GDism ELDI
GDism is a graphical user interface (GUI) program for control the Dism (Deployment Image Servicing and Management tool) present in Windows 7 and Windows 8, you can mount/unmount images *.wim, *.vhd, edit it, commit changes, add/remove updates, add/remove drivers, upgrade to higher edition, make *.iso image, convert packages *.msu to *.cab, etc. Now multilingual: english, spanish, french, italian. New version with support to Windows 8!!!
Dism.exe /?
Version: 6.2.8250.0
DISM.exe [dism_options] {Imaging_command} []
DISM.exe {/Image: | /Online} [dism_options]
{servicing_command} []
DESCRIPTION:
DISM enumerates, installs, uninstalls, configures, and updates features
and packages in Windows images. The commands that are available depend
on the image being serviced and whether the image is offline or running.
GENERIC IMAGING COMMANDS:
/Get-MountedImageInfo - Displays information about mounted WIM and VHD
images.
/Get-ImageInfo - Displays information about images in a WIM or VHD
file.
/Commit-Image - Saves changes to a mounted WIM or VHD image.
/Unmount-Image - Unmounts a mounted WIM or VHD image.
/Mount-Image - Mounts an image from a WIM or VHD file.
/Remount-Image - Recovers an orphaned image mount directory.
/Cleanup-Mountpoints - Deletes resources associated with corrupted
mounted images.
WIM COMMANDS:
/List-Image - Displays a list of the files and folders in a
specified image.
/Delete-Image - Deletes the specified volume image from a WIM file
that has multiple volume images.
/Split-Image - Splits an existing .wim file into multiple read-on
split WIM (SWM) files.
/Export-Image - Exports a copy of the specified image to another
file.
/Append-Image - Adds another image to a WIM file.
/Capture-Image - Captures an image of a drive into a new WIM file.
Captured directories include all subfolders and da
/Apply-Image - Applies an image.
/Get-MountedWimInfo - Displays information about mounted WIM images.
/Get-WimInfo - Displays information about images in a WIM file.
/Commit-Wim - Saves changes to a mounted WIM image.
/Unmount-Wim - Unmounts a mounted WIM image.
/Mount-Wim - Mounts an image from a WIM file.
/Remount-Wim - Recovers an orphaned WIM mount directory.
/Cleanup-Wim - Deletes resources associated with mounted WIM
images that are corrupted.
IMAGE SPECIFICATIONS:
/Online - Targets the running operating system.
/Image - Specifies the path to the root directory of an
offline Windows image.
DISM OPTIONS:
/English - Displays command line output in English.
/Format - Specifies the report output format.
/WinDir - Specifies the path to the Windows directory.
/SysDriveDir - Specifies the path to the system-loader file named
BootMgr.
/LogPath - Specifies the logfile path.
/LogLevel - Specifies the output level shown in the log (1-4).
/NoRestart - Suppresses automatic reboots and reboot prompts.
/Quiet - Suppresses all output except for error messages.
/ScratchDir - Specifies the path to a scratch directory.
Actual Version: 3.1
Link: GDism Folder
Password: @ByELDI
Demo:
New Version 3.0 GDism .NET ELDI
- Fixed Bugs in Editions Page.
- Add AutoFill TargetEditions.
- Add AutoFill Features in Packages Page.
- Add AutoFill Packages in Packages Page.
- Add Hungarian Language.
- Fix Scripts Errors with the website page.
- Administrator Privilegies.
- Updated Dism.exe on Portable.
v3.1
- Fixed crash for MS Sans Serif font
Edited by heldigard
  • Replies 52
  • Views 45.9k
  • abbodi1406
    abbodi1406
    same result.. did not work. i managed to run the java version thanks
  • abbodi1406
    abbodi1406
    Hi again appreciate your hard working I managed to run the .NET version successfully after i installed Microsoft Office 2010 Pro Plus i do not know how.. but that what happend maybe because the Off
  • Arkymedes
    Arkymedes
    Hello, I would like to add my contribution with the Brazilian Portuguese translation for your program. Cheers, Arkymedes WinAppSettings.pt-BR.txt
Updated to v5.2
Link is down.
Access to the webpage was denied
You are not authorized to access the webpage athttp://download643.mediafire.com/783gudwteefg/f17u0dapk0xk70b/GDism+ELDI+v5.2.rar. You may need to sign in.HTTP Error 403 (Forbidden): The server refused to fulfill the request.
Edited by Mr_Smartepants
You right, i will post here the text the people translate for me, and i will put in the code, any language that you want add translate and post here,
botonMountEN.text=Mount-Wim
botonUnmountEN.text=Unmount-Wim
botonWimEN.text=File .wim
botonMountDirEN.text=MountDir
labelIndexEN.text=Index Version
botonCleanUpEN.text=CleanUp-Wim
showExplorarWimEN.Action.text=
showExplorarWimEN.Action.shortDescription=Browse an image file (*.wim)
showExplorarWimTarjetEN.Action.text=
showExplorarWimTarjetEN.Action.shortDescription=Browse an image target (*.wim)
showExplorarDirEN.Action.shortDescription=Browse an empty folder for mount image
showExplorarDirEN.Action.text=
MountWimEN.Action.text=
MountWimEN.Action.shortDescription=Mount image
jLabel1EN.text=Index Version
radioGrabarEN.text=Commit Changes
radioLecturaEN.text=Read Only & Discard
UnMountWimEN.Action.text=
UnMountWimEN.Action.shortDescription=Unmount image on windir
botonCleanUp.TabConstraints.tabTitle=Information Wim
botonWimInfoEN.text=Get-WimInfo
botonMountedInfoEN.text=Get-MountedWimInfo
WimInfoEN.Action.text=
WimInfoEN.Action.shortDescription=Get information of a wim image
checkIndexEN.text=Index Version
MountedInfoEN.Action.text=
MountedInfoEN.Action.shortDescription=Show images mounted
CleanUpEN.Action.text=
CleanUpEN.Action.shortDescription=Cleanup images broken
botonGetPackagesEN.text=Get-Packages
botonAddPackageEN.text=Add-Package
botonRemovePackageEN.text=Remove-Package
GetPackagesEN.Action.shortDescription=Show the packages from image on list o table
GetPackagesEN.Action.text=
AddPackageEN.Action.text=
AddPackageEN.Action.shortDescription=Browse Packages msu, cab or folder with multiples files
ExaminarPackagesEN.Action.shortDescription=
ExaminarPackagesEN.Action.text=
botonExaminarPackagesEN.text=...
RemovePackageEN.Action.text=
RemovePackageEN.Action.shortDescription=Write package name for remove
botonCommitWimEN.text=Commit-Wim
CommitWimEN.Action.shortDescription=Save changes of mounted image
CommitWimEN.Action.text=
botonClearEN.text=Clear
botonCopyEN.text=Copy
ClearEN.Action.shortDescription=Clear Text Area
ClearEN.Action.text=
CopyEN.Action.text=
CopyEN.Action.shortDescription=Copy Content to Clipboard
botonGetDriversEN.text=Get-Drviers
checkTablaDriversEN.text=Table
checkTablaPackagesEN.text=Table
botonExaminarPackages2EN.text=...
botonExaminarPackages3EN.text=...
botonGetDriverInfoEN.text=Get-DriverInfo
botonRemoveDriverEN.text=Remove-Driver
botonAddDriverEN.text=Add-Driver
checkAllDriversEN.text=All
ExaminarDriverEN.Action.text=
ExaminarDriverEN.Action.shortDescription=Browse Driver .inf to show info or remove
ExaminarDriversEN.Action.text=
ExaminarDriversEN.Action.shortDescription=Browse driver inf or folder
GetDriversEN.Action.text=
GetDriversEN.Action.shortDescription=Show drivers from image
GetDriverInfoEN.Action.text=
GetDriverInfoEN.Action.shortDescription=Show Info Driver
RemoveDriverEN.Action.text=
RemoveDriverEN.Action.shortDescription=Remove a driver from image
AddDriverEN.Action.shortDescription=Add drivers to image
AddDriverEN.Action.text=
checkRecurseEN.text=Recurse
checkForceUnsignedEN.text=Force Unsigned
botonLenguajeEN.text=Espanol
RestartExplorerEN.Action.text=
RestartExplorerEN.Action.shortDescription=Restart Windows Explorer
botonCloseExplorerEN.text=Close Explorer
botonOpenExplorerEN.text=Open Explorer
CloseExplorerEN.Action.shortDescription=Close Windows Explorer
CloseExplorerEN.Action.text=
OpenExplorerEN.Action.text=
OpenExplorerEN.Action.shortDescription=Open Windows Explorer
ChangeLanguageEN.Action.text=
ChangeLanguageEN.Action.shortDescription=Cambiar Idioma
botonBorrarProcesoEN.text=Remove
BorrarProcesoEN.Action.shortDescription=Remove a process from list
BorrarProcesoEN.Action.text=
EjecutandoProcesoEN.text=Running now
ProcesoTerminadoEN.text=Process sucessfull
ProcesoPendienteEN.text=Process on waiting list
ProcesoErrorEN.text=Error at the last process
ProcesoClearEN.text=All process on waiting list erased
botonCancelEN.text=Cancel
CancelProcessEN.Action.shortDescription=Cancel Process
CancelProcessEN.Action.text=
labelISOEN.text=Label
botonFolderISOEN.text=Source Folder
botonArchivoISOEN.text=Target .iso
botonCrearISOEN.text=Make Iso.cmd
CrearISOEN.Action.shortDescription=Make Iso.cmd Script
CrearISOEN.Action.text=
FolderISOEN.Action.text=
FolderISOEN.Action.shortDescription=Browse source folder
ArchivoISOEN.Action.text=
ArchivoISOEN.Action.shortDescription=Browse tarjet .iso
ISOErrorEN.text=Error making the iso image
textAreaPane.contentType=text/rtf
ErrorNoDoneEN.text=\nWait until the process list finish and try again @ByELDI\n
ErrorNoDism1EN.text=Dism.exe no found
ErrorNoDism2EN.text=Write the full path of Dism.exe
ErrorNoOscdimg1EN.text=Oscdimg.exe no found
ErrorNoOscdimg2EN.text=Write the full path of Oscdimg.exe
ErrorNoImagex1EN.text=Imagex.exe no found
ErrorNoImagex2EN.text=Write the full path of Imagex.exe
ErrorNoExpand1EN.text=Expand.exe no found
ErrorNoExpand2EN.text=Write the full path of Expand.exe
IsoCompleteEN.text=The program must be closed to finish making iso.
exitMenuItem.text=Salir
labelTime.text=0:0:0
botonGetFeaturesEN.text=Get-Features
botonGetAppsEN.text=Get-Apps
GetAppsEN.Action.text=
GetAppsEN.Action.shortDescription=Show information about aplications MSI
botonEnableFeatureEN.text=Enable-Feature
botonDisableFeatureEN.text=Disable-Feature
GetFeaturesEN.Action.text=
GetFeaturesEN.Action.shortDescription=Show the features
EnableFeatureEN.Action.text=
EnableFeatureEN.Action.shortDescription=Enable a feature
DisableFeatureEN.Action.shortDescription=Disable a feature
DisableFeatureEN.Action.text=
radioImagePackagesEN.text=Image
radioOnlinePackagesEN.text=OnLine
botonGetAppPatchesEN.text=Get-AppPatches
checkTablaAppsEN.text=Table
GetAppPatchesEN.Action.text=
GetAppPatchesEN.Action.shortDescription=Show information about MSP's
checkProductKeyEN.text=ProductKey
GetCurrentEditionEN.Action.text=
GetCurrentEditionEN.Action.shortDescription=Show Edition of the image
GetTarjetEditionsEN.Action.text=
GetTarjetEditionsEN.Action.shortDescription=Show Editions it will upgrade
SetEdition.ActionEN.text=
SetEdition.ActionEN.shortDescription=Upgrade the Windows image
SetProductKeyEN.Action.text=
SetProductKeyEN.Action.shortDescription=Insert product key
radioImageEditionEN.text=Image
radioOnlineEditionEN.text=OnLine
botonSetProductKeyEN.text=Set-ProductKey
botonSetEditionEN.text=Set-Edition
botonGetCurrentEditionEN.text=Get-CurrentEdition
botonGetTargetEditionsEN.text=Get-TargetEditions
BotonImageEN.Action.text=
BotonImageEN.Action.shortDescription=Image OffLine
BotonOnlineEN.Action.text=
BotonOnlineEN.Action.shortDescription=Current System
botonConvertirEN.text=Convert
botonDestinoCabEN.text=Target
botonMsuEN.text=Files *.msu
ExaminarCabEN.Action.shortDescription=Target Folder
ExaminarCabEN.Action.text=
ConvertCabEN.Action.text=
ConvertCabEN.Action.shortDescription=Convert msut to cab
ExaminarMsuEN.Action.text=
ExaminarMsuEN.Action.shortDescription=Browse msu packages
botonGetLanguagesEN.text=Get-Intl
GetLanguagesEN.Action.text=
GetLanguagesEN.Action.shortDescription=Show languages at image
botonGenLangIniEN.text=Gen-LangIni
GenLangIniEN.Action.shortDescription=Generate new file lang.ini
GenLangIniEN.Action.text=
radioImageLanguageEN.text=Image
radioOnlineLanguageEN.text=OnLine
labelDescriptionEN.text=Description
labelNameEN.text=Name
botonExportEN.text=Export
botonChangeInfoEN.text=Change Name
botonWimTargetEN.text=Target .wim
IsoCmdEN.Action.text=
IsoCmdEN.Action.shortDescription=Run Script Iso.cmd
ChangeNameEN.Action.text=
ChangeNameEN.Action.shortDescription=Change Name and Description
ExportEN.Action.text=
ExportEN.Action.shortDescription=Export a image
labelCompressEN.text=Compress
checkBoxErrorListEN.text=Erase List on Error
botonFolderCopyEN.text=Source Folder
botonCopyMountEN.text=Copy
ExaminarFolderCopyEN.Action.text=
ExaminarFolderCopyEN.Action.shortDescription=Browse source folder
botonDeleteFolderEN.text=Delete
CopyMountEN.Action.shortDescription=Copy folder to MountDir
CopyMountEN.Action.text=
DelFolderMountEN.Action.shortDescription=Delete folder in MountDir
DelFolderMountEN.Action.text=
labelTargetFolderEN.text=Target in MountDir
botonIsoCmdEN.text=Iso.cmd
botonCabEN.text=Files *.cab
botonTargetCabEN.text=Target
botonUnzipCabEN.text=Unzip Cab
BrowseCabEN.Action.shortDescription=Browse files *.cab
BrowseCabEN.Action.text=
BrowseTargetCabEN.Action.shortDescription=Browse target folder
BrowseTargetCabEN.Action.text=
UnzipCab.ActionEN.shortDescription=Unzip cab
UnzipCab.ActionEN.text=
checkIgnoreEN.text=IgnoreCheck
showConfigEN.Action.shortDescription=Setting Dism Imagex Oscdimg
showConfigEN.Action.text=
botonCaptureEN.text=Capture
checkVerifyEN.text=Verify
CaptureEN.Action.text=
CaptureEN.Action.shortDescription=Capture a drive in *.wim
MsuCabEN.Action.text=
MsuCabEN.Action.shortDescription=Run script MsuCab.cmd
ExaminarVhdEN.Action.text=
ExaminarVhdEN.Action.shortDescription=Browse file target *.vhd
ConvertVhdEN.Action.text=
ConvertVhdEN.Action.shortDescription=Convert *.wim to *.vhd
DonateEN.Action.shortDescription=Make a Donation
DonateEN.Action.text=
botonDonateEN.text=Make a Donation
botonConvertVhdEN.text=Convert
botonVhdTargetEN.text=File *.vhd
menuBar.getMenu(0).setText("File"); // NOI18N
menuBar.getMenu(0).getItem(0).setText("Setting"); // NOI18N
menuBar.getMenu(0).getItem(2).setText("Exit"); // NOI18N
menuBar.getMenu(1).setText("Language"); // NOI18N
menuBar.getMenu(2).setText("Help"); // NOI18N
menuBar.getMenu(2).getItem(0).setText("Tutorial"); // NOI18N
menuBar.getMenu(2).getItem(1).setText("About..."); // NOI18N
Change the "EN" for the first letters of the language, and any improves for the english will be nice, =)
Edited by heldigard
Hy I just downloaded your application (alone & portable versions), as I can see the portable comes with DISM.exe in it, does it mean it can run in another OS than Win7, like XP SP-3?
Best Regards
Warning ! I changed all the "Get" command in line codes like these ones, to: Obtenir
botonGetCurrentEditionFR.text=Obtenir-Version actuelle
botonGetTargetEditionsFR.text=Obtenir-Versions cibles
I don't know if I was right or wrong, please check
Here we go:
botonMountFr.text=Monter-Wim
botonUnmountFr.text=Démonter-Wim
botonWimFR.text=Fichier .wim
botonMountDirFR.text=Répertoire de Montage
labelIndexFR.text=Version de l'Index
botonCleanUpFR.text=Nettoyer-Wim
showExplorarWimFR.Action.text=
showExplorarWimFR.Action.shortDescription=Parcourir un fichier Image (*.wim)
showExplorarWimTarjetFR.Action.text=
showExplorarWimTarjetFR.Action.shortDescription=Parcourir une image Cible (*.wim)
showExplorarDirFR.Action.shortDescription=Parcourir un dossier vide pour monter une image
showExplorarDirFR.Action.text=
MountWimFR.Action.text=
MountWimFR.Action.shortDescription=Monter image
jLabel1FR.text=Version de l'Index
radioGrabarFR.text=Accepter les Changements
radioLecturaFR.text=Lecture seule & Annuler
UnMountWimFR.Action.text=
UnMountWimFr.Action.shortDescription=Démonter l'image sur windir
botonWimInfoFR.text=Obtenir-WimInfo
botonMountedInfoFR.text=Obtenir-MontageWimInfo
WimInfoFR.Action.text=
WimInfoFR.Action.shortDescription=Obtenir les informations d'une image wim
checkIndexFR.text=Version de l'Index
MountedInfoFR.Action.text=
MountedInfoFR.Action.shortDescription=Montrer les images montées
CleanUpFR.Action.text=
CleanUpFR.Action.shortDescription=Supprimer les images invalides
botonGetPackagesFR.text=Obtenir-Packs
botonAddPackageFR.text=Ajouter-Pack
botonRemovePackageFR.text=Enlever-Pack
GetPackagesFR.Action.shortDescription= Montrer les packs de l'image sur la liste du tableau
GetPackagesFR.Action.text=
AddPackageFR.Action.text=
AddPackageFR.Action.shortDescription=Parcourir les Packs msu, cab ou dossier à fichiers multiples
ExaminarPackagesFR.Action.shortDescription=
ExaminarPackagesFR.Action.text=
botonExaminarPackagesFR.text=...
RemovePackageFR.Action.text=
RemovePackageFR.Action.shortDescription=Ecrire le nom du pack pour supprimer
botonCommitWimFR.text=Créer-Wim
CommitWimFR.Action.shortDescription=Sauvegarder les changements de l'image montée
CommitWimFR.Action.text=
botonClearFR.text=Clear
botonCopyFR.text=Copy
ClearFR.Action.shortDescription=Effacer Zone Texte
ClearFR.Action.text=
CopyFR.Action.text=
CopyFR.Action.shortDescription=Copier Contenu dans Presse-papier
botonGetDriversFR.text=Obtenir-Drivers
checkTablaDriversFR.text=Tableau
checkTablaPackagesFR.text=Tableau
botonExaminarPackages2FR.text=...
botonExaminarPackages3FR.text=...
botonGetDriverInfoFR.text=Obtenir-DriverInfo
botonRemoveDriverFR.text=Supprimer-Driver
botonAddDriverFR.text=Ajouter-Driver
checkAllDriversFR.text=Tout
ExaminarDriverFR.Action.text=
ExaminarDriverFR.Action.shortDescription=Parcourir Driver.inf pour montrer ou supprimer les infos
ExaminarDriversFR.Action.text=
ExaminarDriversFR.Action.shortDescription=Parcourir Driver.inf ou le dossier
GetDriversFR.Action.text=
GetDriversFR.Action.shortDescription= Montrer les Drivers de l'image
GetDriverInfoFR.Action.text=
GetDriverInfoFR.Action.shortDescription=Montrer les infos du Driver
RemoveDriverFR.Action.text=
RemoveDriverFR.Action.shortDescription=Supprimer un Driver de l'image
AddDriverFR.Action.shortDescription=Ajouter drivers à l'image
AddDriverFR.Action.text=
checkRecurseFR.text=Recursif
checkForceUnsignedFr.text=Forcer Non-signés
botonLenguajeFR.text=Espagnol
RestartExplorerFR.Action.text=
RestartExplorerFR.Action.shortDescription=Redémarrer l'Explorateur Windows
botonCloseExplorerFR.text=Fermer l'Explorateur
botonOpenExplorerFR.text=Ouvrir l'Explorateur
CloseExplorerFR.Action.shortDescription=Fermer l'Explorateur Windows
CloseExplorerFR.Action.text=
OpenExplorerFR.Action.text=
OpenExplorerFR.Action.shortDescription=Ouvrir l'Explorateur Windows
ChangeLanguageFR.Action.text=
ChangeLanguageFR.Action.shortDescription=Changement de Langue
botonBorrarProcesoFR.text=Enlever
BorrarProcesoFR.Action.shortDescription=Supprimer une procédure d'une liste
BorrarProcesoFR.Action.text=
EjecutandoProcesoFR.text=En fonction
ProcesoTerminadoFR.text=Réussite de la procédure
ProcesoPendienteFR.text=Processus en file d'attente
ProcesoErrorFR.text=Erreur lors de la derniere procédure
ProcesoClearFR.text=Effacer toutes les procédures en liste d'attente
botonCancelFR.text=Annuler
CancelProcessFR.Action.shortDescription=Annuler Procédure
CancelProcessFR.Action.text=
labelISOFR.text=Etiquette
botonFolderISOFR.text=Dossier Source
botonArchivoISOFR.text=Cible .iso
botonCrearISOFR.text=Créer Iso.cmd
CrearISOFR.Action.shortDescription=Créer Iso.cmd Script
CrearISOFR.Action.text=
FolderISOFR.Action.text=
FolderISOFR.Action.shortDescription=Parcourir dossier Source
ArchivoISOFR.Action.text=
ArchivoISOFR.Action.shortDescription=Parcourir Cible .iso
ISOErrorFR.text=Erreur lors de la création de l'image iso
ErrorNoDoneFR.text=\attendez la fin de la procédure et réessayez @ByELDI\n
ErrorNoDism1FR.text=Dism.exe introuvable
ErrorNoDism2FR.text=Ecrire le chemin complet vers Dism.exe
ErrorNoOscdimg1FR.text=Oscdimg.exe introuvable
ErrorNoOscdimg2FR.text=Ecrire le chemin complet vers Oscdimg.exe
ErrorNoImagex1FR.text=Imagex.exe introuvable
ErrorNoImagex2FR.text=Ecrire le chemin complet vers Imagex.exe
ErrorNoExpand1FR.text=Expand.exe introuvable
ErrorNoExpand2FR.text=Ecrire le chemin complet vers Expand.exe
IsoCompleteFR.text=Le programme doit être fermé pour terminer la création de l'iso.
botonGetFeaturesFR.text=Obtenir-Caractéristiques
botonGetAppsFR.text=Obtenir-Applications
GetAppsFR.Action.text=
GetAppsFR.Action.shortDescription=Montrer les informations des aplications MSI
botonEnableFeatureFR.text=Activer-Caractéristiques
botonDisableFeatureFR.text=Désactiver-
GetFeaturesFR.Action.text=
GetFeaturesFR.Action.shortDescription=Montrer les caractéristiques
EnableFeatureFR.Action.text=
EnableFeatureFR.Action.shortDescription=Activer une caractéristique
DisableFeatureFR.Action.shortDescription=Désactiver une caractéristique
DisableFeatureFR.Action.text=
radioImagePackagesFR.text=Image
radioOnlinePackagesFR.text=OnLine
botonGetAppPatchesFR.text=Obtenir-AppPatches
checkTablaAppsFR.text=Tableau
GetAppPatchesFR.Action.text=
GetAppPatchesFR.Action.shortDescription=Afficherinformations sur MSP's
checkProductKeyFR.text=Clé du Produit
GetCurrentEditionFR.Action.text=
GetCurrentEditionFR.Action.shortDescription=Montrerla version de l'image
GetTarjetEditionsFR.Action.text=
GetTarjetEditionsFR.Action.shortDescription=Montrer les versions pouvant être mises à niveau
SetEdition.ActionFR.text=
SetEdition.ActionFR.shortDescription=Mettre à jour la version windows
SetProductKeyFR.Action.text=
SetProductKeyFR.Action.shortDescription=Insérer clé du produit
radioImageEditionFR.text=Image
radioOnlineEditionFR.text=OnLine
botonSetProductKeyFR.text=Insérer-clé du produit
botonSetEditionEN.text=Insérer-Edition
BotonImageFR.Action.text=
BotonImageFR.Action.shortDescription=Image Horsligne
BotonOnlineFR.Action.text=
BotonOnlineFR.Action.shortDescription=Système actuel
botonConvertirFR.text=Convertir
botonDestinoCabFR.text=Cible
botonMsuFR.text=Files *.msu
ExaminarCabFR.Action.shortDescription=Dossier Cible
ExaminarCabFR.Action.text=
ConvertCabFR.Action.text=
ConvertCabFR.Action.shortDescription=Convertir msut en cab
ExaminarMsuFR.Action.text=
ExaminarMsuFR.Action.shortDescription=Parcourir les packs msu
botonGetLanguagesFR.text=Get-Intl
GetLanguagesFR.Action.text=
GetLanguagesFR.Action.shortDescription=Afficher les langues à l'image
botonGenLangIniFR.text=Gen-LangIni
GenLangIniFR.Action.shortDescription=Generate new file lang.ini
GenLangIniFR.Action.text=
radioImageLanguageFR.text=Image
radioOnlineLanguageFR.text=OnLine
labelDescriptionFR.text=Description
labelNameEN.text=Nom
botonExportFR.text=Exporter
botonChangeInfoFR.text=Changer Nom
botonWimTargetFR.text=Cible .wim
IsoCmdFR.Action.text= Lancer le Script
IsoCmdFR.Action.shortDescription=Lancer le Script Iso.cmd
ChangeNameFR.Action.text= Changer Nom et Description
ChangeNameFR.Action.shortDescription=Changer Nom et Description
ExportFR.Action.text=Exporter une Image
labelCompressFR.text=Compresser
checkBoxErrorListFR.text=Effacer Liste en Erreur
botonFolderCopyFR.text=Dossier Source
botonCopyMountFR.text=Copier
ExaminarFolderCopyFR.Action.text=
ExaminarFolderCopyFR.Action.shortDescription=Parcourir Dossier Source
botonDeleteFolderFR.text=Supprimer
CopyMountFR.Action.shortDescription=Copier Dossier dans Répertoire de Montage Image
CopyMountFR.Action.text=
DelFolderMountFR.Action.shortDescription=Supprimer Dossier dans Répertoire de Montage Image
DelFolderMountFR.Action.text=
labelTargetFolderFr.text=Cible dans Dossier Image
botonIsoCmdFR.text=Iso.cmd
botonCabFr.text=Fichiers *.cab
botonTargetCabFR.text=Cible
botonUnzipCabFR.text=Décompresser Cab
BrowseCabFR.Action.shortDescription=Parcourir fichiers *.cab
BrowseCabFR.Action.text=
BrowseTargetCabFR.Action.shortDescription=Parcourir Dossier Cible
BrowseTargetCabFR.Action.text=
UnzipCab.ActionFR.shortDescription=Décompresser cab
UnzipCab.ActionFR.text=
checkIgnoreFR.text=IgnorerVérification
showConfigFR.Action.shortDescription=Réglage Dism Imagex Oscdimg
showConfigFR.Action.text=
botonCaptureFR.text=Capture
checkVerifyFR.text=Verifier
CaptureFR.Action.text=
CaptureFR.Action.shortDescription=Capturer un lecteur dans *.wim
MsuCabFR.Action.text=
MsuCabENFR.Action.shortDescription=Lancer le script MsuCab.cmd
ExaminarVhdFR.Action.text=
ExaminarVhdFR.Action.shortDescription=Parcourir le fichier cible *.vhd
ConvertVhdFR.Action.text=
ConvertVhdFR.Action.shortDescription=Convertir *.wim en *.vhd
DonateFR.Action.shortDescription=Faire un Don
DonateFR.Action.text=
botonDonateFR.text=Faire un Don
botonConvertVhdFR.text=Convertir
botonVhdTargetFR.text=Fichier *.vhd
Edited by carpediem2b
Best Regards
Theoretically, yes.
Here we go:
CopyFR.Action.text=
Thank you for the translation. I will add it in the next version.
@heldigard
Nice program, thanks.
Could you add French language inside made by carpediem2b! Thanks
I was traveling for a several months, so I am back again. When I have chance I will add the news features and the new language.
@heldigard
Many thanks. Very good work! :giveheart:
I am working right now in the .NET version, so when I have chance I will updated the Java version.
From now on I will publish the development version of GDism .NET ELDI
1) First launch setup.exe and accept to install Microsoft Net Framework 4 (x86 y x64)
with GDism.NET ELDI.
When the installation is complete you can change the language.To open a new time the program launch:
GDism .NET ELDI.application
If you have errors, browse to Add/Remove programs and remove:
1 - Paquete de idioma de Microsoft.NET Framework 4 Extented ESN
2 - Paquete de idioma de Microsoft.NET Framework 4 Client Profile ESN
Install the progam a new time!
All is fine for me!
2) With Portable GDism ELDI:
Right clic on DismGUI_ELDI.jar and select: Open with Java(TM ) Platform SE binary
Edited by myselfidem
I am getting "unable to access the image" error when I tried to set product key. I have also seen the log there I see msg "Failed to access the image folder or image's windows folder." any help?
Using Version NET 4.0 or Java ?
Of course, it's needed to select first the install.wim path and create a temp folder to mount/unmount the image!
Have you read the dism.log to see errors ?
