Nice Makave2345 :) I really like this program.
Do you perhaps know...is it possible to add registration code in addon it self,so I don't have to do that when I run program for the first time.
ThX ^_^
This is how you can use a CMD file to Install and Add your registration info Makave:
Start /WAIT OO_Defrag_Pro.msi /quietREG ADD "HKLM\SOFTWARE\O&O\O&O Defrag\8.0\Pro\licenses" /V Company /t REG_SZ /d ricktendo64 /fREG ADD "HKLM\SOFTWARE\O&O\O&O Defrag\8.0\Pro\licenses" /V SerialNo /t REG_SZ /d 1234-5678-90AB-CDEF-GHIJ /fREG ADD "HKLM\SOFTWARE\O&O\O&O Defrag\8.0\Pro\licenses" /V User /t REG_SZ /d "Ricardo Cooper" /fEXIT
I use RunHiddenConsole.exe to hide my CMD window. So the switches are RunHiddenConsole.exe /W Install.cmd
Hmm so I have to install it first on my OS and then register it manually and latter on register addon via CMD window? Am I getting it? :mellow:
  Makave2345 said:
*** Updated to 10.0.1634.0
Makave2345 I have a question about this addon I installed it and all seem to work well until I deleted a tmp directory that this addon needs to run. It looks like it is created by the 7zip sfx. I don
Edited by dolivas
  • 10 months later...
  • 6 months later...
Hey, I was wondering whether it's possible for you to update this to the new version 11?
Or could I simply replace files inside the archive with the newer version?
TIA!
