I just downloaded the latest Win x64 Home Professional & SP1. Also downloaded all the updates from McRip (As of today Sep 13, 2012).
When I perform an integration, approximately 20 of the updates do NOT integrate.
You can see the failures in this picture:
Spidernz reported the same problem in this post.
I wonder if the problem is related to an inconsistency in the # of files downloaded?
After completing the update downloads, I had 468 files:
But WinToolkit reports I actually downloaded 473 files:
Where did the other 5 files go?
When selecting the updates to add, I use the menu option "Add Updates + Subfolders"
Should I instead be selecting the 371 updates in the main folder, and ignore or do something different with the stuff in the "additional" folder?
  On 9/14/2012 at 9:15 AM, Legolash2o said:
Those 20 updates are probably the additions, they only install if needed,
Then i have a feature suggestion: Can you color-code the "un-needed" updates differently than the failed updates? (maybe make them grey after processing)
speaking as a newbie, when i see things show up in red, I assume I screwed something up.
