Description
Easily view, print, and collaborate on PDF files with free Adobe Reader X software
Adobe Reader software is the global standard for electronic document sharing. It is the only PDF file viewer that can open and interact with all PDF documents. Use Adobe Reader to view, search, digitally sign, verify, print, and collaborate on Adobe PDF files.
Version: 10.1.4
Platform: x86 & x64
Uninstallable: Yes
Credit: *Simpuhl*
Download! - MD5 - A30A01AD7CD08C00EDD1CCBBB8EFE74B
Note: Add this as a silent installer... No Switches needed!
Details:
I took the offline installer, extracted it... edited it with Adobe Customization Wizard X, made it silent, supressed restart, eula, and made it default pdf viewer. It will make default desktop and startmenu icons and saved it. Then I used iexpress to make it a single .exe and then silent extract and run the setup.exe.
Edited by Simpuhl
Simpuhl, I tried your installer and it keeps adding v10.1.0 to my system so I decided to do my own in the same manner you created yours and damn mine also installs 10.1.0... I am totally confused on this...
post-11313-0-30270200-1348751845_thumb.j
Does anyone else have the same issue with this?
Compstuff, I can't confirm that I've had the same issue. However I did stumble upon this post in the Repacks forum. It sounds promising.
[Tweaked] Adobe Reader X 10.1.4 (enu, esp)
http://www.wincert.n...x-1014-enu-esp/
I havent intergrated it into any of my builds as of yet. Perhaps over the next few days. I'll post my results when I do. I'll be following both related threads aswell. Reagrds.
Edited by dotfusion
Thanks very much for the reply and your find... I love Rick's work his stuff is always superb...
I also noticed that lol, I couldn't figure out why! But I said screw it as it updates on its own... I just mainly wanted it "installed". Me having to clikc update rather then take the time to browse to adobe and download and install it is much better. Let me know if you figure something out though. I was going to wait till they release a newer version to try and update it.
  • 11 months later...
  • 4 months later...
  • 4 weeks later...
for silent mode extract and use the switch for "setup.exe" /sAll /RS which means /sAll (silent mode all) and /RS (Reboot Supress) ;)
Edited by KEiGHT
  • 9 years later...
