Vista RocketDock v1.3.5
Info: Modified RocketDock with Vista Icons.
Optional: Addon is also customizable. All you have to do is to Install the AddOn manually and set RocketDock with your prefered settings and native language then simply copy settings.ini file from the RocketDock folder and repack it into the addon.
MD5: 72C26E02C43067E5473799957660DE33
Website: http://www.punksoftware.com/
Changelog:
09-03-07
- Updated v1.3.5
08-22-07
- Updated program v1.3.3
- Added more Vista Icons
  • Replies 78
  • 4 weeks later...
i used this on vista, and it looks pretty sweet.. now only if you can make 1 full file that will replace all the existing ones then when an update comes in i wont have to reintergrate it.. hehe
Nice work Rick
scOOt3r!
Wow, after using this all I had to do was track down 3 more png's for my favorite games and I was done. That's nowhere near the hassle I had getting rocketdock to look nice enough after my last fresh install. Thank you.
You can modify it and add your PNG files into the addon also... Just add them to [sourceDisksFiles] and to [icon.Files] Example:
[sourceDisksFiles]
MyNewFile.png=1
My2ndNewFile.png=1
[icon.Files]
Then Add them to RocktDoc.cab and repack the addon... While youre at it you can overwrite the settings.ini file with your current saved settings and you will have those also
  • 4 weeks later...
... repack the addon...
hi rick! how do you repack an addon? which tool would be best to use? i love the mac look :) works like charm ... works well together with sidebar addon too ... thanks! :P
Well If you have Kels UberPack installed you can use CabTool in the SendTo menu... Just Right Click on the Extracted Folder and Send To CabTool, it will then create a .CAB file with the same name as the folder.
I on the other hand use TUGZip to make my .CAB files
Manual Install Instructions
- Unzip VistaRocketDock_Addon_v1.3.1.rar to a SubFolder
- Right click on RocktDoc.inf and choose Install (you will get an error)
- Browse to the location of RocktDoc.cab, hit Select then OK
hi rick! would there be a way like gadget settings addon creation in sidebar for rocketdock where icons can be customized & preset for integration so that its set upon hitting the desktop after install? thanks! ;)
Not really... I need the names of the icons.png files for the addon builder... Its not that hard to add new icons to the addon (add the icons files to the .CAB archive and edit [sourceDisksFiles] and to [icon.Files] sections) and just add your settings.ini also so your icon settings and layout are added
rick.. thx!! ps i changed my docs, my vids, and my music to real vista icons... i got em if u want to use them, email me kmahajaniAThotmailDOTcom
yesac7.gif but I might not update the addon. I might wait till the next version or RocketDock comes out
