Posted July 18, 201212 yr Hi i am building a win7 with 32bit and 64bit with update and drivers. i use WinToolkit140-35. Win7 build SP1 (7601). but my question is this. i use SoLoR windows updates, there is about over 300 hundre. but do i really need them all. should this build of windows 7 SP1 (7601) have some updates already build in to the Wim.install file. or am i wrong here.Kind regards Maxithx
July 18, 201212 yr Well the updates at the minute are McRips as SoLoR is having a break To answer your question, I always integrate them all but when it comes to the 'Additional' folder I only integrate what I think I will need.
July 18, 201212 yr Use KUC to scan your mounted wim for updates, it will give you exactly the updates you need and nothing more
