When I try to integrate windows updates into a fresh image, sometimes a whole bunch of them end up "red", i.e., they weren't integrated.
It would be very helpful if the program somehow reported why they failed.... so I can intelligently
a. remove them from the .ini , or
b. fix whatever's broken and try again
thanks! -g
Edited by grant3
Though I guess it might be helpful, if it was possible, for Win Toolkit to distinguish between updates that aren't applicable vs ones that are either broken or otherwise fail to install.
