Posted April 16, 200915 yr Animated Cpl's; Dll's; Exe's; Etc. for XPSource files from Xp Sp3; - bmp's, dialogs, icons, and stringsedited/replaced with animated Avi's added.----------------------------------------------------------------------------------------------1) MSGINA.DLL with animation and Hibernate added:- aa7388eca0e464c9bc7d0c674546ca0b 252 kb's1) Download MSGINA Addon----------------------------------------------------------------------------------------------2) SNDVOL32.EXE with animations added:- e7257d884d930c2ffab2d1fd24d62fcf 76 kb's2) Download SNDVOL32 Addon----------------------------------------------------------------------------------------------3) SYSDM.CPL with animations, and "msoft" OEM logo added:- 124808c38afe628d251c2b48c24b0efa 506 kb's3) Download SYSDM with OEM Addon----------------------------------------------------------------------------------------------4) REGEDIT.EXE with animation added to "Find" section dialog (request):- 714dfed15cc5dee924361e83cab34e63 81 kb's4) Download REGEDIT Addon----------------------------------------------------------------------------------------------5) INTRO.WMV (Windows7 Style) for OOBE section (640x480 7sec's duration):-Credit to bmw09121985 for the bmp's I used to make this f10b41c39293872b0d7678144648abc8 109 kb's5) Download INTRO (Win7 Style) Addon----------------------------------------------------------------------------------------------BTW- Gif Images posted are not the best; because I had to take AVI's of the animated files, convert to Gif's, and host the images, so quality and frame rates suffer a lot during the process.May add some others later ...Changelog:-01/05/2009- updated from MSGINA addon to various animated Addons Edited May 24, 200915 yr by wolfcall
April 16, 200915 yr Hej thats really nice. I will try it in some of my versions.I might try it in this one later: http://utcollector.deviantart.com/art/Shut...glish-112537934
April 16, 200915 yr Author cheers guys ... very welcome @UtCollector ... nice msgina on deviantart ... If you wanna edit some of your own styles you will find the regtweak to add hibernate button to the "bar" makes the shutdown box a bit longer and narrower ... I had to reposition the "bar" of the bmp to make it scale to regtweak alteration.
April 20, 200915 yr man that's really nice :thumbsup_anim: can it be done on other xp dialogs?if yes it will be awesomethanks wolfcall
April 20, 200915 yr Author @felix3650....yeah AVI's can be added to a fair few dll files, and cpl's and dialogues altered to suit.example animated mouse:-example animated "Run" message:- cro-man done a tutorial on adding AVI to msgina.dll ... and the same method can be used toedit many dll files and cpl's to add animations.cro-man Tutorial
April 20, 200915 yr how do you center the cancel button? i've seen that in some before. for example http://relentles11.deviantart.com/art/Opus...Dialogs-5486976
April 20, 200915 yr @felix3650....yeah AVI's can be added to a fair few dll files, and cpl's and dialogues altered to suit.example animated mouse:-example animated "Run" message:- cro-man done a tutorial on adding AVI to msgina.dll ... and the same method can be used toedit many dll files and cpl's to add animations.cro-man Tutorial do you mind making a few more of these please?Thank you
April 20, 200915 yr Author @ccl0....Resource Hacker or Restorator good for editing the files ...I prefer Restorator.Open msgina.dll in Restorator .... and under Dialog branch open no. 20100then click Edit Mode tab and you will see the layout appear....then drag the "cancel" button to the position you want click Edit Mode Tab again....and say yesto change....then save the new file.see what I mean here:-@qwesta...give me idea of what shells or cpl's you would like to see Animations onand I'll see if I already got, or possible to make and upload.
April 26, 200915 yr Hi Dave :welcome: .... yeah, Xp tweaks ... never ending That's for sure looking at your desktop you are still creating plenty and doing a fantastic job at it too Good on you I knoow you work very hard at it :thumbsup_anim:
April 29, 200915 yr Author @wolfcallchk PM pleaseok .. added a few more, and posted download links Edited April 30, 200915 yr by wolfcall
May 1, 200915 yr @wolfcall....u've got a preety impressive desktop bro :-). I like ur sidebar design. Any clue how I can make one mine...and r u using rocketdock on the top of ur desktop?
May 1, 200915 yr Author @bigb ... welcome @Talisman ... cheersNo, it's not rocketdock or objectdock; and the sidebar isn't the usual Vista Sidebar.I'm using Winstep Xtreme v8.11, it's providing the side-gadgets and the dock u see,and another hidden dock on the left of my screen that activates when I hover mouseover it ....Here's the homepage:-http://www.winstep.net/index.asp?cat=winstepon that page, you can play a little video of it, to see it in action.
May 3, 200915 yr Author @MANIKANT.S.GUPTA ....Not sure if it's the msgina (shutdown) you would like to see "cool blue".AVI backgrounds are not transparent ... background of avi needs matched tothe colour of the image that its added to .... that makes it difficult to blend as thoughit's not blended when trying to be too creative with "cool" colours .....and also, most important, keep the AVI file size small .....don't want a 1mb dll file trying to play a100 mb avi file ...lol....but I'll try a "blue" shutdown and post it, if it turns out ok.@AMIRZ & Talisman ... very welcome
May 3, 200915 yr Author wow thankyou wolfcallso if you can make avi search in find section of regeditmona ....do u mean add this sort of animated avi...to this section of Regedit.exe?
