Mike2Able Posted September 28, 2012 Posted September 28, 2012 Is it possible to remove updates that have already been installed into a image using WinToolkit? Is there another way to do this?Thanks,Mike Quote
Legolash2o Posted September 28, 2012 Posted September 28, 2012 On a live system via Program/Features or Windows Update then 'Installed Updates'.Offline.... Win Toolkit > Main > Advanced > Component Removal and they should be listed at the bottom. Quote
