Popular Post ricktendo Posted November 9, 2011 Popular Post Posted November 9, 2011 Quote About: These packages contain .NET Framework 4.0 Full (Client and Extended) x86/x64 installers including updates (and Language Packs) integrated. For command-line options run <installer_name>.exe /? Note: The reason its called "Slim" is because the original MSI installers have been carefully edited to remove unnecessary setup junk, this should save 200+ MB of space on your HDD/SSD. OS: Windows XP SP3 Windows Vista/Server 2008 SP2 x86/x64 or Windows 7/Server 2008 R2 SP1 x86/x64 I recommend 4.6 for Vista and above Some tools and resources for (re)creating your own slim (intl) installer .NET4 SFX Maker v5 (installer repacker): .NET4 Intl SFX Maker v1 (if you want to add LP): Silent "No GUI" SFX alternative v1.6: KB2656351 MST Windows Update fix v3.6: MsiTran.Exe -a <transform>.MST <installer>.MSI: KB2468871-v2 MSP Stub Windows Update fix v1.4: Integrate this (before you slim) to activate/enable LDR/QFE branch: Slim down your dotNET4(.5) & LP installers: If you cant find a hotfix try using the KB number w/ this URL: Slim Language Packs: Arabic: Chinese (Simplified): Chinese (Traditional): Czech: Danish: Dutch: Finnish: French: German: Greek: Hebrew: Hungarian: Italian: Japanese: Korean: Norwegian (Bokmal): Polish: Portuguese (Brazil): Portuguese (Portugal): Russian: Spanish: Swedish: Turkish: http://support2.microsoft.com/hotfix/KBHotfix.aspx?kbnum=1234567 Changelog: 2-02-2012 Add: 2652319 2-14-2012 Add: 2564823, 2600217, 2654625 Rem: 2600088, 2628838, 2629846, 2640103 Upd: SFX, MST Fix: UAC 2-16-2012 New: 2468871-v2 WUFix Upd: SFX GUI+NoGUI Del: 2468871 from MST 2-18-2012 Add: 2509900, 2644426 Rem: 2624480 Upd: MSP 2-29-2012 Add: 2645609, 2675049 Rem: 2588096, 2652531, 2654625 3-05-2012 Add: 2600211 Rem: 983182, 2544514, 2605597, 2652319, 2656351 Upd: MST 3-13-2012 Add: 2675468 4-10-2012 Add: 2656368, 2688026 Upd: SFX 4-17-2012 Add: 2660677, 2669774 Rem: 2509900, 2564823 Upd: MSP 5-03-2012 Add: 2702328 Rem: 2656368 Upd: MST 5-08-2012 Add: 2604121 Upd: MST 6-06-2012 Add: 2714396 Rem: 2607656, 2675468 Upd: SFX 6-12-2012 Add: 2656368v2, 2686827 Rem: 2702328 Upd: MST 7-10-2012 Add: 2711617 7-22-2012 Add: 2682543 Rem: 2688026 8-09-2012 Add: 2733944 Rem: 2660677 9-14-2012 Add: 2133974*, 2277657*, 2298853*, 2545756 10-10-2012 Add: 2756195 Rem: 2545756 11-13-2012 Add: 2729449, 2737019 Rem: 2328751, 2645609 12-11-2012 Add: 2783767 Rem: 2328606, 2682543 1-08-2013 Add: 2736428, 2742595 Rem: 2548766, 2578541, 2656368, 2686827 2-12-2013 Add: 2789642 2-16-2013 Add: 2803771 Rem: 2593745 4-11-2013 Add: 2828843 Rem: 2567467, 2630021 5-16-2013 Add: 2804576 6-11-2013 Add: 2836939 6-16-2013 Add: 2848797, 2851199 7-09-2013 Add: 2832407, 2840628 8-13-2013 Upd: 2836939-v2, 2840628-v2 8-15-2013 Add: 2862065 Rem: 2848797 9-18-2013 Add: 2888303 10-08-2013 Add: 2858302, 2861188 Rem: 2644426, 2804576, 2832407, 2836939 10-09-2013 Add: 2889629 1-05-2014 Add: 2894842, 2908370 Rem: 2862065, 2888303 2-11-2014 Add: 2898855-v2, 2901110-v2 Rem: 2889629 2-12-2014 Add: 2926986 Rem: 2898855-v2 4-15-2014 Add: 2937673 5-13-2014 Add: 2931365 Rem: 982638 8-08-2014 Add: 2974335 Rem: 2756195, 2851199, 2937673 9-09-2014 Add: 2894842v2, 2972215 Rem: 2901110 10-14-2014 Add: 2972106, 2979575 Rem: 2783767 10-15-2014 Add: 2996569 Rem: 2926986 11-11-2014 Add: 2978125 Rem: 2931365 11-25-2014 Add: 3013383 1-14-2015 Add: 3031985 Rem: 2974335 4-14-2015 Add: 3037578 Rem: 2894842 5-14-2015 Add: 3023221, 3032662, 3048074 Rem: 2789642, 2858302 7-13-2015 Add: 3057756, 3064706 Rem: 3048074 8-13-2015 Add: 3072309 Rem: 3064706 9-9-2015 Add: 3074547 9-23-2015 Add: 3088949 Rem: 3057756, 3072309 10-29-2015 Add: 3096089 11-22-2015 Add: 3097994, 3098778, 3106994 Rem: 2979575 * = LP only Hotfix list: Client: 971891 2328677 2443643 2468871 2504602 2533523 2534087 2571181 2580188 2600211 2600217 2604121 2638450 2640289 2669774 2714396 2729449 2733944 2736428 2737019 2742595 2803771 2828843 2840628 2861188 2908370 2972106 2972215 2978125 2996569 3013383 3023221 3031985 3032662 3037578 3074547 3088949 3096089 3097994 3098778 3106994 Extended: 971891 2468871 2487367 2533523 2537715 2563483 2600211 2600217 2639157 2675049 2711617 2736428 2742595 2803771 2828843 2894842 3013383 3037578 3098778 ClientLP: 971891 2277657* 2298853* 2518870* 2580188 2600211 ExtendedLP: 971891 2133974* 2277657* Darias, Petrov, ozmania and 17 others 20 Quote
myselfidem Posted November 9, 2011 Posted November 9, 2011 (edited) Many thanks!Yes, that will be fine to give us explainations on how to add our language and the instructions! Edited November 9, 2011 by myselfidem Quote
ricktendo Posted November 9, 2011 Author Posted November 9, 2011 Link to your lp I will slim it and show you how to uncompress and rebuild your own with the lp added Quote
RicaNeaga Posted November 9, 2011 Posted November 9, 2011 He's the man! Thank you very much! :dancing:I'll try it with -ai switch in a couple of hours, and come back with feedback. Quote
RicaNeaga Posted November 10, 2011 Posted November 10, 2011 I can confirm that using /ai switch only client version is installed and no additional updates are needed through windows updates. So, besides beeing rather slow to install, everything is ok. Thanks again! Quote
qwesta Posted November 10, 2011 Posted November 10, 2011 thank you rick, can one make a German language copy? Quote
ricktendo Posted November 10, 2011 Author Posted November 10, 2011 You are going to have to do that yourself, I added the slim German LP, SFX Maker and instructions on how to recompile Quote
qwesta Posted November 11, 2011 Posted November 11, 2011 You are going to have to do that yourself, I added the slim German LP, SFX Maker and instructions on how to recompileA good job, thank you very much Quote
crashfly Posted November 12, 2011 Posted November 12, 2011 hmmm ... if this one has all of the latest updates, I will definitely have to try it out. Thanks ricktendo64.Question: I am under the assumption this will work with Win7 also? Quote
ricktendo Posted November 12, 2011 Author Posted November 12, 2011 XP, Vista, 7 and yes all updates from SoLoR til the date listed on in the topic tittle Quote
crashfly Posted November 12, 2011 Posted November 12, 2011 XP, Vista, 7 and yes all updates from SoLoR til the date listed on in the topic tittleYes, and sometimes I do not read. :doh: :worthy: Quote
bphlpt Posted November 13, 2011 Posted November 13, 2011 @crashfly,Main difference, as I understand it, between Rick's and Trobada's is that Rick's is client + extended capable where Troubada's is client only.Cheers and Regards Quote
ricktendo Posted November 13, 2011 Author Posted November 13, 2011 Mine is both Client+Extended or Client only with passive or quiet install option (also ngen executequeueditems so there is no mscorsvw.exe slowdown)So its pretty much universal, to suit any flavor or taste Quote
myselfidem Posted November 14, 2011 Posted November 14, 2011 (edited) Thanks Rick!Here is the language pack for French (x86):http://www.microsoft...8d-0df2d76e24a8Module linguistique Microsoft .NET Framework 4 Full (x86/x64):http://www.microsoft.com/downloads/fr-fr/details.aspx?FamilyID=6fd7e428-0aa8-40e3-a48d-0df2d76e24a8 Regards Edited November 14, 2011 by myselfidem Quote
yendyjm Posted November 26, 2011 Posted November 26, 2011 ricks a question these updates. NET Framework 4 that I have I will create a need to modify the code you put on a list that I have to this dayadded:x86 .NET.Framework 4.0Eliminado... Quote
ricktendo Posted November 26, 2011 Author Posted November 26, 2011 No comprendo, mi instalador ya tiene todas las actualizaciones integradas Quote
yendyjm Posted November 26, 2011 Posted November 26, 2011 disculpa ricks fue mi hermano utilizando el traductor en un momento que sali yo e bajado lo que esta en lo anterior son los updates mi duda es que si va a funcionar con tu creador de .NET y si es posible el 3.5 Quote
ricktendo Posted November 26, 2011 Author Posted November 26, 2011 No, mi creador de sfx no integra actualizaciones solo es para re-empacar el instalador para añadirle un lp (las actualizaciones para .net en forma de msu se pueden integrar)Acaso acabo de subir el lp Español Quote
yendyjm Posted November 26, 2011 Posted November 26, 2011 ok acabo de bajarme los msp de la pagina de solor y como seria hay que añadirlo al codigo de tu creador Quote
ricktendo Posted November 26, 2011 Author Posted November 26, 2011 No tienes que hacer nada, mi instalador ya tiene las actualizaciones de SoLoR integradas...Solo si quieres ponerle tu LP tienes que extraer dotNetFx40_Full_x86_x64_SlimSetup.exe luego extraes/agregas tu LP slim, vuelves a comprimir todo con 7zip, editas config.txt para quitarle los punto y coma (;) de la lineas RunProgram y AutoInstall* con los LP MSI y finalmente arrastras y sueltas el .7z encima del .bat para crear el EXE (puse instrucciones en el primer post y en la carpeta \Help del creador de SFX) Quote
yendyjm Posted November 26, 2011 Posted November 26, 2011 ok ahora a hacerlo con tus intruciones gracias ricks por tu gran ayuda Quote
RicaNeaga Posted November 28, 2011 Posted November 28, 2011 First question: using /ai for the installer, are you sure no ngen optimization is run for the client version? I'm asking because I don't know why your addon is slower (not by much, but slower) to install then pegasus's one (from rvm).Second question: making two installers, one for client, one full, can be a good idea? First reason - less MB for the client version, second (presumption) - hopefully the client will be a little faster Quote
ricktendo Posted November 28, 2011 Author Posted November 28, 2011 No idea why and no, it does not execute ngen...use pegasus's one if its faster Quote
ricktendo Posted December 6, 2011 Author Posted December 6, 2011 UpdatedUpdated the sfx maker: added /qb! switch to remove the cancel button from the msi gui install and updated the 7zsd.sfx to the latest stable versionAlso added a VBS Slimmer script (thanks to dumpydooby) for .net 4, 4.5 and should also work on any of the LP's Quote
