ziercool Posted September 29, 2012 Posted September 29, 2012 The problem is that the file is install.wim. all images Quote
RicaNeaga Posted September 29, 2012 Posted September 29, 2012 It's a Toshiba driver. Remove it from the integration and you won't have this issues anymore. Probably you are using driverpacks... Quote
bphlpt Posted September 29, 2012 Posted September 29, 2012 If you want help with this, I think you are going to need to provide a translation for what is printed in your screenshot.Cheers and Regards Quote
ziercool Posted September 29, 2012 Author Posted September 29, 2012 It's a Toshiba driver. Remove it from the integration and you won't have this issues anymore. Probably you are using driverpacks...Now as to remove it from Wim?If you want help with this, I think you are going to need to provide a translation for what is printed in your screenshot.Cheers and Regardsno translation - file not found .... Quote
