^SoKoOLz^ Posted April 5, 2007 Posted April 5, 2007 (edited) Okay, it's been a while since I update this installer.This installers contain:- Vista Fonts- Gadgets (Extras)- Gadgets InstallerPrerequisite:- MSXML 6.0 (must have before installing WLAN API) - MSXML 6.0 SP1 (optional) - WLAN API (For XP user, 2003 user won't need this)- ALKY Tools - VC2005 Runtime (Required before installing VAIO Tools) - Alky 1.0 for Windows XP - VAIO Tools for Windows Server 2003 * After you have successfully installed ALKY you will need to restart your system.Gadget Dependecies:- .NET Framework 2.0 ( For some components to run properly)- Internet Explorer 7 For Windows XP- Internet Explorer 7 For Windows 2003- Windows Media Player 11 ( For XP )CHANGELOG:{20/11/07}UPDATE: All components to the latest Vista releaseFIX: Many bugs{30/05/07}ADD: CPU CORE 4 GadgetsADD: ALKY SUPPORT{17/05/07}ADD: WMP GadgetFIX: Now able to select/unselect Gadget InstallerFIX: FONT exist popup{20/04/07}FIX: FONT variablesFIX: More CompressionADD: 2003 CompatibilityADD: Windows Version Check functionADD: More gadgetsSET: LiveClock, CPUMeter, and HDD Monitor to default sidebar first start setting.INSTGUI: Wallpapers and checkboxesToDo:{20/05/07}- More gadget install sectionPre-Installation step (helper)(For those of you who got confused with those prerequisites)XP User Steps:MSXML 6.0>>>WLAN API>>>VC2005 Runtime>>>ALKY Tools for Windows XP>>>Restart2003 User Steps:VC2005 Runtime>>>VAIO Tools for Windows Server 2003>>>Restart*After you have restarted, then you can start using the Windows Sidebar InstallerThis installer also comes with /S , Silent Switch command.Windows Sidebar Installer for Windows XP/2003Credit:Ricktendo64 [AddOn] Windows Vista RTM Sidebar (XP Only)* Edited October 1, 2008 by N1K Reezo and chopper 2 Quote
MrNxDmX Posted April 5, 2007 Posted April 5, 2007 (edited) Links dont work. And, what is the difference between urs and Ricks?Edit: Links working now, sorry for that. Edited April 5, 2007 by MrNxDmX Reezo 1 Quote
^SoKoOLz^ Posted April 5, 2007 Author Posted April 5, 2007 Links dont work. And, what is the difference between urs and Ricks?Edit: Links working now, sorry for that.Mine is an NSIS Installer, it is much much faster than Ricks method when use it as an Addon. And it also contains the gadget installer already. Reezo 1 Quote
ricktendo Posted April 5, 2007 Posted April 5, 2007 The delay load error is caused by WLan API Hotfix not being installed Reezo 1 Quote
Carillo Gallardo Posted April 17, 2007 Posted April 17, 2007 Hi guys, hi Ricks! ^SoKoOLz^ i noticed that your installer (i've tried only the 2k3 version) installs vista fonts only in "c:\windows\fonts". Obviously this is not a bug and your work is great but maybe people with a different configuration of their hard drives (like "f:\windows" or else) could encounter some problems.Except this your installer works like a charm! Byezzzz :welcome: Reezo 1 Quote
^SoKoOLz^ Posted April 18, 2007 Author Posted April 18, 2007 Hi guys, hi Ricks! ^SoKoOLz^ i noticed that your installer (i've tried only the 2k3 version) installs vista fonts only in "c:\windows\fonts". Obviously this is not a bug and your work is great but maybe people with a different configuration of their hard drives (like "f:\windows" or else) could encounter some problems.Except this your installer works like a charm! Byezzzz :welcome:Yep peraps you r right, I'll look into that and will release the new version soon. THank you very much. Reezo 1 Quote
^SoKoOLz^ Posted April 19, 2007 Author Posted April 19, 2007 %WinDir% sKz Thanks, but $FONT might be better, thats for NSIS varaible ^^. Reezo 1 Quote
tap52384 Posted April 20, 2007 Posted April 20, 2007 Is it not possible to go ahead and include VAIO and the WLAN update, or is that against some sort of policy that the authors have set? Reezo 1 Quote
5128 Posted April 21, 2007 Posted April 21, 2007 Hey nice theme on the screenshot Where did you get it ?thnks Reezo 1 Quote
^SoKoOLz^ Posted April 21, 2007 Author Posted April 21, 2007 Hey nice theme on the screenshot Where did you get it ?thnksThat's mine own modified theme.It includes, VistaCG theme + Vista Aurora BG + Aero II Cursor + Vista RTM sound. Quote
kiki burgh Posted April 21, 2007 Posted April 21, 2007 Mine is an NSIS Installer, it is much much faster than Ricks method when use it as an Addon. And it also contains the gadget installer already.hi ^SoKoOLz^! aside from being an NSIS what else is different from Rick's? thanks! Quote
^SoKoOLz^ Posted April 23, 2007 Author Posted April 23, 2007 From my point of view:Rick installer is still using the INF/true Addon method, which I have to say it is slow and there's a chance for user to make a mistake by pressing cancel button. This method is only good for an addon but not for the installer.My one is using the installer script which is faster and smaller with better compression. It is definitely good for WPI and normal setup.If u try both installers u will see the differences. Quote
nikestars Posted April 27, 2007 Posted April 27, 2007 i'm using winserver 2003 SP2, how do i install wireless lan APi if the patch itself says doesn't compatible with winserver 2003 SP2 even tough i turned on the compatibility mode to XP, everytime i run it, it will say"Sorry. This application attempted to delay-load a library or function that does not exist. Instability may occur."that is a sign that Wireless Lan API hasn't been installed. I can run it swiftly on XP because i can install that API, how do i do that in winserver 2003 SP2? Quote
ricktendo Posted April 27, 2007 Posted April 27, 2007 You don't need WLan API if you are gonna use the sidebar on server 2k3, all you need is VAIO2003 and the sidebar (you might need the atl.dll file from a XP machine, just put it in the same folder as sidebar.exe and you will be fine) Quote
nikestars Posted April 27, 2007 Posted April 27, 2007 thx for your fast response, i'm using ATL patch from this link http://www.sokoolz.com/addons/r64/Ricks_Vi...debar2k3Fix.rarhow do i install it? currently i only right click the INF file and selecting install, what i must do with the INI file?i already installed IE7, WMP11, C++ Redistributable 2005 Quote
^SoKoOLz^ Posted April 27, 2007 Author Posted April 27, 2007 So, my installer doesnt work on Win2K3!?, Can u look in Windows Sidebar directory and tell me whether u have ATL.dll or not? Quote
nikestars Posted April 27, 2007 Posted April 27, 2007 yes it is, there is a file atl.dll already before i copy atl.dll from winXP, still i wonder why it still have that error Quote
^SoKoOLz^ Posted April 28, 2007 Author Posted April 28, 2007 i see, I think there's something to do with the file version. I will update it soon.Thank you ^^ Quote
kiki burgh Posted May 3, 2007 Posted May 3, 2007 From my point of view:Rick installer is still using the INF/true Addon method, which I have to say it is slow and there's a chance for user to make a mistake by pressing cancel button. This method is only good for an addon but not for the installer.My one is using the installer script which is faster and smaller with better compression. It is definitely good for WPI and normal setup.If u try both installers u will see the differences.thanks SoKoOLz! leme try this ... would this mean that updates wouldn't be frequent anymore in rick's work? Quote
kiki burgh Posted May 4, 2007 Posted May 4, 2007 (edited) hi SoKoOLz!! i tried slipstreaming this via HFSLIP ... & nLite too ... i was right in thinking it would install at T-13 silently but prompts still came up until the part where you click on Finish ... would the package be good for automatic /S install so that OS install would be unattended? also clock only showed black ... notepad didn't launch ... please know that i had VAIO, WPI and .NET2 integrated too ... oh and btw, how do i add gadgets? didn't see gadget installer installed ... in rick's addon, downloading gadgets and double clicking these automatically added gadgets to the sidebar ... your feedback would be greatly appreciated ... thanks! Edited May 4, 2007 by kiki burgh Quote
modarm Posted May 6, 2007 Posted May 6, 2007 Hello, I have just used your installer it all seems to work well but when I restart I get a starnge error;The procedure entry point Wow64EnableWow64sRedirection......Please see picture for more details. I will try to uninstall and reinstallI am running WinXPSP2 32bit.Thanks Quote
^SoKoOLz^ Posted May 7, 2007 Author Posted May 7, 2007 (edited) Sorry for my late response.@kiki burghI've checked my installer with /S switch and it seems to work just fine, there will only be a little DOS screen that will still shows up and close automatically. If you are using this with WPI then make sure you have the right quotation.This is from my WPI config file:prog[pn]=['Windows Vista Sidebar Installer 1.1 *'];ordr[pn]=[22];desc[pn]=['Windows Vista Sidebar for Windows XP'];uid[pn]=['WVS'];dflt[pn]=['yes'];cat[pn]=['Microsoft Softwares'];forc[pn]=['no'];cmd1[pn]=['"%wpipath%\\Install\\WindowsXPSidebarInstaller-1.1.exe" /S'];pn++;Also, if you still see the black clock, please re-run the installer again and see if it is still got the same error or not? I need to know where did it wnet wrong. Thank you@modarmDo you still see this error every time you reboot?And Do you have Windows XP64-bit installed on the same partition? Edited May 7, 2007 by ^SoKoOLz^ Quote
modarm Posted May 8, 2007 Posted May 8, 2007 Hi, I have no XP64-bit installed. However I did fix it by uninstalling and reinstalling which fixed it for a short time. I then started getting another error which I fixed by setting the compatability mode of the sidebar.exe to Windows 2000. So I now have the sidebar functioning its brilliant but still some bugs. If I load the outlook gadget it comes up with an error then if I try and open outlook outlook will not open until I exit the outlook gadget. This only started after I told the sidebar.exe to open in compatibility mode so I guess this is the problem.Please see image for more info.I also run:TopDeskWindowsBlinds5.5 - Vista32px by JemahoVisual tooltipOffice 2003WinXPsp2This machine was rebuilt two 4 days ago so its very clean.Thanks for your support Quote
kiki burgh Posted May 9, 2007 Posted May 9, 2007 Sorry for my late response.@kiki burghI've checked my installer with /S switch and it seems to work just fine, there will only be a little DOS screen that will still shows up and close automatically. If you are using this with WPI then make sure you have the right quotation.This is from my WPI config file:prog[pn]=['Windows Vista Sidebar Installer 1.1 *'];ordr[pn]=[22];desc[pn]=['Windows Vista Sidebar for Windows XP'];uid[pn]=['WVS'];dflt[pn]=['yes'];cat[pn]=['Microsoft Softwares'];forc[pn]=['no'];cmd1[pn]=['"%wpipath%\\Install\\WindowsXPSidebarInstaller-1.1.exe" /S'];pn++;Also, if you still see the black clock, please re-run the installer again and see if it is still got the same error or not? I need to know where did it wnet wrong. Thank youthanks ^SoKoOLz^! would this integrate with nLite or HFSLIP as silent installer? thanks! Quote
