Posted August 27, 201212 yr hiI'm not a total beginner as I have already slip streamed SP3 on top my original SP2 CDROM.However I am new to nlite 1.491 and and the addition of files such ashttp://www.wincert.net/forum/topic/5747-addon-internet-explorer-8-enu-true-addon/ OnePiece IE8 WinXPSP3 v3.5.0 AddOn ENUI have extracted the files from the 7z zip file into a folder.I have copied my CD ROM files (XP SP3) to another folder and I have Nlite 1.4.9.1 installed. My aim is to protect my investment in Windows XP long after 8-Apr-2014.1. Add IE8 to the CD. (test installation) --- How i do not know as yet (Googling....)2. Add the other updates and hotfixes (100+) to the CD or DVD ONCE IT CONTAINS IE8Any pointers as what has to be done or articles tell me "how to" would be gratefully receivedThanksNeill
August 27, 201212 yr You dont need to extract the archive, in nLite you add the "addon" as a update/hotfix. You can also integrate a "updatepack" containing all updatesHere are some linksuser_hidden XP SP3 UpdatePackyumeyao IE8 (updated by me)yumeyao WMP11You can also add other programs: ccleaner, spywareblaster, etc. just search for the program name + the word addon
August 27, 201212 yr and too easy to integrate AddOns with nLite & RVMi, here look at these videos (however you should integrate Update Pack Onepiece XP Post-SP3 AIO Update Pack already includes all) You can also remove IE8 (Restore IE6) after installation Ciao. Edited September 4, 201311 yr by OnePiece
August 27, 201212 yr You can also remove WMP11 (Restore WMP9) after installation, and configure many other Optional Components create ISO or WinNT.sif Ciao. Edited September 4, 201311 yr by OnePiece
August 30, 201212 yr Author Thank you for your replies. Installing the One....7z file was easy and I produced an iso file. Intalling from that I find there are initial 112 security update/hotfixes to be applied. Is nlite intellegent? if I remove the one...7z file and add the 112 new hotfixes does it add them in the right manor (order) ?What a pain Windows catalog is why can't I select that Iwant only Windows XP - 32bit software
August 30, 201212 yr nLite is OK, but the hotfix integration with nLite is not as accurate or as clean as an AddOn\UpdatePackin poor words if you find an AddOn uses that, otherwise use nLite after to do that thing ect ectCiao. Edited August 30, 201212 yr by OnePiece
