnePiece
Sorry, about the ie8 addon PTB is not working or RUN Automatic OnePiece IE8 XP Own AddOn Creator INTL.exe ??????
Edited by OnePiece
ie8 addon PTB make with RUN Automatic OnePiece IE8 XP Own AddOn Creator INTL.exe not working.
Show an error message in integration
Hash MD5 3C0BBB43C986DC4007119252BE78A7BC
Filesize: 11.1 MB (11713229 bytes)
Edited by OnePiece
