[Solved] Live Essentials silent install fails, requires restart?
Live Essentials did not silently install correctly. When I tried to manually install it, windows showed this error:
Do I need to adjust the order of installs, or change my switches, so i can avoid the necessity to restart again? here is my current silent install:
Edited by grant3
Problem solved: I had typed "Mesenger" in the command line instead of "Messenger".
Because this prevented messenger from installing, i thought the entire install had failed (when in reality, Mail succeeded)
Also I discovered that attempting to install Silverlight from live essentials will cause a fatal crash during the silent install process. Moral of the story: use the separate update file for silverlight.
Edit: silverlight isn't even part of essentials. (i don't know why my install was crashing but it was probably related to duplicate silent installs being added to the iso every time i integrated it)
Edited by grant3
However using this silent switches doesn't work for me with Wimdows Live 2012, but works fine for Windows Live 2011:
wlsetup-all.exe /q /NOToolbarCEIP /NOhomepage /nolaunch /nosearch /AppSelect:Messenger,Mail,MovieMaker,Bingbar,Writer
And Silverligtht installed first!
Edited by myselfidem
Solved adding first Net Framework 4.0 and using this command for Windows 7 on WPI:
cmds[pn]=['"%wpipath%\\Install\\WLive\\wlsetup-all.exe" /q /AppSelect:Messenger%comma%Mail%comma%MovieMaker%comma%Writer%comma%Wlsync%comma%idcrl /log:%temp%\\Wlsetup.log /NOToolbarCEIP /NOhomepage /NOlaunch /NOMU /nosearch'];
desc[pn]=['Windows Live 2012'];
Skydrive is also installed! (Image)
https://skydrive.live.com/?cid=D178EA021B182B88&id=D178EA021B182B88%211397&sc=documents#cid=D178EA021B182B88&id=D178EA021B182B88%211488&sc=documents
Cheers
My Windows Essentials 2012 installs ok. I install DotNet45 first, and then the essentials with these switches:
"/q /NOToolbarCEIP /NOhomepage /NOLaunch /NoSearch /AppSelect:Mail,Messenger"
glad you fixed yours.
