Posted February 10, 200718 yr WMP 11 Slipstreamer Control Panel v0.94 Requires .Net 2.0 or higherCerated by booogy and n7EpilsonShortcuts added to Control Panel and Start->All Program->UtilitiesAddon halted, merged with nLite addonMD5: 9CDAFC8B171547875A325CE235BF2D04Size: 410 KBSite: http://web.clicknet.ro/boooggy/Forum: <a href="http://www.ryanvm.net/forum/viewtopic.php?t=4109" target="_blank"><a href="http://www.ryanvm.net/forum/viewtopic.php?t=4109" target="_blank"><a href="http://www.ryanvm.net/forum/viewtopic.php?t=4109" target="_blank">http://www.ryanvm.net/forum/viewtopic.php?t=4109</a></a></a>Changelog:10-15-2007- Updated v0.9410-05-2007- Updated v0.9309-23-2007- Updated v0.9209-18-2007- Updated v0.9108-26-2007- Updated v0.8508-19-2007- Fixed cpl shortcut bug08-18-2007- Updated v0.8208-15-2007- Updated v0.8108-05-2007- Updated v0.8007-27-2007- Updated v0.79- Tweaked Uninstall to make compatible for XP Home users- Moved CPL shortcut to "Performance and Maintenance" sub section07-13-2007- Updated to v0.78- Improved INF Uninstall05-25-2007- Updated to v0.73- Changed AddOn Version Number Format to 7(Year).05(Month).25(Date)05-18-2007- Updated v0.7205-04-2007- Updated v0.71- Added Utilities Shortcut Edited March 17, 201015 yr by ricktendo64
June 22, 200717 yr Author Used to slipstream WMP11 and its updates/hotfixes into your XP CD updating the old WMP9 files on your CD ROM
July 28, 200717 yr And at nome of file fault "a"http://www.sokoolz.com/addons/r64/Ricks_WM...79_CPLAddOn.raris not "Slipstremer" but "Slipstreamer", right?But its a g8 addon.Thanks.0d Edited July 28, 200717 yr by 0d14r3
August 11, 200717 yr Not if you choose the tweaked option. (It says it right there in the descriptions )Now go and buy a legit copy!
August 19, 200717 yr no shortcut is created at control panel with the latest version. :icon_question: no problem with v0.81
August 19, 200717 yr Author Fixed... Sorry dudes this was a result of me adding _is1 at to the CLSID of the cpl shourtcut reg entrie. It was only meant for the uninstall reg entrie.
August 26, 200717 yr Boogy have updated to 0.85 today :Posted: Sun Aug 26, 2007 3:00 pm Post subject: --------------------------------------------------------------------------------slipstreamer updated to version 0.85 Changelog: v0.85 1. Switch to win32 resource api / brute force byte search to extract type 2 hotfixes. 2. Switch to ms delta api to extract type 1 hotfixes (resolves sp3 incompatiblity) 3. Speed optimization to cabinet.dll interface (faster compression) 4. Fixed: WMP11Slipstreamer loses focus while extracting hotfixes (fixed by 1 and 2). 5. Update of SimpleIniEditor to v4. 6. Update of ArgumentParser to v2.5. 7. Fixed crash when windows source EULA.txt is corrupted or empty. 8. Better error handling in cabinet.dll to help uncover mysterious errors (the ones with Code: None). 0d
