user_hidden Posted November 10, 2009 Posted November 10, 2009 (edited) XPSP3_QFE_UpdatePack for Windows XP Post-SP3 I have to gather some funds to get some new/used hardware. If anyone is willing to donate $ or parts to the cause please PM me. Link: XPSP3_QFE_UpdatePack_20160510.7z (when downloading UNCHECK "fast download") MD5: 24a1ce33701783461e1dc963ab4f4b8e SHA-1: 5be7b2925914e83ec69a26a3f3c76200fa38c12f OS: Windows XP SP3 (x86) Date: 20160510 Size: 57.3 MB For those interested in an addon for POSReady/Embedded extended updates to the pack look here: XPSP3 QFE POSReady Updates You can integrate this using RVMi v1.6.1 b2.1 or nlite 1.4.9.3 What is included: KB892130 - Windows Genuine Advantage Validation Tool ActiveX Control 1.9.42.0 KB898461 - Permanent copy of the Package Installer for Windows version 6.3.13.0 KB909520 - Software update for Base Smart Card Cryptographic Service Provider KB916157 - When you receive a Stop error message or a fatal system error message, a user-mode process dump file is not created in Windows XP KB922120 - Network Map in Windows Vista does not display computers that are running Windows XP KB927374 - Microsoft Compression Client Pack 1.0 for Windows XP KB931125 - Microsoft Root Certificates Update (41.0.2195.1604) KB932716 - Image Mastering API v2.0 (IMAPIv2.0) update package that is dated June 26, 2007 (cdrom.sys) KB942213 - The MMC.exe program randomly becomes unresponsive when the user clicks OK or Cancel several times to close a Windows form KB942288 - Windows Installer 4.5 KB943232 - An application that uses Sxs.dll crashes when running the application KB944043 - Windows Server 2008 read-only domain controller compatibility pack KB946648 - Security update for Windows Messenger 4.7 KB947460 - "<Drive Letter>: is not accessible" error when trying to open a mapped DFS folder after coming out of standby KB948046 - A Word document is not printed as expected after installing the Windows European Union Expansion Font pack KB948101 - USB keyboard does not work after restarting a computer that has an NVIDIA 680i motherboard KB948720 - Cannot install device drivers in a Windows Server 2008 cluster environment if the drivers contain LZ-compressed files KB949127 - Cannot establish a wireless connection using EAP authentication if the Service Set Identifier (SSID) includes a comma KB949900 - The RunOnce.exe process may stop responding during the driver installation process KB950616 - An audio application that uses the Portcls.sys file may stop responding KB950974 - Vulnerability in Event System could allow remote code execution KB951126 - Multiprocessor computer stops responding on a black screen after resuming from hibernation KB951376 - Vulnerability in Bluetooth stack could allow remote code execution KB951531 - The W32Time service does not synchronize the CMOS clock time to the Internet time after the W32Time service stops KB951608 - Update for Credential Security Support Provider (CredSSP) in Windows XP Service Pack 3 KB951618 - A black screen occurs when upgrading the operating system on a computer that has Onekey Recovery 5.0 installed KB951624 - A 30-second delay occurs during the initialization of some network-based applications KB951709 - Event ID 26 when attaching two IDE ATA/ATAPI devices as master and subordinate IDE devices KB951978 - Script output is not displayed as expected when running VBScript or JScript scripts KB952004 - Description of the security update for MSDTC Transaction Facility (April 2009) KB952011 - Image Mastering API v2.0 (IMAPIv2.0) update package in Windows Feature Pack for Storage 1.0 KB952069 - Security update for Windows Media Format Runtime and Media Foundation KB952954 - Vulnerabilities in Microsoft Windows Image Color Management could allow remote code execution KB953024 - Rich Text Format (.rtf) files may not print correctly when using an application that uses the RichEdit control KB953028 - An application experiences an access violation and then crashes if the computer has more than four cores or more than four logical processors KB953155 - Vulnerability in Windows Internet Printing service could allow remote code execution KB953609 - "At least one of your changes was not applied successfully to the wireless configuration" error when adding a wireless network KB953761 - Some DHCP Options are not recognized when the DHCP server offer includes option 43 KB954155 - Vulnerabilities in Windows Media Runtime Could Allow Remote Code Execution (Windows Media Audio Voice Decoder) KB954193 - Jet 4.0 Database Engine cumulative hotfix package: July 2, 2008 KB954232 - On-Screen Keyboard behavior does not mimic the physical keyboard behavior in certain scenarios KB954708 - Update to add support for the serialization of complex Extensible Metadata Platform (XMP) data types in the Windows Imaging Component KB954920 - Various error messages when an application requests a result set from new SQL Server 2008 collations KB955069 - Security update for XML Core Services 3.0 KB955109 - 0xC0000005 (Access Violation) error when running an application that uses the Application Desktop Toolbar (AppBar) component KB955356 - When trying to start a computer that is connected to an IEEE1394 hard disk, it stops responding before the logon screen appears KB955417 - Protected storage (PStore) uses a lower-quality cryptographic function when the system locale is set to French (France) KB955567 - Data corruption may occur when trying to append data to a FILESTREAM varbinary (max) column in SQL Server 2008 KB955576 - TAPI-based applications stop responding, and you cannot disconnect telephone calls on a Windows XP-based telephony server KB955704 - Support for the exFAT file system format KB955830 - When you connect to a Windows XP-based computer by using a remote desktop connection, the computer may be not able to automatically enter the Sleep mode again after you log off the computer KB955988 - The Win32_Environment WMI class doesn't return the value of the PATH environment variable if it contains more than 1,024 characters KB956048 - An application that calls the Image Color Management (ICM) functions in the Icm32.dll module may crash KB956072 - Terminal server does not allow RDP connections whose encryption level is set to Low KB956391 - Cumulative security update for ActiveX (October, 2008) KB956572 - Description of the security update for Windows Service Isolation (April 2009) KB956844 - Vulnerability in DHTML Editing Component ActiveX Control Could Allow Remote Code Execution KB957931 - A Windows XP-based computer does not respond to 802.1X authentication requests for 20 minutes after a failed authentication KB958149 - Performance decreases when streaming isochronous data on a computer that has a TI IEEE1394 host controller KB958244 - System may stop responding when restarting a multicore computer KB958347 - Device that is connected through a 1394 FireWire hub is still present in system after hot unplugging it KB958644 - Vulnerability in Server service could allow remote code execution KB958690 - Vulnerabilities in Windows Kernel Could Allow Remote Code Execution KB958817 - Automatic Update window may stop responding when using a WSUS server to deploy updates KB959267 - After repeatedly docking and undocking a portable computer, unable to change state of attached network device KB959334 - Text that has the font set to Arial Black and the font style set to bold may change so that the font style is set to italic opening the document KB959439 - After uploading encrypted files to a WebDAV share, the files remain encrypted KB959465 - Write protection does not always work on SD memory cards KB960071 - An access violation occurs when using an application that calls the SQLExecDirect function of the SQL Server ODBC driver to run a long query KB960380 - A hyperlink control that is used to open a file or an e-mail message fails in an application that uses MSXML 6.0 KB960680 - Update the Slovak koruna currency symbol (Sk) to the Euro (€) the Turkish currency symbol from Yeni Türk Lirasi (YTL) to Türk Lirasi (TL) KB960859 - Vulnerability in Telnet Could Allow Remote Code Execution KB961118 - All PCL inbox printer drivers become unsigned after you install the Microsoft .NET Framework 3.5 SP1 KB961187 - If you reconnect a removable storage device to a computer running Windows XP, the OS cannot find the removable storage device KB961451 - Receive an incorrect value when you query the last-inserted identity value after you use a client-side cursor to insert data to a table that contains an identity column in an application that uses ActiveX Data Objects KB961503 - You cannot input characters as expected by using a non-English Input Method Editor in Windows Live Messenger KB961605 - Vulnerabilities in Pragmatic General Multicast (PGM) could allow denial of service KB961742 - Update for Windows XP SP3 to enable RemoteApp™ KB967048 - Error message on a Windows XP-based computer that has a USB card reader: "Stop 0x000000D1" KB967756 - Update for Windows Installer 4.5 KB968389 - Update to help strengthen authentication credentials in specific scenarios KB968537 - Vulnerabilities in Windows Kernel Could Allow Elevation of Privilege KB969059 - Vulnerability in Indexing Service Could Allow Remote Code Execution KB969084 - Remote Desktop Connection 7.0 client update for Remote Desktop Services (RDS) for Windows XP SP3 KB969262 - Windows XP stops responding when heavy I/O operations occur on an NTFS-formatted volume KB969632 - Background Intelligent Transfer Service does not start , and you receive a msg in the System log: "The Background Intelligent Transfer Service service terminated with service-specific error 2147500037 (0x80004005)" KB970254 - The modem does not work and you cannot open the "Network Connections" window after you unplug and plug in the modem several times when a PPP connection is established in Windows XP KB970430 - Update that implements Extended Protection for Authentication in the HTTP Protocol Stack (http.sys) KB970483 - Vulnerabilities in Internet Information Services (IIS) could allow elevation of privilege KB970553 - Error message when you query Win32_Product class after you install applications by using Microsoft Windows Installer (MSI) 4.5 with "Per-User" option in Windows XP: "0x80041001 - Generic failure" KB971029 - Update to restrict AutoRun entries in the AutoPlay dialog to only CD and DVD drives KB971165 - The CLIENTNAME environment variable returns the value "Console" instead of the actual client name when users first log on to a Windows XP SP3-based computer by using Remote Desktop Connection KB971234 - The Defrag.exe tool crashes when you run the Dfrgntfs.exe tool to defragment a hard disk on a computer that is running Windows XP KB971314 - All PCL inbox printer drivers become unsigned after you install the Microsoft .NET Framework 3.5 SP1 or the XPS Essentials Pack in Windows XP KB971345 - The LimitProfileSize Group Policy setting does not take effect when the size of a user profile is larger than 4 GB on a Windows XP-based client computer KB971657 - Vulnerability in Workstation Service Could Allow Elevation of Privilege KB972270 - Vulnerability in the Embedded OpenType Font Engine could allow remote code execution KB972422 - A Windows XP-based computer stops responding at the "Windows is loading your profile" screen when you connect to the computer by using an RDP connection KB972435 - Slow performance when you try to open a redirected drive on a remote computer through a Terminal Services session KB972878 - The "Guaranteed service type" Group Policy setting returns to the default value after you restart a client computer that is running Windows XP KB973502 - Credential Roaming service update for Windows XP KB973507 - Security update for the Active Template Library KB973540 - Security update for Windows Media Player 9 KB973624 - After you use a smart card to log on to a computer that is running Windows XP, Digest authentication fails KB973687 - When an application uses MSXML to process XHTML, redundant retrieval requests for well-known DTD files from the W3C Web server cause XHTML parsing to fail KB973815 - Security update for Microsoft MSWebDVD ActiveX Control KB973869 - Security update for Microsoft DHTML Editing Component ActiveX Control KB973904 - Vulnerability in WordPad and Office Text Converters Could Allow Remote Code Execution KB974112 - Vulnerability in Windows Media Player Could Allow Remote Code Execution KB974266 - Group Policy Preferences Client-Side Extension Hotfix Rollup KB974318 - Vulnerabilities in Internet Authentication Service Could Allow Remote Code Execution KB974571 - Vulnerabilities in Windows CryptoAPI Could Allow Spoofing KB975025 - Security update for Audio Compression Manager: October 13, 2009 KB975467 - Vulnerability in Local Security Authority Subsystem Service Could Allow Denial of Service KB975558 - Vulnerability in MPEG-4 Codec Could Allow Remote Code Execution KB975560 - Vulnerability in Microsoft DirectShow Could Allow Remote Code Execution KB975561 - Vulnerability in Windows Movie Maker Could Allow Remote Code Execution KB975713 - Vulnerability in Windows Shell Handler could allow remote code execution KB975791 - Update to Notepad.exe in Windows XP KB976002 - Browser Choice update is available in the European Economic Area KB976323 - Vulnerabilities in Microsoft Exchange and Windows SMTP Service Could Allow Denial of Service KB977816 - Vulnerability in Microsoft MPEG Layer-3 Codecs Could Allow Remote Code Execution KB977914 - Vulnerability in Microsoft AVI filter Could Allow Remote Code Execution KB978338 - Vulnerabilities in Windows ISATAP Component Could Allow Spoofing KB978542 - Vulnerability in Outlook Express and Windows Mail Could Allow Remote Code Execution KB978706 - Vulnerability in Microsoft Paint could allow remote code execution KB978695 - Security Update for Windows Media Format Runtime 9 for Windows XP SP3 KB978835 - Service cannot access the \?? namespace in Windows XP KB979099 - Rights Management Services Client with Service Pack 2 for Windows XP KB979309 - Vulnerabilities in Windows Authenticode Verification that could allow remote code execution KB979482 - Vulnerabilities in Media Decompression Could Allow Remote Code Execution KB979687 - Vulnerability in COM Validation in Windows Shell and WordPad Could Allow Remote Code Execution KB981073 - FTP clients may not connect correctly to an FTP site that is hosted in IIS 5.0 or IIS 5.1 KB981997 - Vulnerability in Windows Movie Maker Could Allow Remote Code Execution KB982132 - Vulnerability in the Embedded OpenType Font Engine Could Allow Remote Code Execution KB982316 - Permissions Update for Windows XP Telephony KB982665 - Vulnerability in Cinepak Codec Could Allow Remote Code Execution KB983234 - Update visual Basic Virtual Machine (MSVBVM60.DLL) KB2115168 - Vulnerability in Microsoft MPEG Layer-3 Codecs Could Allow Remote Code Execution KB2124261 - Vulnerabilities in Microsoft Internet Information Services (IIS) ASP Could Allow Remote Code Execution KB2229593 - Vulnerability in Help and Support Center Could Allow Remote Code Execution KB2264107 - This update helps protect against DLL preloading vulnerabilities in software applications on the Windows platform KB2270406 - "0x000000D1" Stop error message when you try to refresh a webpage in Internet Explorer on a computer that is running Windows XP SP3 KB2290570 - Vulnerabilities in Microsoft Internet Information Services (IIS) Authentication Could Allow Remote Code Execution KB2296011 - Vulnerability in Windows Common Control Library Could Allow Remote Code Execution KB2345886 - Update that implements Extended Protection for Authentication in the Server service KB2347290 - Vulnerability in Print Spooler Service Could Allow Remote Code Execution KB2378111 - Vulnerability in Windows Media Player Could Allow Remote Code Execution KB2387149 - Vulnerability in Microsoft Foundation Classes Could Allow Remote Code Execution KB2393802 - Vulnerability in Windows Kernel could allow elevation of privilege KB2419632 - Vulnerabilities in Microsoft Data Access Components Could Allow Remote Code Execution KB2423089 - Vulnerability in Windows Address Book Could Allow Remote Code Execution KB2443105 - Insecure Library Loading in Internet Connection Signup Wizard Could Allow Remote Code Execution KB2454533 - Description of a shared folder that is mapped to a network drive is not displayed on a Windows XP SP3-based computer KB2478960 - Vulnerability in Local Security Authority Subsystem Service Could Allow Local Elevation of Privilege KB2478971 - Vulnerabilities in Kerberos Could Allow Elevation of Privilege KB2479943 - Vulnerabilities in Windows Media Could Allow Remote Code Execution KB2483185 - Vulnerability in Windows Shell Graphics Processing Could Allow Remote Code Execution KB2485663 - Vulnerability in WordPad Text Converters Could Allow Remote Code Execution KB2491683 - Vulnerability in Windows Faxcover Editor Component Could Allow Remote Code Execution KB2492386 - Application Compatibility Update for Windows XP KB2498072 - Vulnerability in SCSI driver KB2508429 - Vulnerability in SMB Server Could Allow Remote Code Execution KB2509553 - Vulnerability in DNS Resolution Could Allow Remote Code Execution KB2510581 - Vulnerability in JScript and VBScript v5.7 Scripting Engines Could Allow Remote Code Execution KB2524375 - Fraudulent Digital Certificates could allow spoofing KB2535512 - Vulnerabilities in Distributed File System Could Allow Remote Code Execution KB2536276 - Vulnerabilities in SMB Client could allow remote code execution KB2544893 - Vulnerability in MHTML Could Allow Information Disclosure KB2564958 - Security Update for Active Accessibility in Windows KB2566454 - Vulnerability in Remote Access Service NDISTAPI Driver Could Allow Elevation of Privilege KB2570947 - Vulnerability in Windows Components Could Allow Remote Code Execution KB2584146 - Vulnerability in Microsoft Windows Could Allow Remote Code Execution KB2584577 - Vulnerability in Windows MFC Components Could Allow Remote Code Execution KB2585542 - Vulnerability in SSL/TLS Could Allow Information Disclosure KB2592799 - Vulnerability in Ancillary Function Driver Could Allow Elevation of Privilege KB2598479 - Vulnerabilities in Windows Media Could Allow Remote Code Execution KB2603381 - Vulnerability in Windows Object Packager Could Allow Remote Code Execution KB2607712 - Fraudulent Digital Certificates could allow spoofing KB2619339 - Vulnerability in Windows Media Could Allow Remote Code Execution KB2620712 - Vulnerability in Windows Client/Server Runtime Subsystem Could Allow Elevation of Privilege KB2629462 - Computer can become unstable or crash KB2631813 - Vulnerabilities in Windows Media Could Allow Remote Code Execution KB2642020 - Print jobs initiated in a Windows XP point and print environment may have missing characters KB2646524 - Vulnerability in Windows Client/Server Run-time Subsystem Could Allow Elevation of Privilege KB2653956 - Vulnerability in Windows Could Allow Remote Code Execution KB2661637 - Vulnerability in Indeo Codec Could Allow Remote Code Execution KB2686509 - Security Update Enables Fixes to a Problem that can Occur with the Loading of Keyboard Layout Files KB2691442 - Vulnerability in Windows Shell Could Allow Remote Code Execution KB2698365 - Vulnerability in Microsoft Data Access Components Could Allow Remote Code Execution KB2705219 - Vulnerabilities in Windows Networking Components Could Allow Remote Code Execution KB2712808 - Vulnerabilities in Windows Networking Components Could Allow Remote Code Execution KB2723135 - Vulnerability in Remote Desktop Could Allow Remote Code Execution KB2727528 - Vulnerabilities in Windows Shell Could Allow Remote Code Execution KB2749655 - Update to resolve issues in Windows KB2757638 - Vulnerabilities in Microsoft XML Core Services 6.0 Could Allow Remote Code Execution KB2758694 - Vulnerabilities in Microsoft XML Core Services 4.0 Could Allow Remote Code Execution KB2758857 - Vulnerability in Windows File Handling Component Could Allow Remote Code Execution KB2770660 - Vulnerability in DirectPlay Could Allow Remote Code Execution KB2780091 - Vulnerability in Media Decompression Could Allow Remote Code Execution KB2793313 - Security guidance for NTLMv1 and LM network authentication KB2797052 - Vulnerability in Vector Markup Language Could Allow Remote Code Execution KB2802968 - Vulnerability in OLE Automation Could Allow Remote Code Execution KB2803821 - Vulnerability in Windows Media Format Runtime Could Allow Remote Code Execution KB2807986 - Vulnerabilities in Kernel-Mode Drivers Could Allow Elevation Of Privilege KB2808679 - Unauthorized Digital Certificates Could Allow Spoofing KB2813347 - Vulnerability in Remote Desktop Client Could Allow Remote Code Execution KB2820917 - Vulnerability in Windows Client/Server Run-time Subsystem (CSRSS) Could Allow Elevation of Privilege KB2828030 - USB audio devices stop streaming audio on a computer that is running Windows XP SP3 KB2832214 - Vulnerability in TLS Could Allow Information Disclosure KB2834886 - Vulnerability in GDI+ Could Allow Remote Code Execution KB2836198 - Update that removes the Cryptographic Service Provider (CSP) signature check on Windows XP SP3 KB2847311 - Vulnerability in the OpenType Compact Font Format (CFF) Driver Could Allow Remote Code Execution KB2850869 - Vulnerability in Unicode Scripts Processor Could Allow Remote Code Execution KB2859537 - Vulnerabilities in Windows Kernel Could Allow Elevation Of Privilege kb2862152 - Vulnerability in DirectAccess could allow security feature bypass KB2862330 - Vulnerabilities in Windows Kernel-Mode Drivers Could Allow Remote Code Execution KB2862335 - Vulnerabilities in Windows Kernel-Mode Drivers Could Allow Remote Code Execution KB2864063 - Vulnerability in Windows Theme File Could Allow Remote Code Execution KB2868038 - Vulnerabilities in Windows Kernel-Mode Drivers Could Allow Remote Code Execution KB2868626 - Vulnerability in XML digital signatures could allow denial of service KB2876217 - Vulnerability in OLE Could Allow Remote Code Execution KB2876331 - Vulnerability in Windows Graphics Device Interface could allow remote code execution KB2878379 - When you use the Windows Key+L keyboard sequence to lock a Windows XP-based computer shortly after you log on to the system, the operating system may be automatically unlocked and the desktop can be accessed KB2884256 - Vulnerabilities in Windows Kernel-Mode Drivers Could Allow Remote Code Execution KB2892075 - Vulnerability in Microsoft Scripting Runtime Object Library Could Allow Remote Code Execution KB2892734 - Windows Firewall service crashes when multiple FTP operations are running KB2893294 - Vulnerability in Windows Could Allow Remote Code Execution KB2898715 - Vulnerability in LRPC Client Could Allow Elevation of Privilege KB2900986 - Cumulative security update for ActiveX Kill Bits for Windows XP KB2909212 - Vulnerability in VBScript Scripting Engine Could Allow Remote Code Execution KB2914368 - Vulnerabilities in Windows Kernel-Mode Drivers Could Allow Remote Code Execution KB2916036 - Vulnerability in Microsoft XML Core Services Could Allow Information Disclosure KB2922229 - Vulnerability in Windows File Handling Component Could Allow Remote Code Execution KB2929729 - Update for Registry Configuration APIs KB2929961 - Vulnerability in Microsoft DirectShow Could Allow Remote Code Execution KB2930275 - Vulnerabilities in Windows Kernel-Mode Drivers Could Allow Elevation of Privilege KB2936068 - Cumulative Security Update for Internet Explorer 6 KB2964358 - Internet Explorer 6 Security Fix KB3112148 - Cumulative Time Zone Update SA3123040 - Windows Revoked Roots Certificates Update (8.0.2195.1512) Other Updates Adobe Flash Player 21.0.0.213 ActiveX Control Code65536 FontReg 2.1.3 Code65536 ResetWMI 1.3.3 Microsoft CAPICOM 2.1.0.2 Microsoft European Union Expansion Font Update 1.2 Microsoft Qfecheck 6.2.29.0 Microsoft Windows Update Web Control 7.6.7600.257 Microsoft Update Catalog Web Control 7.4.7057.249 Microsoft Update Web Control 7.6.7600.257 Microsoft Visual Basic Runtimes 1,2,3,4 Microsoft Visual C Runtimes 1,7 MSXML 4.0 SP3 4.30.2114.0 Miscellaneous Tweaks KB873374 - Microsoft GDI+ Detection Tool Registry Entry KB890830 - Microsoft Malicious Software Removal Tool v5.36 KB905474 - Windows Genuine Advantage Notifications (Suppressed MU Nag to Install) KB2934207 - Windows XP End Of Service Notifications (Suppressed MU Nag to Install) change log: 20160510 updated Microsoft Malicious Software Removal Tool v5.36 updated Microsoft Root Certificates Update (41.0.2195.1604) Edited May 11, 2016 by user_hidden laolabem, Reborns, polililil and 5 others 8 Quote
user_hidden Posted November 11, 2009 Author Posted November 11, 2009 Welcome to WinCert u_halways been here but finally figured the users here should have access if they haven'talready known about this pack from over at RyanVM forums.btw, thanks as always for your help :icon_cool: Quote
ccl0 Posted November 11, 2009 Posted November 11, 2009 would you consider putting all that info in a spoiler box? technically not a spoiler but its the only way i know that puts all the info into a drop down box to compress the original post. (without spaces) [ spoiler ] tag to the start and [ / spoiler ] at the end of the textwill make it look like this tada! Quote
Mr_Smartepants Posted November 11, 2009 Posted November 11, 2009 WooHoo! Thanks U_H!Will test right away. Quote
user_hidden Posted November 11, 2009 Author Posted November 11, 2009 would you consider putting all that info in a spoiler box? technically not a spoiler but its the only way i know that puts all the info into a drop down box to compress the original post. (without spaces) [ spoiler ] tag to the start and [ / spoiler ] at the end of the textThanks for the heads up.Updated the formating on the first post. Quote
Mr_Smartepants Posted November 11, 2009 Posted November 11, 2009 Just installed on real hardware. No issues so far. Great job! Quote
user_hidden Posted November 11, 2009 Author Posted November 11, 2009 Just installed on real hardware. No issues so far. Great job!some over at RyanVM reported a WPA error at startup but i could not reproduce it.i did however track that it was happenning to vlk users, while i build and test on oem which works fine.i have since updated the version to 20091111 with a change that i hope will fix the issue. Quote
bjfrog Posted November 12, 2009 Posted November 12, 2009 i got a download issue,i have tried twice end at 99.99% each timeCould you post a mirror to ifile.it ?look forward to trying,thanks. Quote
user_hidden Posted November 12, 2009 Author Posted November 12, 2009 (edited) i got a download issue,i have tried twice end at 99.99% each timeCould you post a mirror to ifile.it ?look forward to trying,thanks.EDIT: link removed old version. Edited November 14, 2009 by user_hidden Nr717 1 Quote
Mr_Smartepants Posted November 13, 2009 Posted November 13, 2009 Just installed the updated version on Pro vlk with zero problems. Well done! Quote
newsposter Posted November 13, 2009 Posted November 13, 2009 The updated version does appear to be working, which is the 'definitive' version now or are there two (vlk-supporting and non-vlk) or ??? Quote
Mr_Smartepants Posted November 13, 2009 Posted November 13, 2009 The new one works on both VLK and OEM fine. But there's a typo in the entries.ini (reported already over at Ryan's).d1,xpprof.inf should be d1,xppro.infApparently it only breaks winnt.exe and winnt32.exe setups. Quote
user_hidden Posted November 13, 2009 Author Posted November 13, 2009 The new one works on both VLK and OEM fine. But there's a typo in the entries.ini (reported already over at Ryan's).d1,xpprof.inf should be d1,xppro.infApparently it only breaks winnt.exe and winnt32.exe setups.first post was silently updated to reflect the fix so the winnt/winnt32 installs are fine. Quote
Guest Posted November 14, 2009 Posted November 14, 2009 just if any one wants a mirrorRegards DM Quote
user_hidden Posted November 26, 2009 Author Posted November 26, 2009 updated 1.14 20091125 .... Quote
Guest Posted November 26, 2009 Posted November 26, 2009 if any one doesn't like Rapidshare here is a mirror Quote
Guest Posted November 26, 2009 Posted November 26, 2009 (edited) user_hidden while i was doing the cd of the month i get this in the windows update KB931125 - Microsoft Root Certificates Update (November 2009) the one in your pack is September shouldn't this one be updated ?here is the link and is it only replacing the old file with the new one or there is another thing to change? Edited November 26, 2009 by DaRk MaDnEsS Quote
George King Posted November 26, 2009 Posted November 26, 2009 user_hidden while i was doing the cd of the month i get this in the windows update KB931125 - Microsoft Root Certificates Update (November 2009) the one in your pack is September shouldn't this one be updated ?here is the link and is it only replacing the old file with the new one or there is another thing to change?Only replacing old file with new Quote
soporific Posted November 26, 2009 Posted November 26, 2009 first post was silently updated to reflect the fix so the winnt/winnt32 installs are fine.Thanks for this fix, i was nearly about to revert to using another update pack ... the missing file was named as "xpprof.inf" and it looked important! ... glad to see what the prob was. Cheers mate. Quote
user_hidden Posted November 27, 2009 Author Posted November 27, 2009 user_hidden while i was doing the cd of the month i get this in the windows update KB931125 - Microsoft Root Certificates Update (November 2009) the one in your pack is September shouldn't this one be updated ?here is the link and is it only replacing the old file with the new one or there is another thing to change?I didn't get the updated rootsupd.exe until late yesterday which was after i released the pack.It is in my local 1.15b1 and will be released for the upcomming patch tuesday (December 8, 2009) update pack.If you would like to add it to the pack just unzip the update pack and replace the rootsupd.exe and repack.It is just that one file whoth no other changes. Quote
soporific Posted December 9, 2009 Posted December 9, 2009 updated 1.1.5 20091208 ....luv your work dude, cheers Quote
