InstallWatch Pro 2.5c
For x86/x64
A utility that tracks changes made to your system during the installation or removal of software or hardware. Changes tracked include additions, deletions, or modifications to files and directories, INI files, and the Registry. All information is stored in a database so that it can be accessed later to generate reports. The Registry entries can also be exported to a Reg file for later use.
(Great tool for making inf addon)
Uninstallable: Yes
InstallWatch25c_dual.WA
Size: 1.78 Mb (1,861,991 bytes)
MD5: 6B09351396DAF395FFC37A09B359E109
Tested only on VM win7x86
Edited by Geej
  • 6 months later...
inf updated.
-Includes x64
-Support live install
(x64 untested, please feedback if encounter problem or if it works fine for you)
Cheers :)
