I got error during install: "Windows could not apply unattend settings during pass [offlineServicing]. " What's the problem?
It's possible to remove Unattend from image if applyed by "Full" method?
Edited by Edvardas Po
Win7x64 SP1
It's possible to remove Unattend from image if applyed by "Full" method? (as I understood from boot.wim ?)
my file:
<?xml version="1.0" encoding="utf-8"?>
<!--Created by Win Toolkit v1.4.0.70-->
<unattend xmlns="urn:schemas-microsoft-com:unattend">
<settings pass="windowsPE">
<component name="Microsoft-Windows-Setup" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.micro...fig/2002/State" xmlns:xsi="http://www.w3.org/20...hema-instance">
<UserData>
<AcceptEula>true</AcceptEula>
<ProductKey>
<Key>XXXXX-XXXXX-XXXXX-XXXXX-XXXXX</Key>
<WillShowUI>Always</WillShowUI>
</ProductKey>
</UserData>
</component>
<component name="Microsoft-Windows-Setup" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.micro...fig/2002/State" xmlns:xsi="http://www.w3.org/20...hema-instance">
<UserData>
<ProductKey>
</ProductKey>
</UserData>
</component>
</settings>
<settings pass="specialize">
<component name="Microsoft-Windows-Shell-Setup" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.micro...fig/2002/State" xmlns:xsi="http://www.w3.org/20...hema-instance">
<ProductKey>W9DBJ-QF796-RRKPG-VVQFW-JVDY3</ProductKey>
<ComputerName>server</ComputerName>
</component>
<component name="Microsoft-Windows-Shell-Setup" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.micro...fig/2002/State" xmlns:xsi="http://www.w3.org/20...hema-instance">
</component>
<component name="Microsoft-Windows-Security-SPP-UX" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.micro...fig/2002/State" xmlns:xsi="http://www.w3.org/20...hema-instance">
<SkipAutoActivation>true</SkipAutoActivation>
</component>
<component name="Microsoft-Windows-Security-SPP-UX" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.micro...fig/2002/State" xmlns:xsi="http://www.w3.org/20...hema-instance">
</component>
</settings>
<settings pass="oobeSystem">
<Display>
<ColorDepth>32</ColorDepth>
</Display>
<OOBE>
<HideEULAPage>true</HideEULAPage>
<NetworkLocation>Work</NetworkLocation>
<ProtectYourPC>3</ProtectYourPC>
</OOBE>
<RegisteredOwner>GP</RegisteredOwner>
<RegisteredOrganization>Dature</RegisteredOrganization>
<UserAccounts>
<AdministratorPassword>
<Value>mukas_2044</Value>
<PlainText>true</PlainText>
</AdministratorPassword>
<LocalAccounts>
<LocalAccount wcm:action="add">
<Name>Master</Name>
<Group>Administrators</Group>
<Password>
</Password>
<DisplayName>Master</DisplayName>
<Description>Master</Description>
</LocalAccount>
</LocalAccounts>
</UserAccounts>
<AutoLogon>
<Password>
</Password>
<Enabled>true</Enabled>
<LogonCount>5</LogonCount>
<Username>Administrator</Username>
</AutoLogon>
<TimeZone>FLE Standard Time</TimeZone>
</component>
<Display>
</Display>
<OOBE>
</OOBE>
<UserAccounts>
<LocalAccounts>
<Name>Master</Name>
<Password>
</Password>
</LocalAccount>
</LocalAccounts>
</UserAccounts>
<AutoLogon>
<Password>
</Password>
</AutoLogon>
</component>
</settings>
</unattend>
Does you install work without an unattended file?
I'm not sure if it can be removed, worse case scenario is you can just extract a new boot.wim from an iso and just replace that file.
if I will replace boot.wim in my AIO integrator prepared disk will it damage changes I made?
UPDATE
I made new disk with AIO Integrator with one difference: skipped Updates, added the same Unattend file, but with Quick method Onot Full).
Installed Win7x64 without problems.
So, looks like problem is with updates from Update Catalog (SoLoR)? I suggest that not adding Unattend file to the boot.wim in this situation isn't problem?
