I tried the AutoUnattend.xml-Generator after a long time I didn' use it and I found an error in the section "WindowsPE/Windows-Setup/UserData" of the generated xml-file:
<?xml version="1.0" encoding="utf-8"?>
<!--Created by Win Toolkit v1.4.0.60-->
<unattend xmlns="urn:schemas-microsoft-com:unattend">
<settings pass="windowsPE">
<component name="Microsoft-Windows-Setup" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.micro...fig/2002/State" xmlns:xsi="http://www.w3.org/20...hema-instance">
<UserData>
<AcceptEula>true</AcceptEula>
<ProductKey>
<Key>HYF8J-CVRMY-CM74G-RPHKF-PW487</ProductKey>
<WillShowUI>Always</WillShowUI>
</ProductKey>
</UserData>
</component>
<component name="Microsoft-Windows-Setup" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.micro...fig/2002/State" xmlns:xsi="http://www.w3.org/20...hema-instance">
<UserData>
<ProductKey>
</ProductKey>
</UserData>
</component>
</settings>
This error causes this one if I load the generated AutoUnattend.xml in WAIK
The two red/bold ProductKey should be Key; if I replace those two word with "key" the error isn't coming up.
Just a question about the AutoUnattend-Generator.
In earlier version was possible to choose the architectur: is this feature not possible anymore?
Regards
P.S.: the Key is the default one from MS.
Edited by Thiersee
..... yeah i made it by default just support both architectures by default, if you want it bringing back then just make a request in the requests forum.
Thanks, it isnot really necessary, if it does not causes problem on install.
