Posted August 14, 201212 yr This morning i installed a fully updated enterprise, install mothernoard drivers, win toolkit and win rar.I did the usual exraction of win 7 x64 the one on legolash site list.ran win toolkit the and, removed all images cept ultimate!loaded mcrips updates, added some silent and non silent instals and a few tweaks!all went well, no problems arrived! made the iso, burned the image on a usb key using ultraiso.towards the end, it came up with cannot install components!Here is my settings and last session.ini.Thid is the second time i have done this, the first was tatally clean, just updates only!Several tries and still got install probs!Hey girls!... dont all answer at once!Win x64 test.iniSettings.txt Edited August 14, 201212 yr by Muffy
August 14, 201212 yr I'm getting he same error with just updates, that's every update from McRip for win7 64. Nothing else. Any of the 4 versions fail. 3 different machines.
August 14, 201212 yr Author I'm getting he same error with just updates, that's every update from McRip for win7 64. Nothing else. Any of the 4 versions fail. 3 different machines.Thanks for trying, i thought i was going mad! and Frustrated!can you be a little more specific on the "Any of the 4 versions fail. 3 different machines" bit as it seems odd!
August 22, 201212 yr I mean Home edition, Home Premium, Pro, and Ultimate. All versions get the same error. And I've tested on 3 different machines to make sure it was not the PC.It seems there's another thread on this, and it's most likely an update causing the problem, but not sure which one yet.
August 22, 201212 yr Author I mean Home edition, Home Premium, Pro, and Ultimate. All versions get the same error. And I've tested on 3 different machines to make sure it was not the PC.It seems there's another thread on this, and it's most likely an update causing the problem, but not sure which one yet.Yep, ok on the clarification (big word for me! :noexpression: ), i thought i was going mad! gone back to RT 7 at the mo messing around!
November 20, 201212 yr Any chance of a fix for this? I just tried again, months after this thread, still getting the same error, which means I can't install windows with updates integrated. I don't really know which of the 490 updates could be to blame, but maybe someone who understands the program better, can figure it out.
December 12, 201212 yr It has nothing to do with the program, it will be one of those 490 updates causing the issue.
