ricktendo Posted January 24, 2007 Posted January 24, 2007 Vista RTM FontsFor use with the RyanVM Integrator 1.4.x and nLite 1.3 RCx Updated v1.1 01-28-07MD5: 57FD5F0B5F176DB615658FA5B5EE55B2Size: 5.72 MBRTM Fonts Changelog:01/28/07- Fixed nLite TXT Setup Missing File Issue Quote
Provolino Posted January 27, 2007 Posted January 27, 2007 sorry but same question:is it compatible with nlite ? Quote
cygnus Posted January 27, 2007 Posted January 27, 2007 All the add-ons rick makes and puts in here are for nLite, I'm pretty sure on that. Quote
ricktendo Posted January 27, 2007 Author Posted January 27, 2007 The latest nLite 1.3 RCx YES!... 1.2.1 NO! Quote
Provolino Posted January 27, 2007 Posted January 27, 2007 really thanks I always use latest nlite build Quote
ricktendo Posted January 28, 2007 Author Posted January 28, 2007 Updated v1.1 Fixes nLite Issue Quote
just_laze Posted February 11, 2007 Posted February 11, 2007 Hey,Would it be too much to ask for some example fonts? What do the Vista RTM fonts look like?laze. Quote
ricktendo Posted February 12, 2007 Author Posted February 12, 2007 They are only required if you integrate the sidebarBTW you can download them and double click on the file and a preview will open up Quote
Nomadturk Posted January 6, 2009 Posted January 6, 2009 (edited) The thing is, when i install these fonts, they work OK. But, for some reason in the fonts directory, they're named like:%segoe_ui%%calibri%etc. And i was fine with it up until today. When i realized Autocad 2009 is denying to work, i found out that it was something with the fonts, moved them to desktop then after moved back, everything was back to normal.I think some registry key was not functioning right. I'll look in to it later (:Just to let you guys know.(:--Update--Here is the screenshot f the corresponding registry entry, after a successful and fresh installation.And this a part is from HiveSft.inf file. Comparing to rest, it all seems normal.HKLM,"SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts",,0x00000012HKLM,"SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts","%calibri%",,"calibri.ttf"HKLM,"SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts","%calibri_bold%",,"calibrib.ttf"HKLM,"SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts","%calibri_italic%",,"calibrii.ttf"HKLM,"SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts","%calibri_bold_italic%",,"calibriz.ttf"HKLM,"SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts","%segoe_print%",0,"segoepr.ttf"HKLM,"SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts","%segoe_print_bold%",,"segoeprb.ttf"HKLM,"SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts","%segoe_script%",,"segoesc.ttf"HKLM,"SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts","%segoe_script_bold%",,"segoescb.ttf"HKLM,"SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts","%segoe_ui%",0,"segoeui.ttf"HKLM,"SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts","%segoe_ui_bold%",,"segoeuib.ttf"HKLM,"SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts","%segoe_ui_italic%",,"segoeuii.ttf"HKLM,"SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts","%segoe_ui_bold_italic%",,"segoeuiz.ttf"HKLM,"SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts","%simhei%",,"simhei.ttf"HKLM,"Software\Microsoft\Windows NT\CurrentVersion\Fonts","%roman%",,"ROMAN.FON"HKLM,"Software\Microsoft\Windows NT\CurrentVersion\Fonts","%script%",,"SCRIPT.FON"HKLM,"Software\Microsoft\Windows NT\CurrentVersion\Fonts","%modern%",,"MODERN.FON"HKLM,"Software\Microsoft\Windows NT\CurrentVersion\Fonts","%small_fonts%",,"SMALLE.FON"HKLM,"Software\Microsoft\Windows NT\CurrentVersion\Fonts","%arial%",,"ARIAL.TTF"HKLM,"Software\Microsoft\Windows NT\CurrentVersion\Fonts","%arial_bold%",,"ARIALBD.TTF"HKLM,"Software\Microsoft\Windows NT\CurrentVersion\Fonts","%arial_bold_italic%",,"ARIALBI.TTF"HKLM,"Software\Microsoft\Windows NT\CurrentVersion\Fonts","%arial_italic%",,"ARIALI.TTF"HKLM,"Software\Microsoft\Windows NT\CurrentVersion\Fonts","%courier_new%",,"COUR.TTF"HKLM,"Software\Microsoft\Windows NT\CurrentVersion\Fonts","%courier_new_bold%",,"COURBD.TTF"HKLM,"Software\Microsoft\Windows NT\CurrentVersion\Fonts","%courier_new_bold_italic%",,"COURBI.TTF"HKLM,"Software\Microsoft\Windows NT\CurrentVersion\Fonts","%courier_new_italic%",,"COURI.TTF"HKLM,"Software\Microsoft\Windows NT\CurrentVersion\Fonts","%lucida_console%",,"LUCON.TTF"HKLM,"Software\Microsoft\Windows NT\CurrentVersion\Fonts","%lucida_sans_unicode%",,"L_10646.TTF"HKLM,"Software\Microsoft\Windows NT\CurrentVersion\Fonts","%times_new_roman%",,"TIMES.TTF"HKLM,"Software\Microsoft\Windows NT\CurrentVersion\Fonts","%times_new_roman_bold%",,"TIMESBD.TTF"HKLM,"Software\Microsoft\Windows NT\CurrentVersion\Fonts","%times_new_roman_bold_italic%",,"TIMESBI.TTF" Edited January 6, 2009 by Nomadturk Quote
ricktendo Posted January 6, 2009 Author Posted January 6, 2009 Look in [strings] the values should be thereIt may also be that it cannot find CONFIGURE_PROGRAMS="Set Program Access and Defaults" in the strings section, because after this line the "ExtraFileEdit" will add those string valuesCONFIGURE_PROGRAMS="Set Program Access and Defaults"calibri = "Calibri (TrueType)"calibri_bold = "Calibri Bold (TrueType)"calibri_italic = "Calibri Italic (TrueType)"calibri_bold_italic = "Calibri Bold Italic (TrueType)"segoe_ui = "Segoe UI (TrueType)"segoe_ui_bold = "Segoe UI Bold (TrueType)"segoe_ui_italic = "Segoe UI Italic (TrueType)"segoe_ui_bold_italic = "Segoe UI Bold Italic (TrueType)"segoe_print = "Segoe Print (TrueType)"segoe_print_bold = "Segoe Print Bold (TrueType)"segoe_script = "Segoe Script (TrueType)"segoe_script_bold = "Segoe Script Bold (TrueType)"simhei = "SimHei (TrueType)" Quote
Nomadturk Posted January 7, 2009 Posted January 7, 2009 (edited) Well... That section is called like below in Turkish systems. (:CONFIGURE_PROGRAMS="Program Erişim ve Varsayılanlarını Ayarla"I've added these to the necessary sections. I think it'll be fine now.Thank you Rick. Edited January 7, 2009 by Nomadturk Quote
ricktendo Posted January 7, 2009 Author Posted January 7, 2009 I did not think of that...I think it could be made compatible with all langs if i use [strings]<NEXT> instead of CONFIGURE_PROGRAMS=... for the ExtraFileEdit to search for Quote
Nomadturk Posted January 8, 2009 Posted January 8, 2009 Well, thinking of all the people using this pack, i must admit i am quite surprised to be the one finding this bug.I've edited the necessary section within my .inf file. But if you make that change, i may use it when i am to build a new release from scratch.(: Quote
bigrandalo Posted January 9, 2009 Posted January 9, 2009 i don't see that problem with german xp =) works like a charmregardsbigrandalo Quote
ERMaCDR Posted July 23, 2010 Posted July 23, 2010 Que tal Rick, una pregunta este addon es compatible con WINXP SP3 ES y si no hay problemas de integrarlo con Nlite 1.4.9.1 porque veo que el post es algo viejo Quote
ricktendo Posted July 23, 2010 Author Posted July 23, 2010 Si estas bien, pero si integras el sidebar este addon no es necesario Quote
svseke58 Posted February 3, 2012 Posted February 3, 2012 I'm need to this fonts addon but download link was deleted.Do you upload this again?Please. Quote
ricktendo Posted February 3, 2012 Author Posted February 3, 2012 Sorry, 5 year old addon dont have it anymore...you can find the same fonts type addon in my sidebar addon Quote
svseke58 Posted February 3, 2012 Posted February 3, 2012 i have fonts, i need to inf file content all of (CONFIGURE_PROGRAMS="Set Program Access and Defaults"......etc),i would be happy if you find.(i dont use sidebar i need only font package)Thanx. Quote
ricktendo Posted February 3, 2012 Author Posted February 3, 2012 I did not say you have to use the addon, just download and look how I add/copy the fonts using entries.ini and how I add the font registry entries (I dont use a INF its all done with the INI) Quote
svseke58 Posted February 3, 2012 Posted February 3, 2012 okey, i will try to make it.thank you. Quote
ricktendo Posted February 3, 2012 Author Posted February 3, 2012 This is pretty much all you need in your entries_fonts.ini[general]builddate=2012/02/03description=Fonts addon description.language=Multilanguagetitle=Fonts packversion=1.0.0website=http://www.example.com[EditFile]i386\hivesft.inf,AddReg,AddFonts[AddFonts]HKLM,"SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts","Font 1 Example (TrueType)",,"font1.ttf"HKLM,"SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts","Font 2 Example (TrueType)",,"font2.ttf"[dosnet_files]d1,font1.ttfd1,font2.ttf[txtsetup_files]font1.ttf = 100,,,,,,,22,0,0,,1,22font2.ttf = 100,,,,,,,22,0,0,,1,22[i386_compress]rvmtemp\extracted\font1.ttfrvmtemp\extracted\font2.ttfWhen you are done making your addon and you want me to give it a glimpse to see if its OK, go ahead and post it here Quote
