Posted October 12, 201212 yr Hello, and thank you for this great website and this awesome tool. NT6.x True Integrator and Win Tool Kit are simply extraordinary tools that compliment my current arsenal. I am a total n00b when it comes to coding .ini and .inf files, so please excuse my ignorance. Just one question today,..When coding .ini and .inf file for use with NT6.x True integrator, What is the proper encoding and line ending convention should I be using when using Netepad2.ie: Unicode, UTF-8, etc...ie: Windows (CR+F), UnIX (LF), etc...Any insight would be much appreciated. Thanks in advance. Edited October 12, 201212 yr by dotfusion
October 12, 201212 yr DX WinNT6.x True Integrator is able to recognize any scenario.For example, if you write a string in this way:Line1 & CRLF & Line2 & CR & Line3 & LF & Line4 & CRLF and so on, DXWNTI will be able to handle it correctlyAnyway in windows CRLF is used as default and so it is the one you should use: @CRLF ; Windows@LF ; Unix@CR ; MacAbout notepad, you can save it as you like:UTF-8, ASCII, etc.
October 12, 201212 yr Author Thanks for the reply. I figured as much. Thanks for your support. I think it's time I made a donation with my next pay check. Edited October 13, 201212 yr by dotfusion
