JaCro Posted May 5, 2006 Share Posted May 5, 2006 Hi,apparently can't open rich text editor on forum. The following message appears: "You have set 'Rich Text Editor' as your editor but your browser isn't compatible with it. The standard editor has been used instead."Can you check if is there any solution to fix this problem?p.s.Don't give some kinda answer that I should use IE instead of Opera. Quote Link to comment Share on other sites More sharing options...
NIM Posted May 5, 2006 Share Posted May 5, 2006 LOL, I'm not gonna say that, but I've just tried with IE7 and it works like a charm ....I'll try to find a solution for this problem... Quote Link to comment Share on other sites More sharing options...
NIM Posted May 6, 2006 Share Posted May 6, 2006 I've found this when googled for the Opera issue..Opera 9.0 Preview 1 was the first release with the rich text editing capability. However, most of the rich text editing JavaScript libraries don't do correct object detection, but browser sniffing. We're working with the library authors to make sure Opera is compatible. By the time Opera 9.0 is released, I hope that most rich text editors have been updated to recognize Opera 9.0.Regarding to this information you'll have to wait for Opera 9.0 final which should be able to work with rich-text editors.. :whistle: Quote Link to comment Share on other sites More sharing options...
JaCro Posted May 6, 2006 Author Share Posted May 6, 2006 Oh well, I'll wait for final release of Opera 9, cause I don't like to install beta. Thx, visualB1nary! Quote Link to comment Share on other sites More sharing options...
NIM Posted August 4, 2006 Share Posted August 4, 2006 Oh well, I'll wait for final release of Opera 9, cause I don't like to install beta. Thx, visualB1nary! So, did the new Opera version fixed this problem... :questionmark: Quote Link to comment Share on other sites More sharing options...
JaCro Posted August 5, 2006 Author Share Posted August 5, 2006 No... the same error message appears. Quote Link to comment Share on other sites More sharing options...
NIM Posted August 5, 2006 Share Posted August 5, 2006 No... the same error message appears. Somebody could say: "use the IE then", but I won't say that :rambo: I'll say, wait for the next version Quote Link to comment Share on other sites More sharing options...
