Posted September 24, 201212 yr Change Setup BackgroundChange Logon BackgroundSettings are saved to ini, but not loaded when using that very same preset.Also Silent Installers, Drivers, Theme Packs, Wallpapers arent loaded... Can, be deleted... had somekind of temporary glitch in my PC... Edited September 24, 201212 yr by Etz
October 3, 201212 yr Author Okay, found culprit, its not related to WinToolkit, but still...wanted to share some useful information.If you run WinToolkit from network drive, as I do, it happens if you using tweak that I propsed, for "Mapped drives"If you have it implemented, always remember to "access" those mapped drive(s) before you run WinToolkit, or there will be "profile" loading issues, as most of youre resources arent available to that machine, youre trying to do the build with As Network drives arent actually mounted yet Edited October 3, 201212 yr by Etz
