Posted September 14, 201212 yr [sOLVED] Missing files on driverpack.This may be a bug on dism or in the tool, i'm not sure.I was integrating the drivers i downloaded from the driverpack.Source: pt_windows_7_ultimate_with_sp1_x86_dvd_u_677457.iso (only left the ultimate and i was working on it)Method: All in one integratorDriver: everything from there, also integrating all options to boot.wimErrorlog:2012-09-14_18:30PM: 'D:\TEMPS\Nova pasta\DP_Webcam_wnt6-x86_1103\x86\3\Webcam\Logitech\3\lvPEPI2s.inf'2012-09-14_18:30PM: 'D:\TEMPS\Nova pasta\DP_Webcam_wnt6-x86_1103\x86\3\Webcam\Logitech\3\lvPEPI2v.inf'2012-09-14_18:30PM: 'D:\TEMPS\Nova pasta\DP_Webcam_wnt6-x86_1103\x86\3\Webcam\Logitech\4\lvPRO5s.inf'2012-09-14_18:30PM: 'D:\TEMPS\Nova pasta\DP_Webcam_wnt6-x86_1103\x86\3\Webcam\Logitech\4\lvPRO5v.inf'Checking the files they were all in the folders and i made sure to check spelling and case (upper/lower), everything was exactly the same, so this doesn't seem to be an error. Edited September 17, 201212 yr by TheRuan
September 14, 201212 yr .....2012-09-14_18:30PM: 'D:\TEMPS\Nova pasta\DP_Webcam_wnt6-x86_1103\x86\3\Webcam\Logitech\3\lvPEPI2s.inf'2012-09-14_18:30PM: 'D:\TEMPS\Nova pasta\DP_Webcam_wnt6-x86_1103\x86\3\Webcam\Logitech\3\lvPEPI2v.inf'2012-09-14_18:30PM: 'D:\TEMPS\Nova pasta\DP_Webcam_wnt6-x86_1103\x86\3\Webcam\Logitech\4\lvPRO5s.inf'2012-09-14_18:30PM: 'D:\TEMPS\Nova pasta\DP_Webcam_wnt6-x86_1103\x86\3\Webcam\Logitech\4\lvPRO5v.inf'.....Try without blanks (space) in the path (Nova pasta).Regards, Thiersee
September 15, 201212 yr Author Try without blanks (space) in the path (Nova pasta).Regards, ThierseeThanks, that makes sense, will check later and report back with the results.
September 16, 201212 yr Author Weird, same thing, and same drivers, really weird bug, anyone knows how this is originated, is this coming from dism itself or from ,wintoolkit?Log:2012-09-16_00:08AM: 'D:\TEMPS\NovaPasta\DP_Webcam_wnt6-x86_1103\x86\3\Webcam\Logitech\3\lvPEPI2s.inf'2012-09-16_00:08AM: 'D:\TEMPS\NovaPasta\DP_Webcam_wnt6-x86_1103\x86\3\Webcam\Logitech\3\lvPEPI2v.inf'2012-09-16_00:08AM: 'D:\TEMPS\NovaPasta\DP_Webcam_wnt6-x86_1103\x86\3\Webcam\Logitech\4\lvPRO5s.inf'2012-09-16_00:08AM: 'D:\TEMPS\NovaPasta\DP_Webcam_wnt6-x86_1103\x86\3\Webcam\Logitech\4\lvPRO5v.inf'
September 16, 201212 yr Are you asking about the presence of the log entries themselves? Or are there actual errors (popups, install errors, etc.) associated with the log entries?Can you post a screenshot of the error?
September 16, 201212 yr If i remember correctly.... Those are from a driver pack and they have missing files which are not included but the *.inf file needs them to be installed.Look in WinToolkitEXEFolder\\Logs\\Driver_Errors.txtEDIT: Infact at the end of the integration you should have seen a message saying some drivers did not install and if you clicked yes, it would have taken you to a log.2012-09-16_10:08AM: 'C:\Users\Liam\Desktop\3\lvPEPI2s.cat'2012-09-16_10:08AM: 'C:\Users\Liam\Desktop\3\lvPEPI2v.cat'
September 16, 201212 yr I downloaded the drivers again from the Logitech site and compared the files between the installer and the webcam driverpack.Yes, there are missing files.I'll see about fixing these over at driverpacks.net
