Posted September 1, 201212 yr Auslogics Disk Defrag is a vital maintenance tool that will improve your PC’s performance by defragmenting and re-arranging files on your disk. This software was designed to remedy system sluggishness and crashes caused by disk fragmentation. Auslogics Disk Defrag is extremely simple to use, does not require any analysis phase and is faster than most of the other disk defragmentation software. It will help you get the maximum performance out of your expensive hardware investments. Places system files to the faster part of the disk, minimizing the time needed for the hard drive to access them. Merges scattered pieces of free space into a contiguous block, preventing fragmentation of newly created files. Shows you the list of all fragmented files and their clusters location on the disk after performing disk analysis. Minimizes growth of the VSS storage area and reduces the chance of overwriting previous VSS snapshots. Can be set to start defragmentation automatically when computer has been idle for 15 minutes.Auslogics Disk Defrag® is designed for fast optimization of today’s modern hard disks. Get the maximum performance out of your expensive hardware investments. Can save your time by defragmenting only necessary files, instead of defragmenting an entire hard drive. It works on Windows 7/2008/Vista/2003/XP (32-bit and 64-bit).Auslogics Disk Defrag is not just a defragmenter any more, but a fully featured disk optimizer. And with all the advanced techniques of disk optimization it has, Disk Defrag 3 remains extremely compact and even easier to use!Homepagehttp://www.auslogics.com/en/software/disk-defrag/Addon:Architecture: x86Language: en-USUninstallable: NoSize: 5.59MBCreated: 8/31/2012MD5: c64b357bcabe35d08051200efeaf5bd6SHA1: d2af3a308fe1c3e9223c5d72b8bcc869df4c3fddDownloadhttp://www.mediafire.com/?57o8sk6d25j2kg5Silent Installer (No Switches Needed):Size: 4.89MBMD5: 0368fcba7f3b93be7b8c9144a1a3bb2dSHA1: f5bc3383e166fe4b4419789026cb31a4025c75c3Downloadhttp://www.mediafire.com/?i86cc73jf4b1bd8
