Posted July 23, 200915 yr Reaper v3.05INFO:AudioREAPER's no-compromises 64-bit audio engine and 64-bit end-to-end signal path offer the maximum in resolution and headroom. Unlimited track counts, total routing freedom, draggable sends, beat-based audio templates, sidechain support for any plugin - REAPER gives you both power and flexibility.MIDIREAPER doesn't discriminate against MIDI. You can freely mix audio and MIDI routing, even within a single track. REAPER's parameter modulation allows you to creatively sidechain midi and audio: drive your synth's cutoff filter with an audio signal, or create midi triggers with an audio gate. You can even script your own JS MIDI processing plug-ins and customized game controller-to-MIDI support!Everything You NeedREAPER includes over a dozen top-quality 64-bit ReaPlugs, the celebrated Elastique 2 real-time pitch-shifting engine, full REX support, and literally hundreds of user-programmable effects. Run almost any VST, DX, or AU (OSX only) plug-in, or use the included JS audio and MIDI plug-in scripting engine to create your own. Nothing You Don'tREAPER's 4MB download is smaller than some web pages. It contains no multi-gigabyte library of someone else's music, no crippled evaluation versions of a bunch of software somebody paid us to package, no arbitrary hardware or software restrictions and absolutely no invasive copy protection system. Website: http://www.reaper.fmMD5 - 4EF22B9D4F97FCB2962B65E4D304D714Size - 4.75 MB Edited July 23, 200915 yr by LUZR4LIFE
July 23, 200915 yr your link brings me to tugzip.com :g: btw since this is 64 bit, can it be used on x32 os ?
July 23, 200915 yr Author your link brings me to tugzip.com :g: btw since this is 64 bit, can it be used on x32 os ? Link is fixed, sorry. I use the same template for my topics. LOL. I made this addon for a friend, I have never used it. I believe the 64 bit is not the OS specs but audio specs. The website doesn't have much about the program. The program is for producing, editing music.
July 23, 200915 yr Author well still i don't know what this addon doesso i gonna give it a try and testSorry DaRk MaDnEsS. I made it for a friend and thought I would share. It's not freeware also. All I can say, is this program is used in studios for making music, adding and mixing vocals etc.
February 13, 201015 yr LUZR4LIFE there is a new release if you want to updateit 3.301it just got out todayi'm trying to use this tool this days it seems a nice one
