------------Windows x86------------
size.png136 KB
post-4451-1205780671.png633d656422503728af4362435618c14a
------------Windows x64------------
size.png147 KB
post-4451-1205780671.png57d3ccf878aa6d4c913a05e49b9ce1c8
Description
Enable animated backgrounds support for Windows 7! (All Builds "Works Only When Aero Is Enabled")
Edited by Jatin Beniwal
Updated the layout and added screenshot
Thanks alot for this, i will try it on my build 7057 boot later :thumbsup_anim:
PS: You should also give preview/screenshot of it here, just my suggestion hehe, anyway thanks :D
  • 5 months later...
Hi,
how can I use the file *.wa?
pretep
You can either use Windows 7 Toolkit to install it to a Windows 7 ISO.
OR
You can install it with the new tool which reads WA files :D
Unfortunately it isn't possible to install it via the W7T Installer on a RTM of Seven. It always says "need Build 7000" ...
yeah it's locked
try to go into the Task.txt and remove the build line
and it would work fine
Fixed and Updated. Now u can use it with WA installer or Windows 7 Toolkit.
  • 4 weeks later...
Hey Jatin:
I got this to work and install. BUT I cannot make it start. I see the play dreamscene shell ext but it is always greyed out.
I downloaded several dreamscenes and tried clicking on them and even put them in the proper folder.
Is there something I am missing?
YES i do have aero enabled and rebooted.
Hey Jatin:
Working For Me.
Use this one if in case problem not fixed http://www.mediafire.com/?hjzemvqgl2n
Hey Jatin:
Same problem as you. tested a lot of solution only the *.WA pack worked for me. But i'm stuck with the "Play Dreamscene" option greyed.
Windows 7 RTM Entreprise Ed. 64b
Pack used : and
it's the only one who bring me the "Play Dreamscene" and "Add as Wallpaper" option in right clic menu.
Open to suggestion :-/
information :
Processor : 6.0
Memory : 5.5
Graphics : 2.1
Graphics (game) : 3.3
HD : 5.9
Edited by Crazysky
