Here is ImgBurnADDONBuilderV1.1 2011
Notes
Install ImgBurn before you run this addon builder! Its best to unpack the ImgBurn.exe with 7zip program ore universal extractor programma. Put the files in C:\Program Files\ImgBurn (If you install the program the normal way you're probably and up with the crap ask.com toolbar junk)
This addonbuilder is English only atm. You can download other language files ad there homepage.
Features:
ImgBurn is a lightweight CD / DVD / HD DVD / Blu-ray burning application that everyone should have in their toolkit!
* Read - Read a disc to an image file
* Build - Create an image file from files on your computer or network - or you can write the files directly to a disc
* Write - Write an image file to a disc
* Verify - Check a disc is 100% readable. Optionally, you can also have ImgBurn compare it against a given image file to ensure the actual data is correct
* Discovery - Put your drive / media to the test! Used in combination with DVDInfoPro, you can check the quality of the burns your drive is producing
Homepage:
Install from: True addon maker
MD5 hash: b2ffb6e44f9b88696da846c339d503b0
File Size: 291 kB (298.748 bytes)
Download here:
Edited by UtCollector
  • 3 months later...
  • 2 years later...
  • 9 months later...
Thanks for ths tool. I sounded promising till it threw this error. All files are present in my default installation of imgBurn 2.5.7
!- 6 error(s):
- L2 File Not Found: ImgBurn.exe (ImgBurn.exe)
- L2 File Not Found: ImgBPr.exe (ImgBurnPreview.exe)
- L2 File Not Found: ReadMe.txt (ReadMe.txt)
- L2 File Not Found: unnstll.exe (uninstall.exe)
- L2 File Not Found: Error.wav (Error.wav)
- L2 File Not Found: Success.wav (Success.wav)
!- 6 error(s).
!!!!- Critical error(s) detected, process aborted.
Edited by dotfusion
