Maybe it's my system but version 8.5.9 appears to conflict with config.js files that have the following commands in them:
cond[pn]=['getOSver()=="Win7"'];cond[pn]=['getmshtaBits()==32'];cond[pn]=['getmshtaBits()==64'];and desc[pn]= entries that begin with...['<P>...
I get an error message that points to the alterts.js file in the WPIScripts folder. I upgraded from v8.4.6.
Edited by BYTE-ME
I got rid of all the offending references and re-edited the config.js file. But it was tedious. Was just trying to give others a head's up in case they encounter the same issue.
Hey Byte-Me (I always wanted to say thet :D )
From the changelog:
v8.5.6 Updates - Released August 16th, 2012
*** Fixed out of line boxes issue on layout 3&4.
*** Changed the txt in Allow internet check --
-- This is a XP only function.
*** Fixed getArch6432 and getmshtaBits don't work.
*** Fixed conditions are inserted at the end.
*** Fixed a typo in global.
*** Fixed wrong path in audio copying\playing.
*** Fixed Cannot check categories when items are hidden.
*** Fixed Category was not translated in config wizard proglist.
*** Yet TONS more code cleanup!
*** Streamlined the Registry cleanup functions.
They never worked properly. I had to remove them. Sorry you had this issue.
If it crops up here is a time saver:
In notepad2 you can replace a whole line\section of text with nothing so replace all with a blank entry!!
