So yesterday I created a full customized disc using AIO-I, I tested it out, works perfectly but I left an addon out. Now when I open All-In-One Integrator it automatically opens my same folder and presets...
My question is if I just add the one addon to it will it have to go through the 3 hour process again or does it just add that one thing?
or
Should I uncheck all the presets and just add the 1 program?
or start fresh?
Thanks in advance
Sweet,
Thank you for the quick reply, you are this website are both amazing!
That will defintely help.
I did have 1 last question though, what if I wanted to "remove" an addon because theres an updated version id like to include instead?
Again, thanks in advance!
so just name the exe the same, i notice theres an app folder in the main directory now can I just override it there? without using aio-i ? or just delete it from there or would it cause an error since its missing?
