September 3, 201213 yr If you have made a post about a bug or something that needs my attention then please give that topic a bump. I have a lot of unread posts so i need to know which ones are urgent
September 4, 201213 yr Bug: I am really hoping to fix the bug with the silent installers not adding an unininstall option to the add/remove.Request: Also it would be cool to possibly create desktop icons as an option for them.Request: Ability to add driver pack to ziped files to specifically work with http://driverpacks.n...verpacks/latest instead of having to extract them. Keep up the amazing work, this app is the ****! Ill be donating soon, expecting a bonus from work Edited September 4, 201213 yr by Simpuhl
September 4, 201213 yr @Simpuhl, Please add or bump your requests in the request area.Cheers and Regards
September 4, 201213 yr Author What bug with the silent installers, no one has posted a link to the bug in question.
September 6, 201213 yr @Legolash2oWhen installing a new version of windows, all silent installers that are in .wa format will not show up in the add/remove list. So the user must manually go to the install folder in program files and find the uninstall.exe.Refer to http://www.wincert.net/forum/topic/7240-ccleaner-v3221800/ and read what dareckibmw wrote.
September 6, 201213 yr Just so you know, *67 fixed all my problems! addons are integrated and registered properly ....and those icons too!Thanks Lego! :gleam:
September 6, 201213 yr @Legolash2oWhen installing a new version of windows, all silent installers that are in .wa format will not show up in the add/remove list. So the user must manually go to the install folder in program files and find the uninstall.exe.Refer to http://www.wincert.net/forum/topic/7240-ccleaner-v3221800/ and read what dareckibmw wrote.That is NOT a silent installer! It is a true addon.
September 6, 201213 yr Author @Legolash2oWhen installing a new version of windows, all silent installers that are in .wa format will not show up in the add/remove list. So the user must manually go to the install folder in program files and find the uninstall.exe.Refer to http://www.wincert.n...eaner-v3221800/ and read what dareckibmw wrote.That issue was fixed in v67, dareckibmw reported after you that it is now working That is NOT a silent installer! It is a true addon.Yeah, i wish people knew the difference. Easier when trying to fix things
September 9, 201213 yr Author My MediaFire source/link may have to go, as each time i log on i keep getting some sort of DCMA copyright notification because someone is reporting my files as copyrighted/stolen despite the fact that i own them :/
September 9, 201213 yr Ffing w,kers somebodys probably jelous! Edited September 9, 201213 yr by Muffy
September 9, 201213 yr My MediaFire source/link may have to go, as each time i log on i keep getting some sort of DCMA copyright notification because someone is reporting my files as copyrighted/stolen despite the fact that i own them :/Actually, that is probably more the "automated" bots that search peoples upload files to automatically ban stuff. It is very common these days as the "copyright trolls" have taken over. It is likely related to the name you have that is triggering it. Conversing with MediaFire will probably be pointless as "big content" usually wins (and they likely do not care anyway).
