The latest version 1.4.0.65 not integrating registry .reg file correctly.
I always used the same settings from the same .reg file i created a while back when i first joined the forum a while back, never had a issue. Is it possible that it got broken after this new interface change? The reg files contains some instruction to remove a few keys from registry and some changed value to get the result i want.
I did 2 build's of the iso with the changes but, when i fired up a installation in a virtual machine, the settings weren't applyed. things like menus, icons settings for desktop and power option continues the same. A few days ago I tryed another version before this one and is got a error when importing the .reg file (think it was version 1.4.0.54 not sure thou) but i didn't get that error on version 1.4.0.65, but also didn't get the result I always get from your releases.
Anyhow great app! waiting for a reply.
Tested twice - version 1.4.0.65 doesn't register addons/programs in "uninstall or change a program", however, they are in start menu though.
- no icons of java or flash player in control panel.
Hi
There is a bug processing notepad2.wa in 140-65 with W7 pro SP1 x86.
After installing a system the folder "notepad2" and the files are at there place in x:\Program Files\...
but there are no registry entries about notepad2. :huh:
Using Editor starts the builtin Editor, not notepad2.
I´ve made a test with 140-45 and there is all ok.
It seems that something is going wrong from 140-45 to 140-65. :type:
Edited by wela
