Posted March 25, 200718 yr Universal Extractor 1.6.1What's New1.6.1 (05/12/2010): Added support for environmental variables (eg., specify %temp% for debug dir) Added support for XZ compressed files and txz/tlz archives via 7-Zip Added support for Windows Installer merge modules (.msm) via MsiX Added support for NBH files via NBHextract Added translations for Armenian, Czeck, Persian (Farsi), Serbian, Swedish Changed 7-Zip unpacking behavior; now attempts brute force extraction only after External PEiD scan; change due to aggressive .exe resource extraction in new versions Changed Windows installer support (.msi, .msp) to use MsiX instead of msi2xml Changed LZMA support to use 7-Zip for extraction Changed FEAD support to use PEiD rather than TrID for detection Changed following formats to call 7z by name (also see 7-Zip debug comment): bz2, chm, gz, tar, Z this is mostly for code cleanup; functionality should be the same Fixed InstallShield 5.x regression in 1.6 preventing successful extraction Fixed bug in extraction of non-TAR LZW compressed files Fixed bug that prevented picking files after toggling history option Fixed bug in display of history combo boxes when no items listed Fixed cosmetic bug in Visual C++ SFX status dialog Fixed cosmetic bug in status dialogs due to extra padding by AutoIt Removed lzma helper binary Removed msi2xml helper binary and MSXML download link on MSI selection page Removed Windows NT 4.0 support from installer Removed debug output for 7-Zip, arj, hlp; buffers output, preventing proper user feedback and input prompts Updated success/fail detection to check output directory timestamp; can detect cases where files are overwritten, which old method missed; will still consider failed if user chooses not to overwrite files, or if all files are written to a subdirectory of the output directory Updated RPM and DEB support to extract interim CPIO and TAR files Updated FEAD support to workaround read-only permission issue Updated Zip support to log unzip output and permit minor reported unzip errors Updated PEiD detection of Microsoft SFX cab files for more reliable extraction Updated some UniExtract window sizes for better internationalization support Updated translations for Italian, Korean, Russian Updated 7-Zip to 9.13 beta Updated AutoIt to 3.3.6.1 and replaced deprecated _ArrayCreate UDF Updated InfoZip unzip to 6.0.0 Updated Inno Setup to 5.3.9 Updated innounp to 0.31 (supports Inno Setup 5.3.9) Updated InstallExplorer WCX to 0.9.2 Updated MSI WCX to 1.2.1 Updated PEiD to 0.95 Updated UnRAR to 3.93Version: 1.6.1Addon Release Date: June 5, 2010Credit: *Reaper*RyanVM Integrator & N-Lite Addon: 5.40 MB 382664adaea816f8b4ee890bfd45898aSwitchless "Silent" Installer: 5.39 MB 6c80a3ad54556e1fc49279c96a6afba7Enjoy! Edited June 5, 201014 yr by *Reaper*
October 25, 200816 yr just asking can you upload this addon to another site other than skydrive i cant download from it right now Edited October 25, 200816 yr by DaRk MaDnEsS
October 25, 200816 yr YesI am also having problems to download this one.Please put it on anywhere else.
October 25, 200816 yr reaper do you can create only with (uniextract to subdir) on right click mouseSetup.exe /VERYSILENT /SUPPRESSMSGBOXES /NORESTART /MERGETASKS="!associate\here,!associate\files"Adding this to silent switch, installs it with all default settings, except it does not add all context menu's, but ONLY "uniextract to subdir"MERGETASKS="!associate\here,!associate\files"Am going to be posting a switchless installer of this soon, with only "uniextract to subdir" in switchless installer section.EDIT:Switchless installer can be found below. With only "uniextract to subdir"http://www.wincert.net/forum/index.php?showtopic=4675 Edited October 26, 200816 yr by shahed
November 13, 200816 yr there are 2 seperate posts with Universal Extractor, yours and shahed, are they different? thanks
November 13, 200816 yr there are 2 seperate posts with Universal Extractor, yours and shahed, are they different? thanksAm going to be posting a switchless installer of this soon, with only "uniextract to subdir" in switchless installer section.Switchless installer can be found below. With only "uniextract to subdir"Answer is here
June 6, 201014 yr *** Updated to 1.6.1May by updated with 7zip 9.14. Edited June 7, 201014 yr by J.S.Prasad
