WinSnap 3.0.8
What's New
Version 3.0.8 (May 12, 2009)
New translations: Dutch, Korean, Basque (Euskera)
Greatly improved "Clear window background under Vista" feature
Capture Explorer windows and dialogs using the Application mode
Active monitor is determined by mouse position now (Full Screen)
Fixed some minor issues with capturing elevated (UAC) applications
Improved compatibility with Windows 7 RC and Beta
Portable Edition: increased performance when running from slow USB drives
Information: Info
Version: 3.0.8
Addon Release Date: June 16, 2009
Credit: *Reaper*
RyanVM Integrator & N-Lite Addon
MD5: 88fb0bd55052f89f51abe512bb2a3ce9
Switchless Installer
MD5: ce2f0049e5929d0eadb062f88edfd0f7
NOTE: This app is now shareware. Below is a quote of part of the lic. txt....
LICENSING. You may install and use an evaluation version of the SOFTWARE PRODUCT for 30 days,
after which you must purchase a license or stop using the SOFTWARE PRODUCT.
Enjoy!
Edited by *Reaper*
  • 1 year later...
  • 7 months later...
WinSnap 3.1.1 is out.
* Added Drag-n-Drop support (drag image and drop onto WinSnap to open it)
* Added ability to run WinSnap after installation on Vista and Windows 7
* Several improvements on WinSnap Portable Edition
