Posted August 31, 201212 yr I noticed that wintollkit mounts windows in "WinToolKit" folder under "mount" subfolder.My question is can i replace the files explorer.exe and the 5 patched theme files there before it finished all processes?If its possible, how do i get access to replace these files? since the system says i can't because its locked.Or there is another simpler way for that?The files i want to replace are.Patched explorer.exe with a new start menu orb.Patched themeservice.dll, uxtheme.dll and themeui.dll.so when i start windows after the instalation it already has my theme up and running. Edited August 31, 201212 yr by SsurferR
August 31, 201212 yr You need to take ownership of those files first, then replace them. That is how I been doing it and it always works.
August 31, 201212 yr Author You need to take ownership of those files first, then replace them. That is how I been doing it and it always works.LOL, I totally forgot about taking ownership of files, thanks for reminding me.
September 3, 201212 yr Add the file to the 'Advanced > Files' tab in AIO Integrator, it will do the whole taking ownership stuff for you.
