Posted March 14, 200718 yr <- Diamond Windows Sidebar StyleWindowBlinds 6 Enhanced (6.02 (build 43x86))Info: Includes Diamond WB skin only (also includes Diamond skin for Windows Sidebar Styler) (Updated January 20-2008)MD5: D58066321CA1E0899CA01FAD285245B1Size: 3.92 MBWARNING: This Program is NOT FREE and my AddOn does NOT contain any cracked files, (don't even try to crack it because it wont work) you register the program yourself on 1st run (also any discussion or questions on on how to crack it will result in an immediate suspension from WinCert)Changelog:1/20/2008- Updated v6.02 build 4310/09/2007- Updated v6.01 build 4010/09/2007- Updated v 6.0 build 36- Added Diamond Windows Sidebar Style for WSS- Removed dummy sig6.bin (you register it on login)10/07/2007- Updated v 6.0 build 33Special Thanks:JurgenDoe
March 15, 200718 yr I remember when i used windows Blind on a windows98 Os.*Does this program Load at windows Startup/Service ?*Does it includes Vista Side Bars , Dock Bar & Vista Mycomputer,My Documents Icons Etc ?*Is it working as a trail version or full version ?[i am not asking about Cracking...]
March 15, 200718 yr Author Does not load on startupNo sidebar and Icons (only the Toolbar Icons that come with the themes)Its Enhanced version not trial...
March 17, 200718 yr You Rocks Man....!!Thanks for this Addon...Why you are providing two different versions together...?btw.The above Screenshot included "VistaSidebars,Dockbars etc" with WindowsBlind,What do you think how much RAM resources all of them needed...?Do you feel any slowdown after patching all the Graphics Stuff at your desktop ?But I always like whatever you did Edited March 17, 200718 yr by khan
September 2, 200717 yr ı remove all of this skin files and remove entries from WB55enh.inf too.but this is creating a empty moonflower file.where ı made mistake.please help me
September 4, 200717 yr this theme requires lspatch so this is not good :thumbsdown_anim: .please replace this theme with this one.this is best vista theme. :thumb_yello: :thumb_yello: http://www.deviantart.com/download/4242288...sta_by_6205.zip
September 5, 200717 yr Agree with you, fasak ! That's the best Vista theme i ever seen. one question for Rick, is the theme ran by default, after reboot ?
September 5, 200717 yr Author No you have to start WB after first boot, but yes its the only theme installed.I'm very busy ATM with V'ISO (a cmd Vista icon slipstreamer for XP) but when I have time I will update this.
September 5, 200717 yr No you have to start WB after first boot, but yes its the only theme installed.I'm very busy ATM with V'ISO (a cmd Vista icon slipstreamer for XP) but when I have time I will update this.Now you can make it run the theme silently . (see on RyanVM.net :thumb_yello: ).
September 6, 200717 yr Author Updated...9/06/2007- Changed skin to Windows Vista by 6205- WB now loads on 1st boot- sig.bin file attributes set to "Read Only" and "Hidden"
September 6, 200717 yr Author Redownload I had forgotten to chage the link... You downloaded the old one this is the name of the new one:Ricks_WindowBlinds5.50_Enhanced_AddOn_70906.rarVerify using the MD5 hash
September 6, 200717 yr ı tried this on my xp this is not working rick.I.help me please Edited September 6, 200717 yr by fasak
September 6, 200717 yr Aaaaaaaand just HOW did you try this?Which method of integration did you use?nLiteorRVM Integrator?Are the files in your programs folder?
September 6, 200717 yr ı done it now but ı have a different question which file is theme font files.can ı use default xp fonts.
