ricktendo Posted May 9, 2012 Posted May 9, 2012 This is the yumeyao LZX:21 mod of InstEd (you can credit him and ONLY him for this) Website: http://www.instedit.comFull relationship mapping between all rows, including formatted fields referencing components, files, properties, and directories.Highlighting of broken relationships, with full explanation.Cascaded update when editing a referenced row. e.g. Renaming a directory row will optionally udpate everything that references that row, including formatted fields.Cascaded deletion when deleting a parent row. e.g. Deleting a component row optionally deletes everything belonging to the component.Smart field editors.Auto-completion where suitable.Menu based flag field editor.Tooltips showing exact meaning of flag fields.Guid generator.Validation profiles.Validate more than one file at a time.Validate files using more than one cub at a time.Sort, hide, copy the validation results.Auto navigates to the relevant field.Configurable external tool commands.Optionally pass the current file to the external tool on its command line.Pass transforms to external tools as msi files, and have InstEd automatically include the changes made by the external tool in the original transform.Single command backups of the current file.Msi differencing.Apply and unapply multiple transforms to see cumulative effects.Easily revert single fields, or whole tables, in both transforms and diffed msi files.Hide empty tables.Back and Forward navigation of table cells using keyboard and/or browsing buttons on mice/keyboard.Build and rebuild cabs from the Media table.Merge modules into the msi, with automatic fixup of the sequence tables. Extract the cabs and/or files from the merge module when merging.Command line validation.Specify a name for use in the "Last Saved By" field, e.g. a company name instead of a user name.Context sensitive F1 help integrated with the online Windows Installer SDK.Directory table shows expanded target folder._Streams table is accessible so that merge module cabs can be accessed.Update the File and MsiFileHash details for files located in the source tree.Import regedit files (.reg) into components.Sets the INSTED_VALIDATING_FILENAME environment variable to the filename of the msi being validated, so that QA cubs can validate the form of the filename.For me, InstEd is unique because it can edit an msi file without touching SummaryInfo... Modificatioins: VC10 Runtimes removed from the pack. gdiplus.dll removed from the pack. Changed defaut option - Last Saved by - Don't change on save ----- this is what I mentioned above, not touching SummaryInfo. Allow hacking the executable to grant generating LZX-compressed cab files. (commandline switch: HACKLZX=1) Download the updated/repacked installer http://adf.ly/1713566/instedmsiMD5: 9d3afa16be6c4e70bd985af58b666428 Size: 2.04 MB Or download the MST so you can apply it to current (or future) version of InstEd yourself http://adf.ly/1713566/instedmst Forseti, niTe_RiDeR_Pr0, itsnotu and 4 others 7 Quote
ricktendo Posted September 2, 2012 Author Posted September 2, 2012 Updated evalcom2.dll+mergemod.dll v5.0.9200.16384 and \Validation\*.cub from the new Orca in WDK8 final Quote
Corey Posted February 11, 2013 Posted February 11, 2013 for instad thanks so much for all of your hardwork. Quote
ricktendo Posted September 2, 2013 Author Posted September 2, 2013 Updated evalcom2.dll+mergemod.dll v5.0.9600.16384 and \Validation\*.cub from the new Orca in WDK8.1 final HJSC and Forseti 2 Quote
niTe_RiDeR_Pr0 Posted January 31, 2015 Posted January 31, 2015 thank you rick for sharing this, & thanks to yumaeyo for creating this Quote
Forseti Posted August 7, 2015 Posted August 7, 2015 good morning Rick, Have an idea why I get a cab building errors? Now I am working with Windows 10! Net 3.5 and your Visual C++ Runtimes pack is installed! I hope you can help me.. Quote
ricktendo Posted August 9, 2015 Author Posted August 9, 2015 Your formatted hdd partition or OS does not support 8.3 filenames Quote
Forseti Posted August 12, 2015 Posted August 12, 2015 Your formatted hdd partition or OS does not support 8.3 filenamesthere is an alternative tool? Quote
ricktendo Posted August 12, 2015 Author Posted August 12, 2015 You can add this support back with fsutil, or execute it on a partition/os that does support 8.3 filenames Quote
Forseti Posted August 13, 2015 Posted August 13, 2015 You can add this support back with fsutil, or execute it on a partition/os that does support 8.3 filenames it does not work! you are using Windows 10? Perhaps because of the permissions? I do not have full control! Quote
ricktendo Posted August 13, 2015 Author Posted August 13, 2015 No, its because your partition does NOT support 8.3 filenames. Use fsutil to determine and change this https://technet.microsoft.com/en-us/library/ff621566.aspx Run this command and tell me the result (also let me know how many partitions you have on your machine) fsutil 8dot3name query Quote
Forseti Posted August 13, 2015 Posted August 13, 2015 (edited) Run this command and tell me the result (also let me know how many partitions you have on your machine) fsutil 8dot3name query I have 2 Corsair SSD's a 120GB unpartitions.. EDIT: 0 - Enable 8dot3 name creation on all volumes on the system1 - Disable 8dot3 name creation on all volumes on the system2 - Set 8dot3 name creation on a per volume basis3 - Disable 8dot3 name creation on all volumes except the system volume always the same result! :crying_anim02: Edited August 13, 2015 by Forseti Quote
ricktendo Posted August 13, 2015 Author Posted August 13, 2015 Tell me, did you happen to reboot after you set this? (something tells me the answer is No) 0 should work on all ssd's, or 2 then you enable it on one or the other drive, then put your MSI on that drive and re-try You can use mountvol to determine the VolumePath, example mountvol D:\ /LOnce you have the volume name, you can enable it on ONLY your D:\ drive and leave C:\ as is fsutil 8dot3name set 2 Volume{your-drive-guid-here}Now put your MSI on D:\ and you will be able to rebuild MSI CAB Quote
Forseti Posted August 14, 2015 Posted August 14, 2015 (edited) Tell me, did you happen to reboot after you set this? (something tells me the answer is No) Rick, Please believe me, I've done everything as described, incl. reboot! I suspect the error in the write protection, the InstEd Version or another Windows 10 bug!Use you Windows 10, if so, which version? and they have been modified with NTlite or Winreducer? sorry for my bad english, I hope you understand me... :flowers: Edit:I tested it again! I've found that it occurs only in certain MSI installers! works:- Eraser it does not work:- FileLocator Pro- Skype for business- Silverlight (your Installer) I alone under Windows 10 the problems, under Windows 7 works perfectly! Return to Windows 7 in the VM, for me only times the best way! @Rick Thank you for your support :giveheart: Edited August 14, 2015 by Forseti Quote
bphlpt Posted August 14, 2015 Posted August 14, 2015 From what I understand, Windows 10 has indeed tightened up the permissions so that it is much more difficult, if it is possible at all, to do certain things to various parts of the system, even if you are the administrator. Just one more reason that I don't like Windows 10. Cheers and Regards Quote
ricktendo Posted August 14, 2015 Author Posted August 14, 2015 The reason for the makecab error is because insted generates a ddf file (in insted right click cab and choose show ddf) that it uses with makecab to rebuild installer (makecab /f filename.ddf,) if your hdd/os does not support 8.3 filenames this will failSee the ddf for silverlight (full of 8.3 file/path names) ;*** InstEd produced MakeCAB Directive file;.OPTION EXPLICIT ; Generate errors.Set CabinetNameTemplate=1.set DiskDirectoryTemplate=CDROM.Set FolderSizeThreshold=4294967295 ;M.Set CompressionType=LZX.Set CompressionMemory=21 ; Best Compression.Set UniqueFiles=ON.Set Cabinet=on.Set DiskDirectory1=..Set MaxCabinetSize=0.Set MaxDiskSize=0.Set SourceDir=D:\WPI\Install\SILVER~1.Set InfDateFormat=yyyy-mm-ddPFiles\MICROS~1\514072~1.0\agcp.exe agcpEXEPFILES~1\MICROS~1\514072~1.0\agcp.exe agcpEXE_64PFiles\MICROS~1\514072~1.0\coreclr.dll coreclrDLLPFILES~1\MICROS~1\514072~1.0\coreclr.dll coreclrDLL_64PFiles\MICROS~1\514072~1.0\agcore.dll coreDLLPFILES~1\MICROS~1\514072~1.0\agcore.dll coreDLL_64PFiles\MICROS~1\514072~1.0\coregen.exe coregenEXEPFILES~1\MICROS~1\514072~1.0\coregen.exe coregenEXE_64PFiles\MICROS~1\514072~1.0\npctrl.dll ctrlDLLPFILES~1\MICROS~1\514072~1.0\npctrl.dll ctrlDLL_64PFiles\MICROS~1\514072~1.0\npctrlui.dll ctrlResourceDLLPFILES~1\MICROS~1\514072~1.0\npctrlui.dll ctrlResourceDLL_64PFiles\MICROS~1\514072~1.0\SLRDLL~1.MAN manifestXMLPFILES~1\MICROS~1\514072~1.0\SLRDLL~1.MAN manifestXML_64PFiles\MICROS~1\514072~1.0\MICROS~1.DLL Microsoft.Xna.Framework.Graphics.ShadersDLLPFILES~1\MICROS~1\514072~1.0\MICROS~1.DLL Microsoft.Xna.Framework.Graphics.ShadersDLL_64PFiles\MICROS~1\514072~1.0\MICROS~2.DLL Microsoft.Xna.Framework.GraphicsDLLPFILES~1\MICROS~1\514072~1.0\MICROS~2.DLL Microsoft.Xna.Framework.GraphicsDLL_64PFiles\MICROS~1\514072~1.0\MICROS~3.DLL Microsoft.Xna.FrameworkDLLPFILES~1\MICROS~1\514072~1.0\MICROS~3.DLL Microsoft.Xna.FrameworkDLL_64PFiles\MICROS~1\514072~1.0\ar\MICROS~1.DLL microsoftvisualbasic_arDLLPFILES~1\MICROS~1\514072~1.0\ar\MICROS~1.DLL microsoftvisualbasic_arDLL_64PFiles\MICROS~1\514072~1.0\bg\MICROS~1.DLL microsoftvisualbasic_bgDLLPFILES~1\MICROS~1\514072~1.0\bg\MICROS~1.DLL microsoftvisualbasic_bgDLL_64PFiles\MICROS~1\514072~1.0\ca\MICROS~1.DLL microsoftvisualbasic_caDLLPFILES~1\MICROS~1\514072~1.0\ca\MICROS~1.DLL microsoftvisualbasic_caDLL_64PFiles\MICROS~1\514072~1.0\cs\MICROS~1.DLL microsoftvisualbasic_csDLLPFILES~1\MICROS~1\514072~1.0\cs\MICROS~1.DLL microsoftvisualbasic_csDLL_64PFiles\MICROS~1\514072~1.0\da\MICROS~1.DLL microsoftvisualbasic_daDLLPFILES~1\MICROS~1\514072~1.0\da\MICROS~1.DLL microsoftvisualbasic_daDLL_64PFiles\MICROS~1\514072~1.0\de\MICROS~1.DLL microsoftvisualbasic_deDLLPFILES~1\MICROS~1\514072~1.0\de\MICROS~1.DLL microsoftvisualbasic_deDLL_64PFiles\MICROS~1\514072~1.0\el\MICROS~1.DLL microsoftvisualbasic_elDLLPFILES~1\MICROS~1\514072~1.0\el\MICROS~1.DLL microsoftvisualbasic_elDLL_64PFiles\MICROS~1\514072~1.0\es\MICROS~1.DLL microsoftvisualbasic_esDLLPFILES~1\MICROS~1\514072~1.0\es\MICROS~1.DLL microsoftvisualbasic_esDLL_64PFiles\MICROS~1\514072~1.0\et\MICROS~1.DLL microsoftvisualbasic_etDLLPFILES~1\MICROS~1\514072~1.0\et\MICROS~1.DLL microsoftvisualbasic_etDLL_64PFiles\MICROS~1\514072~1.0\eu\MICROS~1.DLL microsoftvisualbasic_euDLLPFILES~1\MICROS~1\514072~1.0\eu\MICROS~1.DLL microsoftvisualbasic_euDLL_64PFiles\MICROS~1\514072~1.0\fi\MICROS~1.DLL microsoftvisualbasic_fiDLLPFILES~1\MICROS~1\514072~1.0\fi\MICROS~1.DLL microsoftvisualbasic_fiDLL_64PFiles\MICROS~1\514072~1.0\fr\MICROS~1.DLL microsoftvisualbasic_frDLLPFILES~1\MICROS~1\514072~1.0\fr\MICROS~1.DLL microsoftvisualbasic_frDLL_64PFiles\MICROS~1\514072~1.0\he\MICROS~1.DLL microsoftvisualbasic_heDLLPFILES~1\MICROS~1\514072~1.0\he\MICROS~1.DLL microsoftvisualbasic_heDLL_64PFiles\MICROS~1\514072~1.0\hr\MICROS~1.DLL microsoftvisualbasic_hrDLLPFILES~1\MICROS~1\514072~1.0\hr\MICROS~1.DLL microsoftvisualbasic_hrDLL_64PFiles\MICROS~1\514072~1.0\hu\MICROS~1.DLL microsoftvisualbasic_huDLLPFILES~1\MICROS~1\514072~1.0\hu\MICROS~1.DLL microsoftvisualbasic_huDLL_64PFiles\MICROS~1\514072~1.0\id\MICROS~1.DLL microsoftvisualbasic_idDLLPFILES~1\MICROS~1\514072~1.0\id\MICROS~1.DLL microsoftvisualbasic_idDLL_64PFiles\MICROS~1\514072~1.0\it\MICROS~1.DLL microsoftvisualbasic_itDLLPFILES~1\MICROS~1\514072~1.0\it\MICROS~1.DLL microsoftvisualbasic_itDLL_64PFiles\MICROS~1\514072~1.0\ja\MICROS~1.DLL microsoftvisualbasic_jaDLLPFILES~1\MICROS~1\514072~1.0\ja\MICROS~1.DLL microsoftvisualbasic_jaDLL_64PFiles\MICROS~1\514072~1.0\ko\MICROS~1.DLL microsoftvisualbasic_koDLLPFILES~1\MICROS~1\514072~1.0\ko\MICROS~1.DLL microsoftvisualbasic_koDLL_64PFiles\MICROS~1\514072~1.0\lt\MICROS~1.DLL microsoftvisualbasic_ltDLLPFILES~1\MICROS~1\514072~1.0\lt\MICROS~1.DLL microsoftvisualbasic_ltDLL_64PFiles\MICROS~1\514072~1.0\lv\MICROS~1.DLL microsoftvisualbasic_lvDLLPFILES~1\MICROS~1\514072~1.0\lv\MICROS~1.DLL microsoftvisualbasic_lvDLL_64PFiles\MICROS~1\514072~1.0\ms\MICROS~1.DLL microsoftvisualbasic_msDLLPFILES~1\MICROS~1\514072~1.0\ms\MICROS~1.DLL microsoftvisualbasic_msDLL_64PFiles\MICROS~1\514072~1.0\nl\MICROS~1.DLL microsoftvisualbasic_nlDLLPFILES~1\MICROS~1\514072~1.0\nl\MICROS~1.DLL microsoftvisualbasic_nlDLL_64PFiles\MICROS~1\514072~1.0\no\MICROS~1.DLL microsoftvisualbasic_noDLLPFILES~1\MICROS~1\514072~1.0\no\MICROS~1.DLL microsoftvisualbasic_noDLL_64PFiles\MICROS~1\514072~1.0\pl\MICROS~1.DLL microsoftvisualbasic_plDLLPFILES~1\MICROS~1\514072~1.0\pl\MICROS~1.DLL microsoftvisualbasic_plDLL_64PFiles\MICROS~1\514072~1.0\pt-BR\MICROS~1.DLL microsoftvisualbasic_pt_brDLLPFILES~1\MICROS~1\514072~1.0\pt-BR\MICROS~1.DLL microsoftvisualbasic_pt_brDLL_64PFiles\MICROS~1\514072~1.0\pt\MICROS~1.DLL microsoftvisualbasic_ptDLLPFILES~1\MICROS~1\514072~1.0\pt\MICROS~1.DLL microsoftvisualbasic_ptDLL_64PFiles\MICROS~1\514072~1.0\ro\MICROS~1.DLL microsoftvisualbasic_roDLLPFILES~1\MICROS~1\514072~1.0\ro\MICROS~1.DLL microsoftvisualbasic_roDLL_64PFiles\MICROS~1\514072~1.0\ru\MICROS~1.DLL microsoftvisualbasic_ruDLLPFILES~1\MICROS~1\514072~1.0\ru\MICROS~1.DLL microsoftvisualbasic_ruDLL_64PFiles\MICROS~1\514072~1.0\sk\MICROS~1.DLL microsoftvisualbasic_skDLLPFILES~1\MICROS~1\514072~1.0\sk\MICROS~1.DLL microsoftvisualbasic_skDLL_64PFiles\MICROS~1\514072~1.0\sl\MICROS~1.DLL microsoftvisualbasic_slDLLPFILES~1\MICROS~1\514072~1.0\sl\MICROS~1.DLL microsoftvisualbasic_slDLL_64PFiles\MICROS~1\514072~1.0\SR-CYR~1\MICROS~1.DLL microsoftvisualbasic_sr_cyrl_csDLLPFILES~1\MICROS~1\514072~1.0\SR-CYR~1\MICROS~1.DLL microsoftvisualbasic_sr_cyrl_csDLL_64PFiles\MICROS~1\514072~1.0\SR-LAT~1\MICROS~1.DLL microsoftvisualbasic_sr_latn_csDLLPFILES~1\MICROS~1\514072~1.0\SR-LAT~1\MICROS~1.DLL microsoftvisualbasic_sr_latn_csDLL_64PFiles\MICROS~1\514072~1.0\sv\MICROS~1.DLL microsoftvisualbasic_svDLLPFILES~1\MICROS~1\514072~1.0\sv\MICROS~1.DLL microsoftvisualbasic_svDLL_64PFiles\MICROS~1\514072~1.0\th\MICROS~1.DLL microsoftvisualbasic_thDLLPFILES~1\MICROS~1\514072~1.0\th\MICROS~1.DLL microsoftvisualbasic_thDLL_64PFiles\MICROS~1\514072~1.0\tr\MICROS~1.DLL microsoftvisualbasic_trDLLPFILES~1\MICROS~1\514072~1.0\tr\MICROS~1.DLL microsoftvisualbasic_trDLL_64PFiles\MICROS~1\514072~1.0\uk\MICROS~1.DLL microsoftvisualbasic_ukDLLPFILES~1\MICROS~1\514072~1.0\uk\MICROS~1.DLL microsoftvisualbasic_ukDLL_64PFiles\MICROS~1\514072~1.0\vi\MICROS~1.DLL microsoftvisualbasic_viDLLPFILES~1\MICROS~1\514072~1.0\vi\MICROS~1.DLL microsoftvisualbasic_viDLL_64PFiles\MICROS~1\514072~1.0\zh-Hans\MICROS~1.DLL microsoftvisualbasic_zh_hansDLLPFILES~1\MICROS~1\514072~1.0\zh-Hans\MICROS~1.DLL microsoftvisualbasic_zh_hansDLL_64PFiles\MICROS~1\514072~1.0\zh-Hant\MICROS~1.DLL microsoftvisualbasic_zh_hantDLLPFILES~1\MICROS~1\514072~1.0\zh-Hant\MICROS~1.DLL microsoftvisualbasic_zh_hantDLL_64PFiles\MICROS~1\514072~1.0\MICROS~4.DLL microsoftvisualbasicDLLPFILES~1\MICROS~1\514072~1.0\MICROS~4.DLL microsoftvisualbasicDLL_64PFiles\MICROS~1\514072~1.0\ar\MSCORL~1.DLL mscorlib_arDLLPFILES~1\MICROS~1\514072~1.0\ar\MSCORL~1.DLL mscorlib_arDLL_64PFiles\MICROS~1\514072~1.0\bg\MSCORL~1.DLL mscorlib_bgDLLPFILES~1\MICROS~1\514072~1.0\bg\MSCORL~1.DLL mscorlib_bgDLL_64PFiles\MICROS~1\514072~1.0\ca\MSCORL~1.DLL mscorlib_caDLLPFILES~1\MICROS~1\514072~1.0\ca\MSCORL~1.DLL mscorlib_caDLL_64PFiles\MICROS~1\514072~1.0\cs\MSCORL~1.DLL mscorlib_csDLLPFILES~1\MICROS~1\514072~1.0\cs\MSCORL~1.DLL mscorlib_csDLL_64PFiles\MICROS~1\514072~1.0\da\MSCORL~1.DLL mscorlib_daDLLPFILES~1\MICROS~1\514072~1.0\da\MSCORL~1.DLL mscorlib_daDLL_64PFiles\MICROS~1\514072~1.0\de\MSCORL~1.DLL mscorlib_deDLLPFILES~1\MICROS~1\514072~1.0\de\MSCORL~1.DLL mscorlib_deDLL_64PFiles\MICROS~1\514072~1.0\el\MSCORL~1.DLL mscorlib_elDLLPFILES~1\MICROS~1\514072~1.0\el\MSCORL~1.DLL mscorlib_elDLL_64PFiles\MICROS~1\514072~1.0\es\MSCORL~1.DLL mscorlib_esDLLPFILES~1\MICROS~1\514072~1.0\es\MSCORL~1.DLL mscorlib_esDLL_64PFiles\MICROS~1\514072~1.0\et\MSCORL~1.DLL mscorlib_etDLLPFILES~1\MICROS~1\514072~1.0\et\MSCORL~1.DLL mscorlib_etDLL_64PFiles\MICROS~1\514072~1.0\eu\MSCORL~1.DLL mscorlib_euDLLPFILES~1\MICROS~1\514072~1.0\eu\MSCORL~1.DLL mscorlib_euDLL_64PFiles\MICROS~1\514072~1.0\fi\MSCORL~1.DLL mscorlib_fiDLLPFILES~1\MICROS~1\514072~1.0\fi\MSCORL~1.DLL mscorlib_fiDLL_64PFiles\MICROS~1\514072~1.0\fr\MSCORL~1.DLL mscorlib_frDLLPFILES~1\MICROS~1\514072~1.0\fr\MSCORL~1.DLL mscorlib_frDLL_64PFiles\MICROS~1\514072~1.0\he\MSCORL~1.DLL mscorlib_heDLLPFILES~1\MICROS~1\514072~1.0\he\MSCORL~1.DLL mscorlib_heDLL_64PFiles\MICROS~1\514072~1.0\hr\MSCORL~1.DLL mscorlib_hrDLLPFILES~1\MICROS~1\514072~1.0\hr\MSCORL~1.DLL mscorlib_hrDLL_64PFiles\MICROS~1\514072~1.0\hu\MSCORL~1.DLL mscorlib_huDLLPFILES~1\MICROS~1\514072~1.0\hu\MSCORL~1.DLL mscorlib_huDLL_64PFiles\MICROS~1\514072~1.0\id\MSCORL~1.DLL mscorlib_idDLLPFILES~1\MICROS~1\514072~1.0\id\MSCORL~1.DLL mscorlib_idDLL_64PFiles\MICROS~1\514072~1.0\it\MSCORL~1.DLL mscorlib_itDLLPFILES~1\MICROS~1\514072~1.0\it\MSCORL~1.DLL mscorlib_itDLL_64PFiles\MICROS~1\514072~1.0\ja\MSCORL~1.DLL mscorlib_jaDLLPFILES~1\MICROS~1\514072~1.0\ja\MSCORL~1.DLL mscorlib_jaDLL_64PFiles\MICROS~1\514072~1.0\ko\MSCORL~1.DLL mscorlib_koDLLPFILES~1\MICROS~1\514072~1.0\ko\MSCORL~1.DLL mscorlib_koDLL_64PFiles\MICROS~1\514072~1.0\lt\MSCORL~1.DLL mscorlib_ltDLLPFILES~1\MICROS~1\514072~1.0\lt\MSCORL~1.DLL mscorlib_ltDLL_64PFiles\MICROS~1\514072~1.0\lv\MSCORL~1.DLL mscorlib_lvDLLPFILES~1\MICROS~1\514072~1.0\lv\MSCORL~1.DLL mscorlib_lvDLL_64PFiles\MICROS~1\514072~1.0\ms\MSCORL~1.DLL mscorlib_msDLLPFILES~1\MICROS~1\514072~1.0\ms\MSCORL~1.DLL mscorlib_msDLL_64PFiles\MICROS~1\514072~1.0\nl\MSCORL~1.DLL mscorlib_nlDLLPFILES~1\MICROS~1\514072~1.0\nl\MSCORL~1.DLL mscorlib_nlDLL_64PFiles\MICROS~1\514072~1.0\no\MSCORL~1.DLL mscorlib_noDLLPFILES~1\MICROS~1\514072~1.0\no\MSCORL~1.DLL mscorlib_noDLL_64PFiles\MICROS~1\514072~1.0\pl\MSCORL~1.DLL mscorlib_plDLLPFILES~1\MICROS~1\514072~1.0\pl\MSCORL~1.DLL mscorlib_plDLL_64PFiles\MICROS~1\514072~1.0\pt-BR\MSCORL~1.DLL mscorlib_pt_brDLLPFILES~1\MICROS~1\514072~1.0\pt-BR\MSCORL~1.DLL mscorlib_pt_brDLL_64PFiles\MICROS~1\514072~1.0\pt\MSCORL~1.DLL mscorlib_ptDLLPFILES~1\MICROS~1\514072~1.0\pt\MSCORL~1.DLL mscorlib_ptDLL_64PFiles\MICROS~1\514072~1.0\ro\MSCORL~1.DLL mscorlib_roDLLPFILES~1\MICROS~1\514072~1.0\ro\MSCORL~1.DLL mscorlib_roDLL_64PFiles\MICROS~1\514072~1.0\ru\MSCORL~1.DLL mscorlib_ruDLLPFILES~1\MICROS~1\514072~1.0\ru\MSCORL~1.DLL mscorlib_ruDLL_64PFiles\MICROS~1\514072~1.0\sk\MSCORL~1.DLL mscorlib_skDLLPFILES~1\MICROS~1\514072~1.0\sk\MSCORL~1.DLL mscorlib_skDLL_64PFiles\MICROS~1\514072~1.0\sl\MSCORL~1.DLL mscorlib_slDLLPFILES~1\MICROS~1\514072~1.0\sl\MSCORL~1.DLL mscorlib_slDLL_64PFiles\MICROS~1\514072~1.0\SR-CYR~1\MSCORL~1.DLL mscorlib_sr_cyrl_csDLLPFILES~1\MICROS~1\514072~1.0\SR-CYR~1\MSCORL~1.DLL mscorlib_sr_cyrl_csDLL_64PFiles\MICROS~1\514072~1.0\SR-LAT~1\MSCORL~1.DLL mscorlib_sr_latn_csDLLPFILES~1\MICROS~1\514072~1.0\SR-LAT~1\MSCORL~1.DLL mscorlib_sr_latn_csDLL_64PFiles\MICROS~1\514072~1.0\sv\MSCORL~1.DLL mscorlib_svDLLPFILES~1\MICROS~1\514072~1.0\sv\MSCORL~1.DLL mscorlib_svDLL_64PFiles\MICROS~1\514072~1.0\th\MSCORL~1.DLL mscorlib_thDLLPFILES~1\MICROS~1\514072~1.0\th\MSCORL~1.DLL mscorlib_thDLL_64PFiles\MICROS~1\514072~1.0\tr\MSCORL~1.DLL mscorlib_trDLLPFILES~1\MICROS~1\514072~1.0\tr\MSCORL~1.DLL mscorlib_trDLL_64PFiles\MICROS~1\514072~1.0\uk\MSCORL~1.DLL mscorlib_ukDLLPFILES~1\MICROS~1\514072~1.0\uk\MSCORL~1.DLL mscorlib_ukDLL_64PFiles\MICROS~1\514072~1.0\vi\MSCORL~1.DLL mscorlib_viDLLPFILES~1\MICROS~1\514072~1.0\vi\MSCORL~1.DLL mscorlib_viDLL_64PFiles\MICROS~1\514072~1.0\zh-Hans\MSCORL~1.DLL mscorlib_zh_hansDLLPFILES~1\MICROS~1\514072~1.0\zh-Hans\MSCORL~1.DLL mscorlib_zh_hansDLL_64PFiles\MICROS~1\514072~1.0\zh-Hant\MSCORL~1.DLL mscorlib_zh_hantDLLPFILES~1\MICROS~1\514072~1.0\zh-Hant\MSCORL~1.DLL mscorlib_zh_hantDLL_64PFiles\MICROS~1\514072~1.0\mscorlib.dll mscorlibDLLPFILES~1\MICROS~1\514072~1.0\mscorlib.DLL mscorlibDLL_64PFiles\MICROS~1\514072~1.0\ar\mscorrc.dll mscorrc_arDLLPFILES~1\MICROS~1\514072~1.0\ar\mscorrc.dll mscorrc_arDLL_64PFiles\MICROS~1\514072~1.0\bg\mscorrc.dll mscorrc_bgDLLPFILES~1\MICROS~1\514072~1.0\bg\mscorrc.dll mscorrc_bgDLL_64PFiles\MICROS~1\514072~1.0\ca\mscorrc.dll mscorrc_caDLLPFILES~1\MICROS~1\514072~1.0\ca\mscorrc.dll mscorrc_caDLL_64PFiles\MICROS~1\514072~1.0\cs\mscorrc.dll mscorrc_csDLLPFILES~1\MICROS~1\514072~1.0\cs\mscorrc.dll mscorrc_csDLL_64PFiles\MICROS~1\514072~1.0\da\mscorrc.dll mscorrc_daDLLPFILES~1\MICROS~1\514072~1.0\da\mscorrc.dll mscorrc_daDLL_64PFiles\MICROS~1\514072~1.0\de\mscorrc.dll mscorrc_deDLLPFILES~1\MICROS~1\514072~1.0\de\mscorrc.dll mscorrc_deDLL_64PFiles\MICROS~1\514072~1.0\el\mscorrc.dll mscorrc_elDLLPFILES~1\MICROS~1\514072~1.0\el\mscorrc.dll mscorrc_elDLL_64PFiles\MICROS~1\514072~1.0\es\mscorrc.dll mscorrc_esDLLPFILES~1\MICROS~1\514072~1.0\es\mscorrc.dll mscorrc_esDLL_64PFiles\MICROS~1\514072~1.0\et\mscorrc.dll mscorrc_etDLLPFILES~1\MICROS~1\514072~1.0\et\mscorrc.dll mscorrc_etDLL_64PFiles\MICROS~1\514072~1.0\eu\mscorrc.dll mscorrc_euDLLPFILES~1\MICROS~1\514072~1.0\eu\mscorrc.dll mscorrc_euDLL_64PFiles\MICROS~1\514072~1.0\fi\mscorrc.dll mscorrc_fiDLLPFILES~1\MICROS~1\514072~1.0\fi\mscorrc.dll mscorrc_fiDLL_64PFiles\MICROS~1\514072~1.0\fr\mscorrc.dll mscorrc_frDLLPFILES~1\MICROS~1\514072~1.0\fr\mscorrc.dll mscorrc_frDLL_64PFiles\MICROS~1\514072~1.0\he\mscorrc.dll mscorrc_heDLLPFILES~1\MICROS~1\514072~1.0\he\mscorrc.dll mscorrc_heDLL_64PFiles\MICROS~1\514072~1.0\hr\mscorrc.dll mscorrc_hrDLLPFILES~1\MICROS~1\514072~1.0\hr\mscorrc.dll mscorrc_hrDLL_64PFiles\MICROS~1\514072~1.0\hu\mscorrc.dll mscorrc_huDLLPFILES~1\MICROS~1\514072~1.0\hu\mscorrc.dll mscorrc_huDLL_64PFiles\MICROS~1\514072~1.0\id\mscorrc.dll mscorrc_idDLLPFILES~1\MICROS~1\514072~1.0\id\mscorrc.dll mscorrc_idDLL_64PFiles\MICROS~1\514072~1.0\it\mscorrc.dll mscorrc_itDLLPFILES~1\MICROS~1\514072~1.0\it\mscorrc.dll mscorrc_itDLL_64PFiles\MICROS~1\514072~1.0\ja\mscorrc.dll mscorrc_jaDLLPFILES~1\MICROS~1\514072~1.0\ja\mscorrc.dll mscorrc_jaDLL_64PFiles\MICROS~1\514072~1.0\ko\mscorrc.dll mscorrc_koDLLPFILES~1\MICROS~1\514072~1.0\ko\mscorrc.dll mscorrc_koDLL_64PFiles\MICROS~1\514072~1.0\lt\mscorrc.dll mscorrc_ltDLLPFILES~1\MICROS~1\514072~1.0\lt\mscorrc.dll mscorrc_ltDLL_64PFiles\MICROS~1\514072~1.0\lv\mscorrc.dll mscorrc_lvDLLPFILES~1\MICROS~1\514072~1.0\lv\mscorrc.dll mscorrc_lvDLL_64PFiles\MICROS~1\514072~1.0\ms\mscorrc.dll mscorrc_msDLLPFILES~1\MICROS~1\514072~1.0\ms\mscorrc.dll mscorrc_msDLL_64PFiles\MICROS~1\514072~1.0\nl\mscorrc.dll mscorrc_nlDLLPFILES~1\MICROS~1\514072~1.0\nl\mscorrc.dll mscorrc_nlDLL_64PFiles\MICROS~1\514072~1.0\no\mscorrc.dll mscorrc_noDLLPFILES~1\MICROS~1\514072~1.0\no\mscorrc.dll mscorrc_noDLL_64PFiles\MICROS~1\514072~1.0\pl\mscorrc.dll mscorrc_plDLLPFILES~1\MICROS~1\514072~1.0\pl\mscorrc.dll mscorrc_plDLL_64PFiles\MICROS~1\514072~1.0\pt-BR\mscorrc.dll mscorrc_pt_brDLLPFILES~1\MICROS~1\514072~1.0\pt-BR\mscorrc.dll mscorrc_pt_brDLL_64PFiles\MICROS~1\514072~1.0\pt\mscorrc.dll mscorrc_ptDLLPFILES~1\MICROS~1\514072~1.0\pt\mscorrc.dll mscorrc_ptDLL_64PFiles\MICROS~1\514072~1.0\ro\mscorrc.dll mscorrc_roDLLPFILES~1\MICROS~1\514072~1.0\ro\mscorrc.dll mscorrc_roDLL_64PFiles\MICROS~1\514072~1.0\ru\mscorrc.dll mscorrc_ruDLLPFILES~1\MICROS~1\514072~1.0\ru\mscorrc.dll mscorrc_ruDLL_64PFiles\MICROS~1\514072~1.0\sk\mscorrc.dll mscorrc_skDLLPFILES~1\MICROS~1\514072~1.0\sk\mscorrc.dll mscorrc_skDLL_64PFiles\MICROS~1\514072~1.0\sl\mscorrc.dll mscorrc_slDLLPFILES~1\MICROS~1\514072~1.0\sl\mscorrc.dll mscorrc_slDLL_64PFiles\MICROS~1\514072~1.0\SR-CYR~1\mscorrc.dll mscorrc_sr_cyrl_csDLLPFILES~1\MICROS~1\514072~1.0\SR-CYR~1\mscorrc.dll mscorrc_sr_cyrl_csDLL_64PFiles\MICROS~1\514072~1.0\SR-LAT~1\mscorrc.dll mscorrc_sr_latn_csDLLPFILES~1\MICROS~1\514072~1.0\SR-LAT~1\mscorrc.dll mscorrc_sr_latn_csDLL_64PFiles\MICROS~1\514072~1.0\sv\mscorrc.dll mscorrc_svDLLPFILES~1\MICROS~1\514072~1.0\sv\mscorrc.dll mscorrc_svDLL_64PFiles\MICROS~1\514072~1.0\th\mscorrc.dll mscorrc_thDLLPFILES~1\MICROS~1\514072~1.0\th\mscorrc.dll mscorrc_thDLL_64PFiles\MICROS~1\514072~1.0\tr\mscorrc.dll mscorrc_trDLLPFILES~1\MICROS~1\514072~1.0\tr\mscorrc.dll mscorrc_trDLL_64PFiles\MICROS~1\514072~1.0\uk\mscorrc.dll mscorrc_ukDLLPFILES~1\MICROS~1\514072~1.0\uk\mscorrc.dll mscorrc_ukDLL_64PFiles\MICROS~1\514072~1.0\vi\mscorrc.dll mscorrc_viDLLPFILES~1\MICROS~1\514072~1.0\vi\mscorrc.dll mscorrc_viDLL_64PFiles\MICROS~1\514072~1.0\zh-Hans\mscorrc.dll mscorrc_zh_hansDLLPFILES~1\MICROS~1\514072~1.0\zh-Hans\mscorrc.dll mscorrc_zh_hansDLL_64PFiles\MICROS~1\514072~1.0\zh-Hant\mscorrc.dll mscorrc_zh_hantDLLPFILES~1\MICROS~1\514072~1.0\zh-Hant\mscorrc.dll mscorrc_zh_hantDLL_64PFiles\MICROS~1\514072~1.0\mscorrc.dll mscorrcDLLPFILES~1\MICROS~1\514072~1.0\mscorrc.DLL mscorrcDLL_64PFiles\MICROS~1\514072~1.0\SILVER~1.EXE silverlightconfigurationEXEPFILES~1\MICROS~1\514072~1.0\SILVER~1.EXE silverlightconfigurationEXE_64PFiles\MICROS~1\514072~1.0\SILVER~1.DLL silverlightconfigurationuiDLLPFILES~1\MICROS~1\514072~1.0\SILVER~1.DLL silverlightconfigurationuiDLL_64PFiles\MICROS~1\SLLAUN~1.EXE sllauncherEXEPFILES~1\MICROS~1\SLLAUN~1.EXE sllauncherEXE_64PFiles\MICROS~1\514072~1.0\SLMSPR~1.DLL SLMSPRBootstrapDLLPFILES~1\MICROS~1\514072~1.0\SLMSPR~1.DLL SLMSPRBootstrapDLL_64PFiles\MICROS~1\514072~1.0\SYSTEM~1.DLL System.Windows.XnaDLLPFILES~1\MICROS~1\514072~1.0\SYSTEM~1.DLL System.Windows.XnaDLL_64PFiles\MICROS~1\514072~1.0\SYSTEM~2.DLL System.WindowsDLLPFILES~1\MICROS~1\514072~1.0\SYSTEM~2.DLL System.WindowsDLL_64PFiles\MICROS~1\514072~1.0\ar\SYSTEM~1.DLL system_arDLLPFILES~1\MICROS~1\514072~1.0\ar\SYSTEM~1.DLL system_arDLL_64PFiles\MICROS~1\514072~1.0\bg\SYSTEM~1.DLL system_bgDLLPFILES~1\MICROS~1\514072~1.0\bg\SYSTEM~1.DLL system_bgDLL_64PFiles\MICROS~1\514072~1.0\ca\SYSTEM~1.DLL system_caDLLPFILES~1\MICROS~1\514072~1.0\ca\SYSTEM~1.DLL system_caDLL_64PFiles\MICROS~1\514072~1.0\cs\SYSTEM~1.DLL system_csDLLPFILES~1\MICROS~1\514072~1.0\cs\SYSTEM~1.DLL system_csDLL_64PFiles\MICROS~1\514072~1.0\da\SYSTEM~1.DLL system_daDLLPFILES~1\MICROS~1\514072~1.0\da\SYSTEM~1.DLL system_daDLL_64PFiles\MICROS~1\514072~1.0\de\SYSTEM~1.DLL system_deDLLPFILES~1\MICROS~1\514072~1.0\de\SYSTEM~1.DLL system_deDLL_64PFiles\MICROS~1\514072~1.0\el\SYSTEM~1.DLL system_elDLLPFILES~1\MICROS~1\514072~1.0\el\SYSTEM~1.DLL system_elDLL_64PFiles\MICROS~1\514072~1.0\es\SYSTEM~1.DLL system_esDLLPFILES~1\MICROS~1\514072~1.0\es\SYSTEM~1.DLL system_esDLL_64PFiles\MICROS~1\514072~1.0\et\SYSTEM~1.DLL system_etDLLPFILES~1\MICROS~1\514072~1.0\et\SYSTEM~1.DLL system_etDLL_64PFiles\MICROS~1\514072~1.0\eu\SYSTEM~1.DLL system_euDLLPFILES~1\MICROS~1\514072~1.0\eu\SYSTEM~1.DLL system_euDLL_64PFiles\MICROS~1\514072~1.0\fi\SYSTEM~1.DLL system_fiDLLPFILES~1\MICROS~1\514072~1.0\fi\SYSTEM~1.DLL system_fiDLL_64PFiles\MICROS~1\514072~1.0\fr\SYSTEM~1.DLL system_frDLLPFILES~1\MICROS~1\514072~1.0\fr\SYSTEM~1.DLL system_frDLL_64PFiles\MICROS~1\514072~1.0\he\SYSTEM~1.DLL system_heDLLPFILES~1\MICROS~1\514072~1.0\he\SYSTEM~1.DLL system_heDLL_64PFiles\MICROS~1\514072~1.0\hr\SYSTEM~1.DLL system_hrDLLPFILES~1\MICROS~1\514072~1.0\hr\SYSTEM~1.DLL system_hrDLL_64PFiles\MICROS~1\514072~1.0\hu\SYSTEM~1.DLL system_huDLLPFILES~1\MICROS~1\514072~1.0\hu\SYSTEM~1.DLL system_huDLL_64PFiles\MICROS~1\514072~1.0\id\SYSTEM~1.DLL system_idDLLPFILES~1\MICROS~1\514072~1.0\id\SYSTEM~1.DLL system_idDLL_64PFiles\MICROS~1\514072~1.0\it\SYSTEM~1.DLL system_itDLLPFILES~1\MICROS~1\514072~1.0\it\SYSTEM~1.DLL system_itDLL_64PFiles\MICROS~1\514072~1.0\ja\SYSTEM~1.DLL system_jaDLLPFILES~1\MICROS~1\514072~1.0\ja\SYSTEM~1.DLL system_jaDLL_64PFiles\MICROS~1\514072~1.0\ko\SYSTEM~1.DLL system_koDLLPFILES~1\MICROS~1\514072~1.0\ko\SYSTEM~1.DLL system_koDLL_64PFiles\MICROS~1\514072~1.0\lt\SYSTEM~1.DLL system_ltDLLPFILES~1\MICROS~1\514072~1.0\lt\SYSTEM~1.DLL system_ltDLL_64PFiles\MICROS~1\514072~1.0\lv\SYSTEM~1.DLL system_lvDLLPFILES~1\MICROS~1\514072~1.0\lv\SYSTEM~1.DLL system_lvDLL_64PFiles\MICROS~1\514072~1.0\ms\SYSTEM~1.DLL system_msDLLPFILES~1\MICROS~1\514072~1.0\ms\SYSTEM~1.DLL system_msDLL_64PFiles\MICROS~1\514072~1.0\nl\SYSTEM~1.DLL system_nlDLLPFILES~1\MICROS~1\514072~1.0\nl\SYSTEM~1.DLL system_nlDLL_64PFiles\MICROS~1\514072~1.0\no\SYSTEM~1.DLL system_noDLLPFILES~1\MICROS~1\514072~1.0\no\SYSTEM~1.DLL system_noDLL_64PFiles\MICROS~1\514072~1.0\pl\SYSTEM~1.DLL system_plDLLPFILES~1\MICROS~1\514072~1.0\pl\SYSTEM~1.DLL system_plDLL_64PFiles\MICROS~1\514072~1.0\pt-BR\SYSTEM~1.DLL system_pt_brDLLPFILES~1\MICROS~1\514072~1.0\pt-BR\SYSTEM~1.DLL system_pt_brDLL_64PFiles\MICROS~1\514072~1.0\pt\SYSTEM~1.DLL system_ptDLLPFILES~1\MICROS~1\514072~1.0\pt\SYSTEM~1.DLL system_ptDLL_64PFiles\MICROS~1\514072~1.0\ro\SYSTEM~1.DLL system_roDLLPFILES~1\MICROS~1\514072~1.0\ro\SYSTEM~1.DLL system_roDLL_64PFiles\MICROS~1\514072~1.0\ru\SYSTEM~1.DLL system_ruDLLPFILES~1\MICROS~1\514072~1.0\ru\SYSTEM~1.DLL system_ruDLL_64PFiles\MICROS~1\514072~1.0\sk\SYSTEM~1.DLL system_skDLLPFILES~1\MICROS~1\514072~1.0\sk\SYSTEM~1.DLL system_skDLL_64PFiles\MICROS~1\514072~1.0\sl\SYSTEM~1.DLL system_slDLLPFILES~1\MICROS~1\514072~1.0\sl\SYSTEM~1.DLL system_slDLL_64PFiles\MICROS~1\514072~1.0\SR-CYR~1\SYSTEM~1.DLL system_sr_cyrl_csDLLPFILES~1\MICROS~1\514072~1.0\SR-CYR~1\SYSTEM~1.DLL system_sr_cyrl_csDLL_64PFiles\MICROS~1\514072~1.0\SR-LAT~1\SYSTEM~1.DLL system_sr_latn_csDLLPFILES~1\MICROS~1\514072~1.0\SR-LAT~1\SYSTEM~1.DLL system_sr_latn_csDLL_64PFiles\MICROS~1\514072~1.0\sv\SYSTEM~1.DLL system_svDLLPFILES~1\MICROS~1\514072~1.0\sv\SYSTEM~1.DLL system_svDLL_64PFiles\MICROS~1\514072~1.0\th\SYSTEM~1.DLL system_thDLLPFILES~1\MICROS~1\514072~1.0\th\SYSTEM~1.DLL system_thDLL_64PFiles\MICROS~1\514072~1.0\tr\SYSTEM~1.DLL system_trDLLPFILES~1\MICROS~1\514072~1.0\tr\SYSTEM~1.DLL system_trDLL_64PFiles\MICROS~1\514072~1.0\uk\SYSTEM~1.DLL system_ukDLLPFILES~1\MICROS~1\514072~1.0\uk\SYSTEM~1.DLL system_ukDLL_64PFiles\MICROS~1\514072~1.0\vi\SYSTEM~1.DLL system_viDLLPFILES~1\MICROS~1\514072~1.0\vi\SYSTEM~1.DLL system_viDLL_64PFiles\MICROS~1\514072~1.0\zh-Hans\SYSTEM~1.DLL system_zh_hansDLLPFILES~1\MICROS~1\514072~1.0\zh-Hans\SYSTEM~1.DLL system_zh_hansDLL_64PFiles\MICROS~1\514072~1.0\zh-Hant\SYSTEM~1.DLL system_zh_hantDLLPFILES~1\MICROS~1\514072~1.0\zh-Hant\SYSTEM~1.DLL system_zh_hantDLL_64PFiles\MICROS~1\514072~1.0\SYSTEM~3.DLL systemcoreDLLPFILES~1\MICROS~1\514072~1.0\SYSTEM~3.DLL systemcoreDLL_64PFiles\MICROS~1\514072~1.0\system.dll systemDLLPFILES~1\MICROS~1\514072~1.0\system.dll systemDLL_64PFiles\MICROS~1\514072~1.0\SYSTEM~4.DLL systemnetDLLPFILES~1\MICROS~1\514072~1.0\SYSTEM~4.DLL systemnetDLL_64PFiles\MICROS~1\514072~1.0\SY2094~1.DLL systemruntimeserializationDLLPFILES~1\MICROS~1\514072~1.0\SY2094~1.DLL systemruntimeserializationDLL_64PFiles\MICROS~1\514072~1.0\SYF3C0~1.DLL systemservicemodelDLLPFILES~1\MICROS~1\514072~1.0\SYF3C0~1.DLL systemservicemodelDLL_64PFiles\MICROS~1\514072~1.0\SYA533~1.DLL systemservicemodelwebDLLPFILES~1\MICROS~1\514072~1.0\SYA533~1.DLL systemservicemodelwebDLL_64PFiles\MICROS~1\514072~1.0\SY8865~1.DLL systemwindowsbrowserDLLPFILES~1\MICROS~1\514072~1.0\SY8865~1.DLL systemwindowsbrowserDLL_64PFiles\MICROS~1\514072~1.0\SY1523~1.DLL systemwindowsruntimehostDLLPFILES~1\MICROS~1\514072~1.0\SY1523~1.DLL systemwindowsruntimehostDLL_64PFiles\MICROS~1\514072~1.0\SYE9D3~1.DLL systemxmlDLLPFILES~1\MICROS~1\514072~1.0\SYE9D3~1.DLL systemxmlDLL_64PFiles\MICROS~1\XAPAUT~1.DLL XAPAuthenticodeSIPDLLPFILES~1\MICROS~1\XAPAUT~1.DLL XAPAuthenticodeSIPDLL_64;*** <the end> Quote
Forseti Posted August 18, 2015 Posted August 18, 2015 @Rick after the update KB3081438 it works perfectly! Quote
