Thiersee Posted July 17, 2012 Posted July 17, 2012 (edited) Hi,the "move top/bottom"-buttons in the updates-tab ist still NOT working, also in version .34.The "Move to bottom" moves the 1st item on the top max. 100 positions down (I have 109 items).All others is working fine for me.Regards, Thiersee Edited July 17, 2012 by Thiersee Quote
caphp Posted July 18, 2012 Posted July 18, 2012 Hi Thiersee,try v35. Works fine for me so far.cu Quote
Thiersee Posted July 18, 2012 Author Posted July 18, 2012 Not for me, sorry!And the behaviour of "Move To Bottom" is quite different from "Move ToTop".Regards, Thiersee Quote
caphp Posted July 18, 2012 Posted July 18, 2012 Ah ok,maybe Legolash2o can take a look at it over again. Quote
Legolash2o Posted July 18, 2012 Posted July 18, 2012 I've managed to reproduce the error.EDIT: I might just remove the 'Move to Top' and 'Move to Bottom' buttons, they're more hassle than they are worth. Quote
compstuff Posted July 18, 2012 Posted July 18, 2012 Will we still have the move up and down buttons?I've managed to reproduce the error.EDIT: I might just remove the 'Move to Top' and 'Move to Bottom' buttons, they're more hassle than they are worth. Quote
Legolash2o Posted July 18, 2012 Posted July 18, 2012 Yes, they work perfectly however i've managed to fix the Top and Bottom buttons fully so all is good Marking topic as solved. Quote
Legolash2o Posted July 19, 2012 Posted July 19, 2012 Your awesome!!! THANKS!!!For a slight second while the topic was loading i was thinking "OMG it's still broken, AHHHHHHH" but i'm assuming everything is working correctly now? Quote
