After unmounting an image in AIO while it was processing, i chose to force dismount and read the tooltip saying there could be corruption. Is it possible for this force unmount to corrupt the updates folder which I download the 'solar' updates to? I say this because I was able to install office unattended a little while back, but now can't. The errors of office not installing point to a corrupt .net framework installation.
Also, should the 'force unmount' be ticked by default (as it currently is) if it can cause corruption?
It will only cause corrupt if for example a user is running Win Toolkit and some other program like RT7Lite/vLite at the SAME time. Believe me, some people do this and it results in an half saved image because another tool is working on the image. However if you're using the discard option then there's nothing to worry about what-so-ever.
EDIT: I've updated the description to cause less confusion :)
Thanks for the clarification!
I was running RT7lite at one stage and absent-mindedly opened up win toolkit, and the warning message popped up about never attempting this :). That's a good warning message, I make sure I'm careful.
