Its a known bug, that is expected to be fixed in vaio's next release. ALready written in sidebar topic.
Not anymore, Rick cleaned the topic. :(
  • 6 months later...
Posted (edited)
PLEASE HELP ME!!!
I don't know how to remove one of this double icons on my control panel.
Edited by noob
HAHAHAHHAHAHAHAHA You used 2 different versions of my control panel didn't you?
Simply goto addremove programs and uninstall the CPL all in one...
But i want use your version(CPL all in one) Kel.
How to uninstall/remove the old version ?
You need to go into the system32 dir and find the relevant .cpl files for JUST those ones and delete them, the newer cpl all in one uses reg entries instead of cpl files so you will be safe to do that. REMEMBER to delete JUST the .cpl foles like bootvis and memtest the ones you have doubling of...
Thanks a lot Kels!
