I am just getting this error again, too. Does not matter whether I use Windows 7 or Windows 8. I guess it is language dependent, because on English versions only everthing works like a charm.
Form: All-In-One Integrator (1.4.0.40) (2 Images Selected)(frmAllInOne)
Description: Could not extract files!
Status: F:\Win7Temp\WINTOOLKIT\cInst\Windows8Family-KB2717246-x64-RP.cab [0 bytes]
Exception: Could not find file 'F:\Win7Temp\WINTOOLKIT\cInst\Windows8Family-KB2717246-x64-RP.cab'.
Form History:frmStartup, frmToolsManager, frmSoLoR, frmToolsManager, frmWIMManager, frmAllInOne, frmTweaks, frmTweaks, frmTweaks,
Open Forms:frmStartup, frmAllInOne,
#Tweaks
Add 'Register' and 'Unregister' to *.dll, *.ocx and *.ax Context Menu
Show 'Computer' on Desktop
Show 'Control Panel' on Desktop
Show 'Network' on Desktop
Show User Folder on Desktop
Small Taskbar Icons
Allow 3rd Party Themes
Always Show Menu Bars
Increase Icon Cache
Show File Extensions
Show Hidden Files & Folders
Show System Files
Speed Up Desktop
Speed-up Access to AVI Media Files
Enable DVD in Media Player
Enable SSL and TLS
GPU Rendering::GPU Rendering On
IE Homepage::http://www.google.com
Launch Internet Explorer in Separate Process
Set Google as Search Provider
Show IE Statusbar
Turn On Clear Type
Unlimited Simultaneous Downloads
Use small icons on Start Menu
Shutdown Quicker
Always Unload DLL
Disable Bandwidth Limit
Disable CPU Parking (AMD)
Enable MAC File Sharing
Large System Cache::Enable
Enable Legacy .NET Framework
#Updates
K:\EigeneDataXP32\Downloads\8\x64\Windows6.2-kb2717246-x64.msu
K:\EigeneDataXP32\Downloads\8\x64\Windows6.2-kb2718704-x64.msu
K:\EigeneDataXP32\Downloads\8\x64\Windows6.2-kb2718791-x64.msu
K:\EigeneDataXP32\Downloads\8\x64\Windows6.2-kb2719985-x64.msu
K:\EigeneDataXP32\Downloads\8\x64\Windows6.2-kb2727113-x64.msu
K:\EigeneDataXP32\Downloads\8\x64\Windows6.2-kb2730450-x64.msu
K:\EigeneDataXP32\Downloads\8\x64\Additional\KB2693643RemoteServerAdministrationTools\Windows6.2-KB2693643-x64.msu
#Options
Compatibility Check
Create Backups
Enable CMD
Integrate 'HDC' Drivers (boot.wim)
Integrate 'SCSIADAPTER' Drivers (boot.wim)
Integrate 'SYSTEM' Drivers (boot.wim)
LDR-QFE Mode
Prepare Drivers
Prompt Addons
Prompt Drivers
Prompt Gadgets
Prompt Silent
Prompt Themes
Prompt Updates
Prompt Wallpapers
Rebuild Image
Status: F:\Win7Temp\WINTOOLKIT\cInst\Windows8Family-KB2718704-x64-RP.cab [0 bytes]
Exception: Could not find file 'F:\Win7Temp\WINTOOLKIT\cInst\Windows8Family-KB2718704-x64-RP.cab'.
Status: F:\Win7Temp\WINTOOLKIT\cInst\Windows8Family-KB2718791-x64-RP.cab [0 bytes]
Exception: Could not find file 'F:\Win7Temp\WINTOOLKIT\cInst\Windows8Family-KB2718791-x64-RP.cab'.
Status: F:\Win7Temp\WINTOOLKIT\cInst\Windows8Family-KB2719985-x64-RP.cab [0 bytes]
Exception: Could not find file 'F:\Win7Temp\WINTOOLKIT\cInst\Windows8Family-KB2719985-x64-RP.cab'.
Status: F:\Win7Temp\WINTOOLKIT\cInst\Windows8Family-KB2727113-x64-RP.cab [0 bytes]
Exception: Could not find file 'F:\Win7Temp\WINTOOLKIT\cInst\Windows8Family-KB2727113-x64-RP.cab'.
Status: F:\Win7Temp\WINTOOLKIT\cInst\Windows8Family-KB2730450-x64-RP.cab [0 bytes]
Exception: Could not find file 'F:\Win7Temp\WINTOOLKIT\cInst\Windows8Family-KB2730450-x64-RP.cab'.
Status: F:\Win7Temp\WINTOOLKIT\cInst\Windows6.2-KB2693643-x64.cab [0 bytes]
Exception: Could not find file 'F:\Win7Temp\WINTOOLKIT\cInst\Windows6.2-KB2693643-x64.cab'.
Form: frmTweaks (True)
Status: Updates | Preparing: 5 of 7 (KB2727113)
Unhandled Exception: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
StackTrace: at System.Collections.ArrayList.get_Item(Int32 index)
at System.Windows.Forms.ToolStripItemCollection.get_Item(Int32 index)
at System.Windows.Forms.ToolStrip.OnPaint(PaintEventArgs e)
at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer)
at System.Windows.Forms.Control.WmPaint(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.StatusStrip.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativewindow.WndProc(Message& m)
at System.Windows.Forms.Nativewindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
InnerException:
Source: mscorlib
TargetSite: System.Object get_Item(Int32)
Data: System.Collections.ListDictionaryInternal
Form History: frmStartup, frmToolsManager, frmSoLoR, frmToolsManager, frmWIMManager, frmAllInOne, frmTweaks, frmTweaks, frmTweaks,
Open Forms: frmStartup, frmAllInOne,
Items:
#Tweaks
Small Taskbar Icons
Increase Icon Cache
Show System Files
Speed Up Desktop
Enable SSL and TLS
Show IE Statusbar
Turn On Clear Type
Shutdown Quicker
Always Unload DLL
#Updates
#Options
Compatibility Check
Create Backups
Enable CMD
LDR-QFE Mode
Prepare Drivers
Prompt Addons
Prompt Drivers
Prompt Gadgets
Prompt Silent
Prompt Themes
Prompt Updates
Prompt Wallpapers
Rebuild Image
Form History:frmStartup, frmToolsManager, frmSoLoR, frmToolsManager, frmWIMManager, frmAllInOne, frmTweaks, frmTweaks, frmTweaks, frmError,
Open Forms:frmStartup, frmAllInOne, frmError,
The issue I have noticed is when I use an English version of Windows everything will be integrated just fine, but when I use a German version of Windows 7 or Windows 8 I get the "index out of range errors" and "file not found errors", but after all everything got integrated according to WinToolkit.
Weird all this
I have just created a dual-boot. Windows 7 and Windows 8. Windows 8 as a vhd file using diskpart while setup of Windows 8 comes up. The file not found is untrue, because this update was integrated successfully. I just have checked it in Windows 8.
Maybe this will help.
I think i've fixed the issue as i'm no longer getting the error, i'm pretty glad i've re-written the integration code as it seems A LOT quicker as there are less extractions needed.
QFE Mode Enabled
IE9 took 1:21 to integrate
Update 1: 22s
Update 2: 12s
Update 3: 22s
I don't integrate much so guys may be able to tell more than me.
Perfect. No more issues. Exept one thing for Windows 8. The Remote Server Administration Tools get integrated but still shows red... But that's not too bad.
Congrats, bro
Edited by McRip
