September 2, 201212 yr Author Uhmmm ... probably not. However, I can give long distance advice. If you are not going to use it in a year (or have not used it for more than a year), get rid of it. The point of that is "if you are not going to use it, why have it?".That's the rule i use, if i haven't used it in a year, sell it on eBay. Using that rule i didn't have much to unpack. If after another year i haven't used it then i try selling it again on eBay or just bin it.
September 2, 201212 yr Thats so LAME it barely even warrants this response!!!!!Uhmmm ... probably not. Seriously, one year and you have not unpacked/cleaned up/cleaned out, you are pushing it on being a hoarder. Five years .... you went too far, you *are* a hoarder. Twelve years .... you surpassed the limit and just need to have a house fire. *BAM* problem solved.
September 2, 201212 yr I also use that rule and I use another one also which makes me get rid of stuff BEFORE I move and not after ...that way I have less to move and to unpack each time I moveThat's the rule i use, if i haven't used it in a year, sell it on eBay. Using that rule i didn't have much to unpack. If after another year i haven't used it then i try selling it again on eBay or just bin it.
September 2, 201212 yr Thats so LAME it barely even warrants this response!!!!!Why thank you ... must mean that it was good. Seriously though, a bit of OCD cleaning does not hurt either. :punk:
