Just another "Little Thing":
ISO-Path (ISO-Folder) is not remembered; there is a path in the settings.txt.
fAddons=E:\ServicePacks-Install\Win_7\Windows_7_Toolkit
fDrivers=E:\DriverWin7\Motherboard\AHCI_win7\Win7x64
fGadgets=
fSilents=E:\ServicePacks-Install\Win_7\Windows_7_Toolkit\Thiersee
fThemes=E:\ServicePacks-Install\Win_7\Windows_Theme
fTweaks=
fUpdates=E:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_33_x64\patches
fWallpapers=
sAICommands=True
sAVScan=False
sAIOSave=True
sPreventSleep=True
sCheckForUpdates=True
sDLogging=True
sFreeRAM=True
sLastDir=C:\Users\Capo\Desktop
sLastWIM=E:\Win7_Prof_x64_DE_SP1_X17-59885\sources\install.wim
sPLastWIM=N/A|N/A|N/A|N/A|N/A
smCheck=False
sAIOPM=True
sMountTemp=C:\WinToolkit\Mount
sQuickMerge=True
sFormSize=|frmWIMManager:760*348|frmAllInOne:1477*1040|frmToolsManager:823*502
smVerify=False
sSolDownload=E:\Windows_7_Toolkit-Ausführen\UCatalog\
sShowSoLoR=False
sTMAero=True
sTransparency=100
sTransparencyAll=False
sWinToolkitDISM=Normal
sWinToolkitExt=Normal
sWinToolkitPRI=Normal
sWinToolkitTemp=C:\WinToolkit
sUploadLogs=True
sLastISO_Folder=E:\Win7_Prof_x64_DE_SP1_X17-59885
sLastISO_ISO=E:\ISO's\
sMountLog=True
sWelcomeTab=True
sDownloadTab=True
sToolsTab=True
sRegistryLog=True
Regards, Thiersee
It's working how it should, when you click 'Browse' button it will take you to the folder you last saved an ISO.
Sorry, it doesn't: when I click "Browse" it goes on "E:\", not on "E:\ISO's"!
Could be, it happens because of the hyphen in the path?
